Voltage Regulators with Higher Output (EarthX Battery)
Posted: Mon Nov 23, 2020 4:54 pm
The permanent magnet (PM) alternators used in the AeroVee and Jabiru engines create an alternating current (AC) output that varies as a function of RPM. PM alternators are paired with a voltage regulator/rectifier (VR) that converts the AC output to direct current (DC) - the “rectify” function, and then cap (e.g “regulate”) the voltage at a set point of around 13.5 volts (this varies a bit from unit to unit). At idle speeds the output voltage is typically lower than battery bus voltage and the battery receives no useful charging current to recharge. At high rpm the alternator is making plenty of power and the output stabilizes at the regulator set point. This all works fine for traditional lead-acid batteries, but the output voltage is actually too low for Odyssey brand batteries as well as EarthX lithium batteries. Odyssey and EarthX batteries require a charging voltage of around 14.5-14.8 volts (edit: 13.9-14.7 as per the EarthX/Odyssey manuals), and the solution to keeping them fully recharged is to raise the regulator output set point to provide a higher charging voltage.
The stock AeroVee and Jabiru VRs are not user-adjustable for output voltage. However, there are two options that have been used as replacements and both work well. The Caltric brand VR model 11-2 (PN LD1293111RV) is set to a higher output set-point and is pretty much a drop-in replacement for the stock VRs. The newest option is the B&C AVC1 Voltage Regulator. This is a purpose-built aviation regulator, with a massive heat sink, over-voltage protection and an adjustable set point.
Either of these solutions will provide improved performance of your electrical system when using an Odyssey or EarthX battery, and are simple to use or retrofit to a flying airplane. Experience has shown that they key to long VR life is good cooling, so ensure you mount the VR to a solid surface that can serve as a heat sink and provide airflow through either natural circulation or a blast tube.
Links:
https://www.amazon.com/Caltric-Regulator-Rectifier-DEERE-AM101406/dp/B008HTBHUI
https://bandc.com/product/avc1-advanced … lation-kit
For more reading on the subject, see the following threads:
https://www.sonexbuilders.net/viewtopic.php?f=8&t=5076
https://www.sonexbuilders.net/viewtopic.php?f=21&t=5581
Re: Voltage Regulators with Higher Output (EarthX Battery)
Posted: Mon Nov 23, 2020 8:49 pm
I recently installed an EarthX battery in my Turbo Aerovee with the stock alternator/voltage regulator setup. I have a current sensor, and so far I haven’t noticed any difference in the in-flight charging current between my old lead-acid battery and the EarthX. In either case, I’m getting 10-11 amps flowing into my battery during climb out, which slowly returns back to zero after 15-20 minutes. Admittedly I didn’t also take note of the voltage, but it seems to me that my alternator/VR is having no trouble recharging the EarthX, at least after it has been discharged from engine start/taxi.
Disclaimer: I’ve used a battery tender after each flight. So if the EarthX was returning from each flight with a lower charge than the last I wouldn’t know it yet, I just know that my current sensor is showing a good initial recharge and I haven’t completely drained the battery yet.
Posted: Tue Nov 24, 2020 10:18 am
Ryan,
I would be very interesting to see the state of charge in your battery at the end of a flight. With the very flat voltage drop curve that Lithium provides, the voltage only varies by a half a volt from mostly-charged to mostly-discharged (see EarthX graph below).
A great way to determine the exact state of charge would be to run a controlled discharge test and record the time the battery can supply power to your panel before the voltage drops to the cutoff voltage. The battery manual (link below) recommends 12.6 volts as the cutoff voltage for discharging, and page 11 shows the expected discharge profile. If you ran this test with a freshly-charged battery you’ll have a baseline to establish performance, then you can easily run the test in the future to determine either battery health or charge state. It would also be good to know how long the battery will power your panel in an alternator-out situation.
EarthX Battery Manual: https://earthxbatteries.com/wp-content/ … 17_Y-1.pdf
EarthX Battery Discharge Curve: https://earthxbatteries.com/wp-content/ … charge.jpg
Posted: Sat Jan 02, 2021 6:08 pm
sonex1374 wrote:https://www.amazon.com/Caltric-Regulator-Rectifier-DEERE-AM101406/dp/B008HTBHUI
I figured I’d give this unit a try. What I received looks a bit different, and has NO markings at the tabs. It has the same number of tabs, and the left one is offset from the others, like the one on Amazon, so I’ll assume the identifiers are the same.
