To Sonex Owners And Pilots (SOAPs lol),
Just curious as to how these aircraft are holding up over time. This month will be 28 years since the big event noted on the Sonex site:
On February 28, 1998 John Monnett lifted-off from Wittman Regional Airport in Oshkosh, WI in a completely new aircraft: Sonex serial number 1, or “SX1.
Myunn will be 14 years old this year with ~400 hours in service. I’ve been very pleased to have had no major airframe or engine issues. Maintenance has been quite routine with tires, brake pads (once with TOB), and oil & filter changes as needed. I did pull a head on the Corvair early on when carbon was preventing a valve from closing but since I’ve learned how to lean it properly and the use of Decalin that concern has vanished. I also replaced the distributor cap and rotor. Oil feed line to the fifth bearing was replaced but again that’s a maintenance issue.
I have the original canopy that last year showed a small crack in the pilots side that was stopped using the hot needle method. I also had to chase an intermittent strobe issue that turned out to be a poor crimp connection that I made.
But all of this is small stuff in all the years she’s been flying both from pavement & grass.
I was reading today about a pilot looking for a spinner for his 55 year old certified airplane and was stunned (seriously stunned) that a replacement spinner was over $7,800.00 (yes that’s correct)!
Somedays I don’t believe we really understand just how blessed we are!
So what’s your journey after the build been like? How long do you think a Sonex airframe will last?
Curious,
