Taper pin philosophy
Posted: Tue Jun 30, 2020 4:14 pm
by Carlos Trigo
In the type of aircraft homebuilding I’m used to (RV’s), there is no use of taper pins, all is done with AN bolts.
Does anybody know what’s the philosophy behind using taper pins instead of bolts?
Carlos
Re: Taper pin philosophy
Posted: Tue Jun 30, 2020 5:56 pm
by Sonex Foundation
Hi Carlos
See if this helps
http://www.sonexfoundation.com/uploads/ … lation.pdf
Posted: Tue Jun 30, 2020 6:29 pm
by Carlos Trigo
Do you mean that the use of a taper pin, instead of a bolt, is “to reduce the potential for a sloppy connection “?
Posted: Tue Jun 30, 2020 10:32 pm
Yes. In tube to tube connections
Posted: Wed Jul 01, 2020 4:28 am
They have been used with success for spar bolts also. The new old addition to the Sonex line of aircraft, the Sonerai. Uses 6 taper pins in lieu of bolts to hold the wings on.
Steve
Sonex 892
