Tires/Gear Leg/Toe In
Posted: Sun Nov 19, 2023 6:00 pm
by tps8903
I burned through a set of stock tires in 70 hrs, with 2/3 of the landings being on turf. One tire blew out on me while taxiing today.
I took the opportunity to upsize to 5x5.00, because I wanted to, and also my hand was forced because that’s all the FBO had in stock.
When I got back while looking at the plane I felt like the left main gear might have a bend in it, and that might be causing alignment issues? I’m going to pull it off and check it against a straight edge this week. Does anyone have advice for straightening a main gear with a press that has done it?
Once that’s done I’m going to have another look at the toe in…The plane kit had it set when I bought it, so it was one of the tasks I didn’t have to do during the build. Advice is welcome.
I am considering using grease plates to get the toe in correct, I may have to up drill the axels to move them on the current gear. Task #1 however is making sure they are not bent.
Re: Tires/Gear Leg/Toe In
Posted: Sun Nov 19, 2023 6:14 pm
We are about to replace the tires for the second time at 185 hours or so. We had a blowout on the first set. I suspect alignment and plan to measure it carefully when ballasted up. I was going to put steel rods under a steel plate to let the gear spread out, same idea as a grease plate. No advice yet, it’s going to be a winter project.
Posted: Sun Nov 19, 2023 8:02 pm
by tps8903
Bryan Cotton wrote:We are about to replace the tires for the second time at 185 hours or so. We had a blowout on the first set. I suspect alignment and plan to measure it carefully when ballasted up. I was going to put steel rods under a steel plate to let the gear spread out, same idea as a grease plate. No advice yet, it’s going to be a winter project.
Roger.
I’m gonna haul the legs off this week and check to see if they are bent. If they are ill bend them back, maybe a touch the opposite way with a 12 ton pipe bender.
Then I’ll throw them on grease plates and see how they look.
I suspect my high landing speed when the plane was new and resulting excessive braking didn’t help time wear. I’m gonna leave the pants off u til I figure this out
Posted: Mon Nov 20, 2023 9:18 am
What tires are you running? What tire blew out?
Posted: Mon Nov 20, 2023 9:30 am
bvolcko38 wrote:What tires are you running? What tire blew out?
Not sure if you are asking Chris, me, or both. Cheng Shin, right tire. We had let it get too worn and it failed during taxi.
Posted: Mon Nov 20, 2023 10:00 am
by tps8903
Cheng Sing tires. Pilot side. Same, blew out during taxi. Both were worn equally poorly however.
Posted: Mon Nov 20, 2023 10:53 am
tps8903 wrote:When I got back while looking at the plane I felt like the left main gear might have a bend in it, and that might be causing alignment issues? I’m going to pull it off and check it against a straight edge this week. Does anyone have advice for straightening a main gear with a press that has done it?
The factory prototype Xenos had it’s gear legs bent pretty badly here in Crystal River a couple of years ago. The owner has a friend with a press and he straightened the legs with admirable results.
I can put you in touch with him if you like.
Posted: Mon Nov 20, 2023 10:58 am
I’ll confess my flat was pilot induced. It’s hard to see the tires with the wheel pants. We wore a hole which exposed the tube. I was a little shocked how quickly they wore but now I know!
Posted: Mon Nov 20, 2023 2:21 pm
by tps8903
So an update. I purchased a rolling chasis when I acquired this kit. I thought I checked everything over when I bought it. Indeed I found 3 relatively important things when I went over the airframe. It should be mentioned the previous builder was on his 4th build and was a very good builder.
I checked the gear legs today. They are NOT bent, just a little bit of an optical illusion the way the plane sits.
However, I ja ked it up and checked the wheel alignment. 3.9° toe out!!! WTF!
No wonder I shredded those tires in 9 months.
