I just picked up an unbuilt pre-owned legacy kit. It came with a “Motor Mount-Standard-VW” and “Universal cowling” (vertical split) which I assume is for the 80hp AeroVee engine. It would be cheaper for me to go with an Aerovee engine since I already have the mount and cowling, but I wonder if that’s really prudent. So my question to all of you who have an Aerovee engine (both non-turbo and turbo), would you do it again? Any regrets? If you were starting over, what engine would you invest in? Thanks.
I’d do it again. But the Jabiru 3300 is really more awesome. Do you like to turn wrenches and tinker?
I also like the vertical split cowling.
I thought to offer my highly biased opinion but I believe it’s well known …
HI Bob,
I believe the Universall cowl was designed to accommodate both the AeroVee and the Jabiru 3300.
Congratulations! There have been literally dozens of aircraft designed around the VW engine. You have, IMHO, picked up one of the best. Detailed dimensions for each and every part are included in the plans.
I’ve built two VW powered aircraft. A legacy Sonex (AeroVee) and a Onex (Hummel). I’d do it again. The main concerns when flying a VW are EGTs and CHTs. If you keep those in check, the more experienced VW pilots have indicated that inexpensive head work every 200 hours or so will keep you flying. As Bryan indicated, there is usually some tinkering involved when flying VWs. I’ve taken that tinkering to the extreme ![]()
Having said that, if someone offered me a Jabiru 3300, a UL Power, or a 100 + HP Rotax for the same price, I’d jump on it. More power is always better ![]()
One thing about the VW, the parts are cheap. I think that will always be an advantage over those motors listed. I think the Corvair parts may also be cheap, Dale could talk about this for sure.
The VW does respond to tinkering. Even without a VeeCU (although I want one) I was able to pull down 130 KIAS at 6000’ the other day, Works out to about 142 kts true. I have as much work into cooling optimization as I do into performance stuff. None of it was hard or expensive, but it takes time and a leap of faith in yourself. So for me it’s fun. There are people who hate the AeroVee and they have their reasons. I am definitely more of a fan of naturally aspirated than I am of the turbo.
If you can’t build light, then skip the AeroVee. Or if you are over 200 lbs and want to bring other adults. If you find yourself wanting a metal baggage compartment with carpet, you will be too heavy. I’ve got a fabric baggage area that adds about 1 lb. Paint is heavy. If you are reasonable on the panel the modern stuff can be both light and low power. Low power is important with only 20A on tap.
As I’ve disclosed before, at 513 hours I’m on my third set of heads. I’ll be able to rebuild the second set and get more time out of them. The first set actually lived a long time, but they are goners. That was part of my learning process with the VW engine.
I have a spare AeroVee. We had been looking for a project to use it on. There was a possible Onex project but my buddy Rusty came to his senses and is keeping it. Then we found a Sonerai and the spare AeroVee will go on that. So in a way I’m doing it again.
Absolutely I would do AeroVee again! Well known, parts are pretty much everywhere, and are a bunch less expensive!
I found the original cowl too tight for my jab 300, second attempt, made a prop-spacer about 5/8" thick and worked out well, but not sure if all old cowls had enough material to cut off the back edge to do that. I made my own prop spacer, but think Prince sells a similar unit if they are still around.
I do not like the vertical split, so cut off the top and bonded the top two pieces together, but left the bottom with its vertical split, thus three pieces. Very quick and easy to remove or re-install.