Question: which of the 3 AeroVee wires goes on which tab?
Posted: Sat Jan 02, 2021 7:29 pm
by lutorm
It seems a solution to the poor charging at idle would be to have a regulator that functions as a buck/boost regulator so that it always provides 14.x volts prior regardless of whether the rectified generator output is above or below that value. It wouldn’t be a very complicated circuit, but I’ve never heard of such a thing being used. Anyone know why?
Posted: Sat Jan 02, 2021 11:17 pm
mike.smith wrote:Question: which of the 3 AeroVee wires goes on which tab?
Mike,
The two wires coming from the AeroVee alternator coil attach to the terminals labeled “AC”, then the “B+” terminal connects to your battery/capacitor/battery bus. You can ignore the “L” (low-voltage light) and “IGW” (voltage sense) terminals. The terminal identification is not marked on the unit itself, but follows the picture below. There are several similar units sold by different companies that all use the same terminal functions (they are patterned after a John Deere voltage regulator). The grounding is done through the case, so either use a ground wire on a mounting bolt or attach the regulator to an airframe-grounded component.
Posted: Sun Jan 03, 2021 12:15 am
Mike,
Thanks, Jeff!
Posted: Sun Jan 03, 2021 4:54 pm
Think AeroVee-voltage regulator as supplied by Sonex (Onan unit I think)-and an EarthX battery.
Till this morning, the voltage would always stabilize at or slightly above 14.1V after 10-15 of flight time. This has been a constant for 18.5hrs.
This morning, all appeared normal with the voltage dropping into the high 12volt range during warm-up and taxi as usual. After the prescribed .2 hours of level flight, the voltage never rose above 13.1. The voltage would oscillate between 12.9v and 13.1v at 5-7 hippopotamus intervals. This went on till I landed 1.1 hours later.
My electrical load consists of a master contactor-red secondary coils-a half an amps worth of engine instruments-and a Garmin G5.
Is it possible to get this kind of partial failure with a voltage regulator, or might something else be brewing?
Searching for my “HeathkIt” instructions here @Area 51%.
Posted: Mon Jan 04, 2021 2:26 am
by pilotyoung
I bought a John Deer one from Amazon that I used with my Rotax 912 ULS for a few months. It worked fine. I replaced it because I wanted one that had build in over voltage protection. So I put a Silent Hetik to use with my Rotax.
But the John Deer one worked fine with the Rotax and if you want it, I will give it to you, just pay for shipping. Pm me if you want it or your can call me at 295 531 9959.
John
Posted: Mon Jan 04, 2021 12:07 pm
Mike,
Thanks Jeff,
This information is very timely. My 3 year old EarthX began sending out BMS error warnings a few months ago. The BMS warning means either a) the cells are not charging at an uniform rate, or b) the cells are not discharging at at uniform rate. This ususally happened about 20-30 minutes into the flight. Therefore, I think it is a problem with uneven charging.
I’ll replace the regulator to see if it corrects the problem.
Posted: Tue Jan 05, 2021 12:59 am
sonex1374 wrote:You can ignore the “L” (low-voltage light) and “IGW” (voltage sense) terminals.
Mike,
I need to clarify my earlier statement - the “IGN” (Voltage Sense) terminal should probably be connected to either the battery, capacitor or battery bus (just like the “B+” terminal). This is the way the stock Jabiru voltage regulator is wired, and this regulator should also be wired this way. The Voltage Sense wire controls the output of the regulator - when the voltage on that terminal is low it ramps up the output voltage to start charging the battery, and when the battery is fully charged that terminal sees the higher voltage and the output ramps down. You can connect this terminal directly to the battery for the best results, but really anyplace on the battery bus is fine also. I overlooked this detail in my original response while concentrating on the AeroVee’s three wires from the stock voltage regulator. Sorry for the confusion.
Posted: Tue Jan 05, 2021 10:24 am
Mike,
Correct me if I’m wrong, Jeff, but the “voltage sense wire” draws current even while shut down, if not disconnected from the battery. So to avoid running the battery down while parked, the best place to connect this wire is where it will be disconnected from the battery at shut down. Mine is connected to the output post of the master solenoid but other “switched” locations work as well.
