Tail kit just came in, how to bend the forward horizontal stab spar strap?
So, got everything for the tail kit except for two tailtips. It seems like the very first thing I need to do is bend the forward horizonal stab spar to 22.3 degrees. Is the best way to accomplish this to get an arbor press, a bandsaw, and some scrap wood, cut the angle into the wood, and then put a steel rod on top with some tape and press the part down to form the angle?
Very new to all of this, so assume I know literally nothing while you answer.
There is a good tutorial on the sonex site. The second one down i believe is what you are looking for… Bending Flat Parts.indd
Check out page 1 of my build thread on the wayback machine:
Ampzapper shared his take on the task:
The key thing is to make sure there is a generous radius, no sharp bends or nicks in the part. Tail stays on = good, falls off = bad. In my picture above I had a half-circle cut into the wood and that was ok. My later jig was a hunk of plywood with a couple pieces of wood screwed into it to make the empty space to press into. I could not find the picture, but I still have the jig at the hangar and I’ll take a picture.
Keep in mind that the aluminum will want to spring back so you have to bend it a little over the final angle. I’d used a protractor and wouldn’t use the V-block as the primary measurement.
I had my hydraulic fixture from a previous project. If I had know how much I was going to use it I might have bought a hydraulic press or built something like this to make it easier: Homemade hydraulic press
Also, if you ever find yourself waiting for parts or tools, it’s a good time to look ahead or deburr edges on future parts. There’s a lot that can be done out of order.
I detailed that in a KITPLANES article.
Nice article Kerry, thanks.
Here is my later tooling, much like Kerry’s 2x4s. It’s hardwood and wider, so I can screw scraps to the board to keep the part captive as the bend starts. Not really needed for simple bends, but helpful for Waiex hockey sticks. I have some large bolts I use for the radius.
Thank you all for your help, I figured it out and while it’s a little bit underbent still, it measured only 0.3 to 0.5 degrees off so it should still be within tolerances. Unfortunately, this part is giving me a different kind of hell now, but I’ve put it in another thread in the Onex section.