So now I have to rotate the axles and re drill. I have to move them enough, should I just drill a new hole about 1" above the current one? Or drill out the current hole large enough to see the gear leg hole and weld new pieces and back drill each side? I would prefer not to leave the plane on horses with wheels removed to do the welding and painting…
Suggestions?
Posted: Mon Nov 20, 2023 3:02 pm
Chris,
I had 3 thoughts on how to do it:
  1. weld up the axles and then redrill.
  2. make a sleeve, drill to the gear leg. Slot the original. Get it lined up, mark/tack weld it, then weld for real.
  3. buy new weldments.
Would like to see your setup for checking alignment.
Posted: Mon Nov 20, 2023 3:28 pm
by tps8903
Bryan Cotton wrote:Chris,
I took the tires off the rim. Used metal straight edges clamped to the face of the rims. Measured, did the math. Just like a car alignment. They are visibly toe out which was alarming before I even measured anything.
How would one match drill the hole with new weldments?
Posted: Mon Nov 20, 2023 3:50 pm
Somebody had a picture of description. I’ll have to see if I can find the thread. Basically you make a drill jig aligned with the gear hole. It is clamped onto the gear leg above the weldment.
Posted: Mon Nov 20, 2023 3:58 pm
viewtopic.php?f=3&t=1171
Posted: Mon Nov 20, 2023 4:49 pm
by tps8903
Bryan Cotton wrote:Somebody had a picture of description. I’ll have to see if I can find the thread. Basically you make a drill jig aligned with the gear hole. It is clamped onto the gear leg above the weldment.
I guess I’ll have to see how far it rotates to the new position before I decide which method to use.
From a practical stand point. What would be the problem with drilling a new hole slightly above the original?
Posted: Mon Nov 20, 2023 5:25 pm
I had a similar issue. I had a machine shop relocate the mounting holes at the engine mount. This involved rotating the leg the required degree, and use a 5/16 bit. Then I bushed the hole back to 1/4.
I .
Posted: Tue Nov 21, 2023 1:07 pm
by jerryhain
I had the same problem. I just removed the bolt. Did the alignment, drilled a new hole about an inch above it 90° to the original hole and installed the bolt there. Then I elongated the holes in the weldment and installed second bolt in the original hole through the axle. I really should weld that back up and re-drill but I decided if one bolt was good enough to maintain the alignment. I didn’t need to do the second bolt properly.
Posted: Tue Nov 21, 2023 2:17 pm
by tps8903
jerryhain wrote:I had the same problem. I just removed the bolt. Did the alignment, drilled a new hole about an inch above it 90° to the original hole and installed the bolt there. Then I elongated the holes in the weldment and installed second bolt in the original hole through the axle. I really should weld that back up and re-drill but I decided if one bolt was good enough to maintain the alignment. I didn’t need to do the second bolt properly.
That’s exactly what I wanted to know.
Posted: Wed Nov 22, 2023 12:36 am
Started swapping my tires tonight. This is about 110 hours or so.
new vs old tire.png (473.22 KiB) Viewed 6557 times
Posted: Wed Nov 22, 2023 4:52 am
Wow! Fortunately I fly off grass, most of the time - I am hoping for a long tyre service life
Posted: Wed Nov 22, 2023 12:54 pm
Wow. Are you sure you have the correct alignment? I guess you can extend that if you swap them every oil change. Any opinions if it would be ok to just swap the whole wheel, in which case the direction of rotation would be reversed? Is there a bearing problem if you do this?
Gordon
Posted: Wed Nov 22, 2023 1:15 pm
GordonTurner wrote:Wow. Are you sure you have the correct alignment? I guess you can extend that if you swap them every oil change. Any opinions if it would be ok to just swap the whole wheel, in which case the direction of rotation would be reversed? Is there a bearing problem if you do this?
Gordon
Gordon,
I followed the alignment procedure in the plans but I suspect it is off. I will be measuring and correcting it at the next condition inspection. That profile is not wear, but the quality of the Cheng Shin tire showing through. Had that shape when new, but looks normal when inflated.