Posted: Tue Jan 05, 2021 11:25 am
by pilotyoung
I could be wrong also but my understanding is the voltage sense wire also turns the VR on. When there is no voltage on that terminal, the VR is off and doesn’t let the battery charge. That is the way the generic John Deere VR worked that I put on my RV-12. The original VR also worked the same way. The original VR was from an Italian motor cycle I just can’t remember the name right now.
Posted: Tue Jan 05, 2021 4:39 pm
builderflyer wrote:Correct me if I’m wrong, Jeff, but the “voltage sense wire” draws current even while shut down, if not disconnected from the battery. So to avoid running the battery down while parked, the best place to connect this wire is where it will be disconnected from the battery at shut down. Mine is connected to the output post of the master solenoid but other “switched” locations work as well.
I’ve had mine wired directly to the battery for 6 years and it’s never run down the battery even a little. So it must not draw any power when it senses nothing going on.
Posted: Tue Jan 05, 2021 9:56 pm
Art,
I’m not sure if the voltage sense wire draws battery power all the time. I suppose is would be easy to test and find out, but I’ve never done it. Like you, I also connect my voltage sense wire to the switched side of the battery bus (at the big capacitor, actually). This prevents any sort of small parasitic drain on the battery (if there is one). The only reason I recommended connecting the sense wire directly to the battery is that is how Jabiru recommends it in their install manual. I didn’t follow this myself, but that’s their recommendation. This might also give you better charging performance without any strange influences from the bus (if that’s even a thing).
pilotyoung wrote:I could be wrong also but my understanding is the voltage sense wire also turns the VR on. When there is no voltage on that terminal, the VR is off and doesn’t let the battery charge.
John,
I think you are correct. If the sense wire doesn’t detect any voltage then the regulator will not “turn on” and provide charging output. I’ll have to test this as well.
mike.smith wrote:I’ve had mine wired directly to the battery for 6 years and it’s never run down the battery even a little. So it must not draw any power when it senses nothing going on.
Mike,
The standard 3-terminal AeroVee voltage regulator doesn’t use a discrete voltage sense wire. I think it just output full-bore whenever the PM alternator is sending it AC current. In any case, it’s pretty simple to add a voltage sense wire connection when retrofitting a new voltage regulator to the AeroVee. Simply run a new wire from that terminal to wherever is convenient on the battery bus and you’re good to go.
Posted: Wed Jan 06, 2021 10:26 am
Mike, we may be talking about different regulators as I know we have different engines. When I purchased my now 20 year old Jabiru 3300 engine new in 2001 it came with the VR that is still going strong to this day. I’ve never put a milliammeter on it but when I had the sense wire connected directly to the battery, the battery would discharge in a fairly short time. When the sense wire was “switched”, the battery would remain charged indefinitely. This phenomenon may have been discussed on the Jabiru engines forum years ago. I doubt I was the only one who made this observation at the time.
Posted: Mon Feb 01, 2021 3:18 pm
Hi, all:
I tried the VR Jeff suggested, with my AeroVee and EarthX battery. It did not work well. It provided much less charge, and worst of all it made my tachometer go crazy. The tach reading is taken from pulses from the VR. With the secondary ignition ON the tach was all over the map, and would generally not read anything below 1600 rpm. Wih the secondary OFF, the tach read from 0 to 300 rpm. I flew twice around the pattern, with full stop landings, to verify I got the same readings, which I did. So I took off the VR and put on the original Sonex one. Since the wonky readings happened at both low and high rpm, I don’t think it’s because of low alternator output.
Posted: Mon Sep 12, 2022 1:49 pm
I cant find the higher output Caltric VR model 11-2 suggested by JS. Does anyone know where its available or perhaps suggest another?
peter
Posted: Tue Feb 28, 2023 10:02 pm
by tps8903
Edit***** Do Not Use. Full Wave Rectifier. Fried my Stator.
Link Removed
Just purchased this Rectifier regulator. Seems to be a common unit on other homebuilt airplanes based on comments at Rivival Cycles. It’s a MOSFET controlled REC/REG set to 14 +/-0.2V simple wiring with two Alt wires, a positive and negative lead for the battery. Can be installed on the engine side and comes with a 1 year warranty. I’ll post an update.
