Hi Guys,
I will use this thread to discuss the VeeCU.
Introduction:
So …, where to begin. Back in the University days we were required to submit our homework in a specific format. That format was:
Given
Required
Solution
I’ll try that. You may not agree with all of my assertions and that’s OK. Here goes.
Given:
Most VW engines that have been converted for aircraft use have poor cylinder to cylinder fuel balance.
VW cylinder heads are somewhat fragile and so EGT and CHT limits must be observed and adhered to.
Many VW conversions are not equipped with an impulse mag and experience “kick-back” during engine start. Further, the overly simplified secondary electronic ignition is inefficient sometimes resulting in ignition module failures and ignition coil overheating.
Many VW conversions are equipped with simple slide throttle body injectors and experience mixture fluctuation with G loading and fuel level changes.
My biggest concern is the fact that #2 is aggravated by #1.
Required:
In the safest, most efficient, and most approachable way possible:
Balance cylinder to cylinder fuel distribution under all loading conditions.
Control ignition timing and dwell to facilitate easy engine starts and to reduced secondary ignition power consumption.
Control cost wherever possible so the solution flanges well with VW engines.
Solution:
Broadly speaking, EFI and Electronic Ignition with variable dwell and variable timing. For the sake of efficiency, the system will reuse most, or all, of the existing induction and ignition component. For the sake of “approachability”, the system will be as easy to install, easy to tune, and as easy to use as possible. Cost will be contained by using an off the shelf enclosure and a simple user interface that does not require an intelligent control head. Cost will be contained further by the simplicity of the system requiring minimal technical support. ![]()
So that’s it. Lofty goals, but I think achievable.
If you are interested in EFI for the VW engine I suggest you listen to this podcast produced by Jeff Shultz: Episode 58 “SDS EFI for your AeroVee”.
While researching EFI I wasted a lot of money on book titles.
Only one of the books lived up to my expectations. I plug it every chance I get. If you are new to EFI I highly recommend:
The author is an OEM tuner by day and a performance tuner by night. An easy read and mixes theory and practice of engine tuning nicely.
More To Come …