Swapping the wheel is not a good option, because the tires wear on the outside due to camber. The inside must become the outside to get maximum life. I also swap left and right as my right tire wears more quickly.
Posted: Wed Nov 22, 2023 2:00 pm
by tps8903
Bryan Cotton wrote:Started swapping my tires tonight. This is about 110 hours or so.
Is the wear on the outside or inside of the tire? Mine was the inside of the tire. The extreme toe out was dragging my gear down trying to spread the tires. I would assume you have a bit of an opposite issue with too much toe in.
I only got about 30 pavement landing on my Cheng Sing tires before one blew out. The other 40-50 landings were on turf.
I’m going to rotate the axles, see how much it takes. If I can up drill with a custom jig to cover the size of the new hole, then I’ll do that. Otherwise I’ll elongate the original weldment hole, use that to clamp the weldment in place (like a set screw) and use my drill jig to drill a second hole about 3/4" above. This should prevent the weldment from walking around when I redrill it.
Because the original bolt will act as a set screw, I might do the final alignment in taxi position with weight in wheels with grease plates, then I know for sure what it is once the plane is in taxi position. My assumption for why this is done in the air is because normally the weight on the axles would cause them to shift while drilling.
Posted: Wed Nov 22, 2023 3:07 pm
tps8903 wrote:Is the wear on the outside or inside of the tire? Mine was the inside of the tire. The extreme toe out was dragging my gear down trying to spread the tires. I would assume you have a bit of an opposite issue with too much toe in.
Definitely on the outside. Regardless of toe there is a lot of camber. I would not have guessed anybody would have wear on the inside!
Posted: Fri Nov 24, 2023 7:48 pm
I think it would be helpful if you gave your tyre pressures - On my new Sonex Legacy (45 hrs) I am using 35 psi, operating almost exclusively of grass and so far no sign of unusual wear (actually tyres still look new)
Posted: Fri Nov 24, 2023 8:10 pm
Skippydiesel wrote:I think it would be helpful if you gave your tyre pressures - On my new Sonex Legacy (45 hrs) I am using 35 psi, operating almost exclusively of grass and so far no sign of unusual wear (actually tres still look new)
45-55 psi.
Posted: Fri Nov 24, 2023 10:07 pm
45-55 psi.
Thanks Bryan - that’s quit a wide pressure range for such a small tyre. My tyres are Goodyear Flight Custom III, 5.00-5, if failing memory is good Max 50 psi.
Would the tyre make/model change your recommendation?
Posted: Fri Nov 24, 2023 11:27 pm
Skippydiesel wrote:Thanks Bryan - that’s quit a wide pressure range for such a small tyre. My tyres are Goodyear Flight Custom III, 5.00-5, if failing memory is good Max 50 psi.
Skippydiesel,
From memory the Sonex recommendation is 50-55 psi. My Cheng Shin tyres say max 70 psi on them. The rims are cast at max PSI 30. My understanding with the stock sonex wheels and tyres is that running low pressure, like 30psi, can lead to the tyre/tube spinning on the rim. This causes a failure at the valve stem. I’ve heard a Sonex employee say he would like to grind off the 30PSI off the wheel casting, as low pressures have caused a lot of grief.
Typically when I fill mine I go right to 55 psi. They never stay there, but they don’t seem to go below 45 psi. So I fill them to 55 and leave them alone as long as they are at least 45. That is where I get my range from.
185 hours and hundreds of landings and those pressures have served me well. Now I just need to get the alignment figured out.
Posted: Sat Nov 25, 2023 12:06 am
Bryan Cotton wrote:Typically when I fill mine I go right to 55 psi. They never stay there, but they don’t seem to go below 45 psi. So I fill them to 55 and leave them alone as long as they are at least 45.
My older rims didn’t have the 30 psi limit but the ones I have now do. I’ve always used 50 psi as my setting but even with the famous “Leakguard” tubes I still check & set the pressure about once a month. I too understand that a lower pressure can lead to tire spinning & tube failure.