The Sonex VR that I have stabilizes ar 13.2V. So my EarthX is not draining because I only use about 12amp on the high end.
Posted: Tue Feb 28, 2023 11:16 pm
I must have gotten lucky. My battery shows 13.2V during runup and 14.5-14.6 in cruise. Stock VR that came with my Aerovee kit.
I have pretty minimal electric loads. I turn off the secondary ignition out of the pattern.
Posted: Tue Feb 28, 2023 11:58 pm
by tps8903
Bryan Cotton wrote:I must have gotten lucky. My battery shows 13.2V during runup and 14.5-14.6 in cruise. Stock VR that came with my Aerovee kit.
I thought about this after I ordered the other one. I’m wondering if the load is dragging the voltage down. I guess tomorrow I’ll have to find out. I’ll unload and turn off the lights and electric Ignition and see what it does. I think it’s low regardless, I usually start with 12.8V and then It stabilizes at 13.2V in cruise.
Posted: Wed Mar 01, 2023 1:27 am
I usually just run my strobes in cruise. Nav lights if it’s close to dark. Whelen Orion 600s, not much draw.
I run my wig-wags in the pattern. Consumes 0.65 a.
Radio and transponder are on. Low draw except transmit.
I have a mechanical master switch. Saves an amp and some weight.
My fuel tank camera and light draw nearly nothing but I leave them off except when I want to check fuel.
My Braüniger Alpha MFD draws milliamps. If power fails it continues to run off a 9V battery. Cool.
I have a turn coordinator but I leave it off usually.
With only 20A to work with, conservation is good.
Posted: Tue Mar 07, 2023 5:50 pm
by tps8903
So the VR I installed was full wave, seems like that was a bad idea. Diagnosing the damage now…sigh…
Posted: Wed Sep 20, 2023 3:05 pm
Cross posted from another thread, but the info belongs here.
Bryan,
Thank you for contacting us with that question. At the present time, we do not have a voltage regulator that we consider compatible with the AeroVee alternator. We have a design in the development process that should be suitable, however. I have not been given a release date at this point, but if all goes well with tests of the prototypes, it may be available within the next 6 months or so.
We appreciate your checking with us. Please let me know if you have any other questions.
Kind Regards,
“TJ” Jenkins
B&C Specialty Products
123 E. 4th Street
Newton, KS 67114 USA
Voice: 316-283-8000
Posted: Sun Oct 01, 2023 1:03 pm
Per a recommendation from Dale, I installed a genuine John Deere MIA881279 voltage regulator. This is made in Japan and rated at 20A. It was pretty much a bolt in replacement, but I had to add a wire to the VR enable yellow wire. I did see 14.5V on a ground run so far. I spent $107 buying from eBay.
daleandee wrote:
Wires are as follows:
blue wires (2) are AC voltage from the PMA
the red wire (1) is charging voltage to the battery
black wire (1) is ground
yellow wire (1) is the sense wire & turns on the regulator
green wire (1) idiot light - generally not used
3.0 Corvair/Tailwheel
http://www.n56ml.com/corvair/dynamo.html
So far I have one ground run. At 3000 RPM, I am getting 14.5V with all loads off, and then all loads on. Looks promising.
Posted: Sun Oct 01, 2023 2:30 pm
Bryan … good deal! Just a few thoughts,
I cut the original plug off the regulator and used some high quality faston terminals as some folks complained about the original connectors not holding up very well.
Also on the other thread you noted that you spaced it away from the firewall. I did that initally but someone smarter than me suggested that I mount it to the firewall and recommended to use heat sink compound so that the regulator could use the firewall as a heat sink. BTW, I have a small blast tube on mine with a a small cover that directs the air through the fins.
As an aside, some even suggest to mount the fins vertically so the rising heat can better disipate. How much difference any of this really makes is unknown to me. As they say … you pay your money and takes your chances.
Any idea whether you can make the KJZP fly-in (if it happens of course)?
Posted: Sun Oct 01, 2023 3:32 pm
daleandee wrote:Bryan … good deal! Just a few thoughts,
Dale,
I’m working on a blast tube installation. I’ll post pictures when I complete it. Probably not until I have the cowl off again. I’m thinking the blast tube will remove a lot more heat than the firewall. I’m also making a cooling tin for it, so the cold air goes outward over the cooling fins. It will be cool.
