Wingtip Light Placement
Posted: Thu Aug 31, 2017 4:27 pm
by Spaceman
What’s up guys, I’m just about done with my second wing, and getting ready to fit the wintip next. I noticed on another thread the other day (now I can’t find it of course), someone mentioned they had issues getting their plane inspected because their wingtip lights weren’t visible from above or something like that.
I already did the wingtip on my other wing, and I hadn’t even thought about visibility from the top. I just located the light right in the middle of the fiberglass wingtip. I have the little gaugepod fairings that push the lights out a little, but I still don’t think they’ll be visible from above. I’ll post a picture when I get home from work.
Is it really a requirement to have the lights visible from above? I didn’t think lights were really even required in the first place, I was just doing it for extra safety!
If I do need lights visible from above, I guess my options would be to redo my first wingtip completely, relocate the light and patch the hole I cut in the fiberglass, or just leave it and add a third light on top of the fuselage or something!
Re: Wingtip Light Placement
Posted: Thu Aug 31, 2017 7:27 pm
by Spaceman
Here are a couple pictures of the RH wingtip, which is the one I did a few months ago. The light isn’t installed on the fairing here, but you can see it still won’t really stick out past the top edge of the wing!
Posted: Thu Aug 31, 2017 10:05 pm
by kevinh
Yah - check the FARs for the angle of view rules for the wingtip lights. It is something like 30 (45? - can’t remember) deg above and below and the white must be viewable also above and below and x (60?) deg from the tail center line.
Mounting the lights in the middle of a sonex wingtip won’t cut it. For my wingtips I will be mounting the lights at the top edge with a little 3d printed fairing/mount.
Posted: Sun Sep 03, 2017 9:22 pm
by Spaceman
Yeah I think you’re right. I just did my other wingtip today, and I had to put the light mount all the way at the top/outboard edge for it to be visible from above. I’ll post some pictures later. Now I’ll have to go back and change the first one!!
Posted: Sun Sep 03, 2017 10:11 pm
These should help:
https://www.whelen.com/pb/Aviation/Syst … ystems.pdf
https://www.faa.gov/documentLibrary/med … 20-30B.pdf
Posted: Wed Sep 06, 2017 10:47 pm
by Spaceman
Thanks for the info Mike!
I forgot to come back and post pictures. Here’s how I did my left wing (the second wing I built):
This allows the light to peek out just past the top of the wing, so I think it’ll be visible up to 90° above. This view is from the floor looking up, since the wing was upside down on the table:
To fix the right wingtip, I cut a new hole behind the updated light location first, so I could reach the back of the old hole through it. I used a piece of waxed aluminum plate as a backer on the outside, and then applied fiberglass on the inside of the old hole. I used a little fiberglass repair kit from Autozone, and I was able to get 12 layers out of the piece of fabric it came with. I think it turned out pretty sturdy, but it’ll need some filling and sanding later. If I decide I really hate it I can fit a whole new wingtip later on, but this cost me $20 and like an hour versus $100+ and several hours to fit a new wingtip!
Posted: Wed Sep 06, 2017 10:48 pm
by Spaceman
Also, I didn’t really mean to post this in the Waiex forum since it isn’t Waiex specific… If any mods want to move this thread somewhere more appropriate that’s fine with me!