One of our Sonex flyers here has said that 50 psi using the factory 11x4-5 tires is correct but that larger tires (5" or larger) would mandate using 30 psi for a limit as 50 psi with the larger tire puts too much stress on the rim.
I’ve always used the factory recommend tires on both of the Sonex aircraft I have owned (16 years total) with 50 psi as a limit and have never had a flat.
I replaced my last set of tailwheel tires at ~200 hours with many landings and my worst tire looked excellent compared to what you posted (I still had tread all the way across). 8~)
Posted: Sat Nov 25, 2023 1:54 am
The Goodyear chart would suggest Goodyear Flight Custom III, 5.00-5, Rated Pressure, range from 31 psi for the 4 ply up to 50 psi for the 6 ply (I will check what ply rating I have)
https://www.aps-aviation.com/wp-content … e-data.pdf
Posted: Sat Nov 25, 2023 12:51 pm
by N190YX
Regarding the Goodyear Flight Custom III tires, while they will wear longer than just about any other tire except the Desser Monster retread*, they weigh 2 or more pounds more per tire, depending on the size. It is ~2 pounds more in the 500-5 tire size. That is four extra pounds on a tail dragger Sonex if you are using 500-5 tires! *Retread tires are commenly used in aviation with good results, the airlines and the Air Force use retreads almost exclusively.
Posted: Sat Nov 25, 2023 2:20 pm
Weight is the enemy! My latest Cheng Shin tire and tube weighed in at 3.16 lbs. My worn tire was 0.6+ lbs lighter.
Cheng Shin weight.png (475.44 KiB) Viewed 7178 times
Posted: Sat Nov 25, 2023 4:38 pm
Have the 5.00 x 5 tires on mine and never needed more than 25 PSI. Have just over 500 hours on the tach. Most of that landing on pavement and on the first set of tires. I would be wary of using over 30 PSI with those bigger tires. The larger sidewall area means more force pushing outward on the rims than with the smaller stock tires for a given air pressure.
Posted: Sat Nov 25, 2023 5:01 pm
Can anyone tell me what the weight of the 5.00x5 tire and tube is?
Posted: Sat Nov 25, 2023 5:27 pm
Bryan Cotton wrote:Can anyone tell me what the weight of the 5.00x5 tire and tube is?
The Goodyear specificaton document https://www.aps-aviation.com/wp-content … e-data.pdf has all their weights (I presume without tubes). Naturally the weight varies across “model” & ply rating, for a given size (5.00-5)
Posted: Sat Nov 25, 2023 6:00 pm
I’ll have to weigh one of my tubes. But the lightest 5.00x5 tyre I found in that chart was 4.9 lbs. I think by the time you add tubes that is a 5-6 lb weight increase. Hard pass for me!
Posted: Sat Nov 25, 2023 7:23 pm
Seems my Goodyear Flight Custom III, 5.00-5 are 6 ply, so according to the chart 50 psi.
I assume 50 psi is Max pressure - seems a tad high for a light aircraft, like the Sonex but will give 40 psi a try out. My tyres weight 3 kg /6.7 lb each.
Posted: Sun Nov 26, 2023 10:00 am
by 13brv3
AirTrac 5.00-5 4-ply tire is 4.5 lbs. I have a pair I haven’t installed yet. I don’t have a weight for the tube.
Posted: Mon Nov 27, 2023 11:25 am
Bryan Cotton wrote:I’ll have to weigh one of my tubes. But the lightest 5.00x5 tyre I found in that chart was 4.9 lbs. I think by the time you add tubes that is a 5-6 lb weight increase. Hard pass for me!
Bryan, I believe going to the larger 5.00x5 tires is probably the largest and most common mistake most builders make.. The weight penalty is severe, the cost penalty is outrageous, the braking action may even be reduced, and they’re simply not needed on the Sonex. The smaller tires are perfectly adequate on the Sonex and if one keeps them inflated at 45-50 psi, they don’t go flat.
