Torque Wrench
I’m planning on building a high wing and currently putting together my workshop.
What torque wrench do people recommend?
The low end of the range seems to be too high for most of the wrenches I’ve looked at.
For most airframe stuff, an inch - pound torque wrench is the best. Mine is a click type and goes from 25-240 in-lb. I’ve also got a beam type that goes a little higher, and a click type that goes from 25 ft-lbs to 150 ft-lbs. Finally I bought a 250 ft-lb wrench for the VW gland nut.
The purpose of the hobby is to buy tools.
25 in-lb is the high end for an AN3 with the usual nut. AN4 high end is typically 70 in-lb. It’s surprisingly low. It’s been joked that no nut on an aircraft has ever been under-torqued :slight_smile:
I use a beam type, inch lbs. torque wrench. Years ago I had one of the cheaper click type and learned quickly that using that one was a mistake. If you’re going with a click type torque wrench spend the funds for a really good one.
I like the beam type as they are consistent and hold calibration very well. The other thing is … learning how to properly hold and read the beam type. It’s not difficult but there is a floating handle on it and the readings need to be taken from a straight on view of the scale.
I used to believe I had calibrated hands but in one of my training sessions we were challenged to set certain torque values by hand and then test them with a torque wrench. Almost every time, we all would over torque the fasteners …
FWIW,
Thanks all!
I’m just getting started and seeing that this is 1000% true :slight_smile:
More and more often I am applying the ‘buy once, cry once’ methodology. Cheap and inexpensive tools are easier to find than high quality, higher priced tools, but the satisfaction of better performance, lower failure rates, and higher confidence in the final output can sometimes totally justify buying the good one first instead of second or third.
Opinions are like several bodily parts, where we all have one?
There are accuracy tests you can look up on the harbor freight torque wrenches. In their middle range they are usually accurate within 1 to 2% and usually never off more than 4%. AI tells me 4% is the ISO standard for calibration for click type. A 1/4” harbor freight inch lb is what I have used so far. Pretty good for 20$
I like the click type. You can be eyes free. Beam type can’t be beat for modern torque to yield fasteners, though I think TTY fasteners are an evil idea.
I have several torque wrenches from cheap to slightly expensive (came with callibration certificate).
All have their place.
My best purchase would be the little electric digital ones (I have two covering diffrent ranges). They have an auditory signal for when preset torque achived.
Periodically I check them all for accuracy - I don’t mind a “known” inaccuracy, as it’s easy to adjust for it
While I subscribe to any excuse to purchase tools, I try to maintaine some semblance of cost effect. It’s far too easy to be persuaded that the expensive tool , that you will only use once every 5 years, is the way to go, when a cheaper one may fit your requirements just as well. :smiling_face_with_horns:
Anyone else calibrate their torque wrenches? I use a little fish scale and a piece of string taped at a measured point on the handle to make sure it reads properly. I verify about every year or so. It’s a click type (which I prefer).
Veeery nice!!! :smiling_face_with_horns:
