The oil capacity of the stock engine seems very low to me and I’m wondering if the additional capacity and added surface area of the sump will help with lowering oil temperature.
I’ve never heard of anybody adding one of these extended sumps to an AeroVee. I see a few downsides, the biggest one being weight. Both the weight of the sump and the additional oil. Weight is the enemy on a Sonex! The extra surface area could help cooling, but realize the AeroVee sump lives in a hot area as compared to a VW Bug sump that is hanging in the breeze. The best thing, in my opinion, is adding airflow to the existing sump if you have oil temperature issues:
Wes Ragle went another route, and used a real oil cooler on a full flow system. Also gave him an easy path to getting cabin heat in the airplane:
I seemed to have as much trouble as anybody with oil temperatures but adding a baffle and some fresh air on the stock sump has worked wonders for me. There is a lot of surface area on the stock sump.
I’ve not found the stock 2.75 quart capacity to be a problem. We run our naturally aspirated AeroVee really hard and I’ve been hot-rodding it over the years. Extra capacity would not really improve cooling, it would just take longer to heat up and cool down.