Even Tony Spicer, who began flying his Sonex with the larger tires, eventually switched back to the smaller tires with success, and he was based on a grass field. Guess which tires I have on my Sonex.
Posted: Mon Nov 27, 2023 12:03 pm
by tps8903
Parts availability could be a concern. I blew my tire in North Tampa and needed to get home. Most A&Ps have 500x5 in stock, not so much 11x4x5. So I made the switch out of what was available and they work much better on my sand/turf field here in Florida, actually they roll sooooo much better. 90% of my operations are on turf.
Posted: Mon Nov 27, 2023 12:41 pm
In defense of the small tires, I will say I flew to a couple of 2100’ grass strips this weekend. Of course to do it, had to pick the right conditions. Cold, windy down the runway, and solo. Took more power to taxi and takeoff roll longer than hardtop, but it was fine. I can’t see going with big tires to optimize the airplane for a mission that it is not really suited for. It will never be a super cub.
Posted: Mon Nov 27, 2023 12:54 pm
by 13brv3
The 5.00-5 tires were a no brainer for me, since I need the prop clearance. Since the Onex can’t be full stall landed due to the short main gear, the extra height at least helps with that too. Considering the damage that can be done with a flat on landing, I feel better having a real aircraft tire as well. The extra weight is a small price to pay in my opinion.
Posted: Mon Nov 27, 2023 1:14 pm
Who was it who once said…“if you’re considering adding something to your airplane and you throw it up in the air and it comes back down, it’s too heavy”. Someone notable but I don’t recall who.
Posted: Mon Nov 27, 2023 1:22 pm
builderflyer wrote:Who was it who once said…“if you’re considering adding something to your airplane and you throw it up in the air and it comes back down, it’s too heavy”. Someone notable but I don’t recall who.
Rutan I think.
Posted: Mon Nov 27, 2023 5:40 pm
Bryan Cotton wrote:In defense of the small tires, I will say I flew to a couple of 2100’ grass strips this weekend. Of course to do it, had to pick the right conditions. Cold, windy down the runway, and solo. Took more power to taxi and takeoff roll longer than hardtop, but it was fine. I can’t see going with big tires to optimize the airplane for a mission that it is not really suited for. It will never be a super cub.
Me thinks that your comments, favouring “hardtop” - “airplane for a mission that it is not really suited for”, fails to appreciate that Sonex around the World are probably operating of grass.
Posted: Mon Nov 27, 2023 6:41 pm
Skippydiesel wrote:Me thinks that your comments, favouring “hardtop” - “airplane for a mission that it is not really suited for”, fails to appreciate that Sonex around the World are probably operating of grass.
Fair enough of a comment. The mission I was thinking of was short grass. I tend to view the airplane through Aerovee glasses and I perform a lot better off of hardtop!
This limited performance from the 80HP mill is also the reason I see the extra 6 lbs as a deal breaker for the bigger tyres.
Posted: Mon Nov 27, 2023 7:09 pm
I have …
Airhawk 5x5 4 ply with a Leakguard tube 3.8 + 1.16 = 4.96 #
peter
Posted: Mon Nov 27, 2023 10:07 pm
This may be of general intersted:
In Australia we have a number of plants that produce tough spiny seeds capable of puncturing bicycle tyres & some foot wear.
Many, if not all, are introduced species and can be found in many parts of the World, with similar hot dry climates.
They have all sorts of common names, usually reflecting the shape of the seed eg Cathead, Goathead, Bullhead, Three Cornered Jack, etc.
In Australia these plants are often found inland, in grassed areas eg taxiways, aircraft parking areas, grass runways, etc.
It is not uncommon for them to cause punctures in small aircraft tyres.
The most vulnerable part of a tyre, to puncture, is the relativly thin sidewall.
Low tyre pressures causes the side wall to bulge more than higher pressure.
The bulge may come close to the ground, particularly when additional load (landing, uneven ground) is encountered - this is when the seed is most likely to penetrated a tyre.
There is no full proof solution, other than solid tyres, however having your tyres at the correct pressure will minimise sidewall bulge and the chances of penetration by one of these seeds (or FOD).
Most Australian pilots, venturing far inland, will carry a spare tyre and or tube and I have also heard of temporary repair “green gloop/slime” to address the chance of a flat tyre.
Posted: Mon Nov 27, 2023 10:25 pm
My tube is 0.414 lbs. That puts my tire at 2.75ish lbs.
Posted: Tue Nov 28, 2023 1:08 am
by tps8903
Bryan Cotton wrote:My tube is 0.414 lbs. That puts my tire at 2.75ish lbs.
I do appriciate the weight comments on the tires. That being said, most Sonex I have seen have a lot of extras, extra avionics, extra auto pilots, extra interior pieces, extra paint, extra fuel tanks, extra lightining, extra electronics, extra alternators, and the list goes on.
Tires are important to me and my mission, I imagine most people who take the weight penalty are in the same boat, autopilot/avionics, for me, not so much. To each their own when it comes to compromises in weight.
Posted: Tue Nov 28, 2023 11:07 am
Regarding toe in. The plans called for toe in is set with the aircraft in a level position. But for a tailwheel aircraft, the tires actually experience a minor toe out condition when the tailwheel is lowered to the ground. So if one only taxis and makes 3 point takeoffs and landings as I do, the tires never experience any wear brought about by a toe in condition. For the tailwheel aircraft, that would only occur if one raises the tail on takeoff or when making wheel landings. Just a thought that some may have not considered.
Posted: Tue Nov 28, 2023 12:21 pm
by N190YX
It was definitely Burt Rutan who I heard say back in the day, at an early VeriEze workshop in Mojave, “If you are thinking about putting something on your airplane (not in the plans), throw it up. If it comes back down, it is too heavy”. He did not actually say (not in the plans) but that was the context of what he was saying.
The thing about the larger than Sonex/Waiex plans’ use of 500-5 tires is, if they make sense for your mission, do not select Goodyear Flight Custom III tires, because they weigh almost two pounds more, each tire, then other brand (and Goodyear Flight Custom II) 500-5 four ply tires, and that heavy and quality (long wearing) tire is not needed on a Sonex/Waiex. I thought quite a bit about tire weight and decided why put more wear on the retract mechanism of my factory retractable airplane having to lift significantly heavier tires into the wheel wells.
The comment about non-native plants penetrating tires in Australia was interesting, perhaps six or more ply tires instead of four ply could withstand those conditions better. I don’t know if the additional plys extend past the tread into the sidewalls though.
Posted: Tue Nov 28, 2023 12:58 pm
builderflyer wrote:Regarding toe in. The plans called for toe in is set with the aircraft in a level position. But for a tailwheel aircraft, the tires actually experience a minor toe out condition when the tailwheel is lowered to the ground. So if one only taxis and makes 3 point takeoffs and landings as I do, the tires never experience any wear brought about by a toe in condition. For the tailwheel aircraft, that would only occur if one raises the tail on takeoff or when making wheel landings. Just a thought that some may have not considered.
Interesting thought that I haven’t pondered over in much detail.
I do mostly three point landings as that’s is what Sonex suggest. A few other tailwheel pilots of these aircraft have warned that wheel landings on pavement can get squirrelly pretty quick. Still … I like a good wheel landing now and again. Not only do I need to keep in practice but they just feel so good sometimes when I can squeak one on! Tail low during take-off and landing is also something I do especially when flying from grass, which I really like to do.
I use the small factory tires i.e. 11X4-5 and they have worked quite well thus far …
Posted: Tue Nov 28, 2023 1:54 pm
When I check and set the alignment, I was going to evaluate both the 3 point and level attitudes. I’ll ballast up as well to simulate pilot weight.
