What is your XENOS registered as?
Posted: Tue Jan 31, 2023 8:21 am
This arose during a discussion with a USA FAA Safety Inspector who is also a keen glider pilot. The issue potentially could catch out SECOND owners of XENOS who miss the distinction during purchase.
If the Xenos is registered as a “Fixed Wing Single Engine” you cannot fly it on a Private Pilot GLIDER certificate. The aircraft has been registered as a Single Engine plane requiring a PPL or Sport Pilot (if the plane qualifies for LSA) rating.
If registered as a GLIDER – you cannot fly it on a PPL or Sport Pilot rating – you need a Glider rating.
To qualify to self-launch a Xenos registered as a GLIDER you have to have a Private Pilot Glider WITH a “Self Launch” endorsement – which requires training and then an endorsement for the type of self launch you are using.
It was also pointed out that the current - AC 61-94 - Pilot Transition Course for Self Launching or Powered Sailplanes (Motorgliders) - is significantly out of date and does not meet the way training or endorsements are currently issued!
Re: What is your XENOS registered as?
Posted: Tue Jan 31, 2023 9:31 am
Mine is registered as SEL aircraft because I wanted to get the paperwork completed in a timely manner. It would be a struggle to get the Orlando FSDO to make it a glider; at least that is my impression. With Basicmed, it is a mute point for me now. I can fly with Basicmed and do not ever see the need to drop med. certificate & fly with a drivers license. Yes, I have a glider rating but not self launch endorsement, nor do I need one.
Xenos 0057 68 hr (engine,) about 8 hrs solar power only
CAMit 3300 (yes, it doesn’t use much runway and climbs 1600 fpm)
Posted: Tue Jan 31, 2023 11:04 am
Graeme,
" which requires training and then an endorsement for the type of self launch you are using."
What types of self launch are they referring to? Are they making new distinctions as far as where the engine is mounted?
Posted: Tue Jan 31, 2023 2:55 pm
bvolcko38 wrote:Graeme,
As I THINK I understood it (and I am not a Glider guy) - There are three types of launch endorsements. Airtow, Ground (winch), Motorglider.
I am NOT qualified to comment on this properly. But as I think it was explained to me - A Self Launch can include a winch (if the pilot operates it) or your own engine (motorglider). And I was told there was a distinction in the training and endorsement.
The bigger issue is PPL’s flying Gliders and PPG’s flying SEL’s. It was explained to me that this is not just a paper distinction. The thought being that a XENOS with a bigger engine registered as an SEL being flown by a PPG - the PPG might not have all experience/training required.
If in doubt talk to the FSDO. You will get chapter and verse there. (well usually!).
Posted: Tue Jan 31, 2023 4:11 pm
I’ve never heard of a self-launch winch. I’ve also never launched from a winch and only have an aerotow endorsement. I think the motor glider self-launch endorsement is the one you need.
Besides launching, training covers failed restarts. Depending on the motorglider that can be a high drag configuration as compared to soaring mode.
