I had been building a Waiex and took time off to (a few years) to prep for retirement. Now that I am officially retired I am back to building. A week into getting back to it and it is taking a bit to wrap my head around everything again. And of course I have a question already.
My right wing was done and I am working on my left wing and noticed this: On plan sheet WIX-W11 Wing Substructure; In Detail Section A-A, B-B, and C-C, the plan shows the rivets going through the aft rib flange, spar, forward rib flange, from aft to forward (rivet shop head against the forward rib flange) … except the bottom two rivets which go in from forward to aft.
I do not see the reason why those bottom two rivets need to be oriented opposite of all the others, it does not seem to be a structure thing (shop head being on the side with the thicker material, or anything like that), and It does not seem to a clearance issue either … and the kicker …
On my right wing (complete and buttoned up), they are in the same way as all the others - from aft to forward (!!!)