I mostly do 3 point landings. I prefer to stand it on the mains for takeoff if the crosswind component is under 6kts or so. The aircraft does nice wheel landings. I don’t think it is squirrelly on the mains at all.
Posted: Tue Nov 28, 2023 9:49 pm
Bryan Cotton wrote:I mostly do 3 point landings. I prefer to stand it on the mains for takeoff if the crosswind component is under 6kts or so. The aircraft does nice wheel landings. I don’t think it is squirrelly on the mains at all.
I had heard that term used but it’s not my personal opinion. Still, I tend to do much like you and keep the tailwheel on the ground if the winds are gusty.
I find a Sonex to be a very docile taildragger to take-off & land and I certainly wouldn’t want anyone to be afraid of learning to fly a tailwheel Sonex. Of course those of us flying tailwheels hate to admit that it really doesn’t take a super-human ace pilot to land one of these things as that tends to take the swagger out of the walk.
Posted: Tue Nov 28, 2023 11:16 pm
I find a Sonex to be a very docile taildragger to take-off & land and I certainly wouldn’t want anyone to be afraid of learning to fly a tailwheel Sonex. Of course those of us flying tailwheels hate to admit that it really doesn’t take a super-human ace pilot to land one of these things as that tends to take the swagger out of the walk.[/quote]
I am new to tailwheel aircraft - did my conversion in a Citabria, which I found to be okay but challenging at times - best landings were on grass.
My Sonex (all but the first few) landings on grass, I find much easier - don’t know why. Similar approach/stall speed to the Citabria, seems less affected by X wind (lower to ground ?)
Posted: Fri Dec 01, 2023 2:48 pm
by tps8903
Fixed my alignment today. Had to bring the gear legs home. There were shims in the weldments and I could not move them by hand. I had to put the legs in a vice and heat the weldments then use a tube on the axle as a lever to get it to move. Even then it was fairly difficult to move.
I rotated them both about 0.065". Once they cooled there was no moving them again. The heat required didn’t even damage the paint. I used a standard propane torch for about 1 minute.
I was able to install them back on the plane and use the Gator V groove drill guide to drill the weldment and legs to 5/16" and consume the previous hole entirely. I used a carbide drill bit and it made short work of the titanium.
Plane tracks better, we will see how the tire wear goes. Initial measurements show 1.0° toe in.
As far as measuring goes. I used a straight 1x1 aluminum bar. 8’ long. Marked the centerline and clamped it to the bare rim with the plane in a level position. I ran a centerline with a bob and thin waxed line.
Posted: Tue Feb 13, 2024 4:45 pm
Bryan Cotton wrote:Weight is the enemy! My latest Cheng Shin tire and tube weighed in at 3.16 lbs. My worn tire was 0.6+ lbs lighter.
If weight is the enemy, why don’t you use worn out 0.6lbs lighter tires exclusively :wink:
Posted: Tue Feb 13, 2024 5:06 pm
We had discussed that! Or at least doing the short field missions with worn tires!
Posted: Thu Mar 28, 2024 2:19 pm
I’ve decided that I will attempt to realign the main gear on my tailwheel sonex B. I have a pretty good shimmy that sets up just after landing for about 6 seconds, all other times are smooth, the shimmy only occurs w wheel pants on. The pant installation is solid. If anything I’m a lil to far toe in, pic attached. Go pro under the plane indicates most of the shimmy is on the left. My tires have no wear, the wheels do not tack in or out when ground handling the airplane. Ive tried new tires, balancing wheels and balancing the pants but I’m at a loss. My bolt holes are snug. I would imagine that I will rotate the axle assemblies less than a hole diameter. I’m looking for suggestions on how best to do the job. Oversize the existing holes? Drill new? If drilling new how far above or below the existing hole and does the bolt orientation matter, ie can the new hole be perpendicular to the old. Best method? I dont want to screw up…again.