I’m not going to be able to make the KJZP fly-in, unfortunately. Only 3 days of vacation left this year and even less spousal support. Maybe some year!
Posted: Mon Oct 02, 2023 11:20 pm
So one of my original female spade connectors melted sometime when Adam was flying yesterday. I replaced it with a better looking female spade terminal that we bought at Autozone tonight. It looks like faston terminals are still spade terminals, but higher quality? Was the John Deere male spades the issue or the Sonex side?
We did a ground run and seem to be charging again. We were going to fly down to DeKalb at dusk, about 26 nm away. But we never left the pattern as I could see it was not charging. My other crimp must have gone bad.
Posted: Tue Oct 03, 2023 5:33 am
by Panther16
Aircraft electrical connections are no place for auto zone, especially the hi current alternator leads. Use faston stud type terminals and bolt together or use a stud type terminal strip. If bolting together cover with shrink tubing but do not shrink to allow for cooling of the joint.
Posted: Tue Oct 03, 2023 7:11 am
Saw a report here many years ago of someone who had a VR burn through the thin SS firewall, and with the fuel tank right behind that, I mounted mine on a slightly heavier piece of SS, hat shaped for about 1/2" clearance. It is big enough to hold a small relay and a filter capacitor. Best cooling of the VR will be with its fins oriented vertically.
Posted: Tue Oct 03, 2023 10:03 am
Panther16 wrote:Aircraft electrical connections are no place for auto zone, especially the hi current alternator leads. Use faston stud type terminals and bolt together or use a stud type terminal strip. If bolting together cover with shrink tubing but do not shrink to allow for cooling of the joint.
Agreed. This is temporary to see if the John Deere regulator is working. I’m going to switch to a 10ga Deans connector for the stator. I hate spade terminals.
Posted: Tue Oct 03, 2023 11:13 am
I wouldn’t use connectors fro Autozone. I got my spade connectors from B&C…AMP spade connectors and a good ratcheting crimper
Posted: Tue Oct 03, 2023 12:07 pm
DCASonex wrote:Saw a report here many years ago of someone who had a VR burn through the thin SS firewall, and with the fuel tank right behind that, I mounted mine on a slightly heavier piece of SS, hat shaped for about 1/2" clearance. It is big enough to hold a small relay and a filter capacitor. Best cooling of the VR will be with its fins oriented vertically.
I remember seeing a similar photo (maybe the one you’re referring to) of a Jabiru 3300 regulator that caught fire and seriously burned the regulator and the firewall. This is the reason I use a dynamo relay with an OV protection circuit. The relay should be wired into one of the AC lines from the generator and not the 12 volt line to the battery. The reason being that if the relay is in the output line of the regulator when an overvoltage event occurs then you have no way to to shut off the power to the regulator itself. Putting the relay in one of the AC lines fixes this problem.
I agree with others about using high quality connectors and also with those saying to use a quality ratcheting crimper. I’m still using spade connectors but have seriously considered changing them over to a terminal stud strip.
Posted: Tue Oct 03, 2023 11:13 pm
Follow up: We flew for 0.9 hours, with pretty much everything on except the secondary. We exceeded 14V pretty quickly, like a minute or two. By 5 or 6 minutes we had stabilized around 14.5-14.6V. So, it seems good.
I made this cooling tin:
side view VR cooling tin.png (578.87 KiB) Viewed 4585 times
inside view VR cooling tin.png (546.74 KiB) Viewed 4585 times
Here it is on the regulator. Air from the blast tube goes in the middle, then it has to flow out left and right past the fins to escape.
cooling tin on VR.png (533.33 KiB) Viewed 4585 times
I used a silicon 1/2" hose. I used a 1/2" aluminum tube flared at one end for both hose ends.
hose routing.png (779.06 KiB) Viewed 4585 times
So stealing a little air from the engine plenum to cool the VR.
Posted: Wed Oct 11, 2023 7:01 am
Hi Brian,
My Son made me a Voltage Regulator cooling shroud, much like yours, except he used CAD & printed it out on a 3D printer - very nice.
My Regulator is on the cockpit side of the firewall & gets its cooling air from a T piece (also printed) in one of the cabin air inlets.
I have not flown with this yet but hope to finalise all mods and be flying within a week - 10 days
I would send photos but unfortunately have tried in the past, without success.
