When to polish?
When to polish?
Posted: Sat Apr 13, 2024 2:06 pm
by gregsonex
A few posts mention it’s easiest to polish sheets before riveting at the beginning of the build. Curious what most folks recommend since it seems you don’t think about polish/paint until you’re getting to the finish line. I was planning to paint the fiberglass components after completion and then use nuvite to polish the aluminum at the end of the build. Any advice or recommendations?
Re: When to polish?
Posted: Sat Apr 13, 2024 4:25 pm
Hi Greg,
I’ve done it once each way. If you plan to polish, it’s much better to do the polish on flat sheets. If you wait, the aluminum will tend to stretch just a little between supports/ribs/etc. Also, on flat sheets, placed on a flat table, you can apply all the pressure you want without worrying about buckling anything.
Ref. https://sonexbuilders.net/viewtopic.php?f=30&t=704&start=20#p33481
YMMV,
Re: When to polish?
Posted: Sat Apr 13, 2024 5:59 pm
Definitely before riveting. Sacrifice a folding table to the Polishing Gods.
Re: When to polish?
Posted: Mon Apr 15, 2024 9:54 am
by Tnhelm
A polished aircraft is generally beautiful on the ground although requires more detailing work to keep it that way. Painted is much easier to maintain, although heavier, (+15 lbs on my Onex).
I was in the pattern one time with another polished Sonex doing multiple circuits. I found that polished Sonex nearly impossible to spot, blending in with the surroundings. (Think mirrored surfaces)
For that and other reasons, my preference is a nice paint scheme.
Tnhelm
OneX 0137
Re: When to polish?
Posted: Mon Apr 15, 2024 10:30 am
After a year and a half of flying, Adam did some post-build polishing for the first time. So we have about 230 hours of flying and 5 hours of polishing. Doesn’t seem too bad.
Also, weight is the enemy.
Re: When to polish?
Posted: Mon Apr 15, 2024 1:45 pm
Definitely easier and faster to polish flat sheets. When solidly supported on a flat table, more pressure can safely be applied and that speeds up the polishing with the first two and most difficult grades of polish. The warning about not using too much pressure is mostly about not causing ribs and other components to be visible due to bending of the sheets when working on a finished plane.
Re: When to polish?
Posted: Tue Apr 16, 2024 5:14 pm
by gregsonex
Thanks for all the helpful thoughts on this!
Re: When to polish?
Posted: Tue Apr 16, 2024 8:39 pm
DCASonex wrote:Definitely easier and faster to polish flat sheets. When solidly supported on a flat table, more pressure can safely be applied and that speeds up the polishing with the first two and most difficult grades of polish. The warning about not using too much pressure is mostly about not causing ribs and other components to be visible due to bending of the sheets when working on a finished plane.
Seconded. The great thing about polishing on a table is you can really bear into the metal and get that mill finish off. I did polish the ruddervators when they were built and it was a lot more difficult to do a good job.
Re: When to polish?
Posted: Tue Apr 16, 2024 9:10 pm
I did the initial polishing when the sheets were flat. You do have to be very careful with the direction of the polishing pad. You want it to be moving away from edges and corners. If it’s turning toward the edges, and especially corners (!!) you can instantly bend the corner with the pad if/when it catches. I only did the next level of polishing after I was flying. I polish every couple of years, in different areas. Wings one year, tail another year, fuselage another. It’s too much work to do it all :slight_smile:
Re: When to polish?
Posted: Thu Apr 18, 2024 7:26 pm
I polished strictly due to weight. Mileage varies, but on a classic Sonex, 25 lbs seems to be the most common number reported when weighing the aircraft before and after. With an AeroVee, unless you’re flying solo, weight is a very big consideration. Mine weighed in at 653 lbs at completion, and I only painted the fiberglass parts. Another 20+ lbs would have really cramped my mission parameters. No regrets on my side. I’ve never had a mirror finish, and really never wanted that degree of polish.
I love the idea of polishing before riveting, a couple of questions
1- what would be the best flow from experience, polish → drill/debur → rivet, or drill/debur → polish → rivet? i assume polishing after debur will be cleaner but can it affect the dimensions after drilling?
2- so what do you do for the rivets, any polishing or post processing?
Drill, deburr, polish. The rivets will be fine and will polish up when you continue to polish.
Hi Guys,
I’m getting ready to bring my Onex home for EFI installation. While I have it at home, I would like to freshen up the polish job. In the past I’ve used Nuvite with wool pads.
Question: Is there a better/gentler pad for polish refresh than coarse wool pads when using Nuvite S.
Or…, is there a better polish than Nuvite for repolishing.
Whatever I use, it needs to be powered. I don’t want to wear out what cartilage I have left :wink:
The instructions from Nuvite for 6061-T6 indicate using the tufted wool pad for F9 and C, then using their towels over a dual head cyclo polisher with S. I think for a repolish they talk about using C and S.
Although the technique specified for using S always gets rid of the swirl marks from previous steps, I have been getting mixed results with the S grade. Sometimes it seems to leave a slight haze - almost like a very slight ‘milky’ finish. I don’t know if it is my technique - too much pressure, or maybe to much polish, or maybe the polishing with the previous grades wasn’t good enough - I just don’t know.
My technique is to set a goal to polish before Oshkosh. When that goes zooming by, I move the goal to Oshkosh next year.
Yea, it’s an art. There has to be an easy way to get rid of light oxidation. I just have to find it.
I’ve tried that technique for the last several years with worse results each time. :wink:
You are probably just using the wrong metrics. Mine revolve around hours flown. So far, good results!
