Statis Ports
Statis Ports
Posted: Mon Feb 26, 2024 12:13 am
by pilotyoung
Has anyone put static ports on the sides of the fuselage on a Onex? If so how did it work? And if so, where did you put them?
Thanks.
Re: Statis Ports
Posted: Tue Feb 27, 2024 12:30 am
by Jim1342
Reinhard Metz did an article in Kitplanes a while back.
Static Port Location.doc
(2.09 MiB) Downloaded 264 times
Re: Statis Ports
Posted: Tue Feb 27, 2024 1:38 am
by pilotyoung
Thanks for your help.
Re: Static Ports
Posted: Tue Feb 27, 2024 7:45 am
by lgsievila
When I installed my Dynon AOA pitot tube, I tried Dynon Static Ports a couple of different locations on the fuselage and nothing worked. Probably didn’t get far enough aft. Ended up leaving the Sonex supplied pitot static tube under the wing and used the static portion only. So I have two things hanging on the bottom of my wing.
Re: Statis Ports
Posted: Tue Feb 27, 2024 9:17 am
by BobDz
Jim1342 wrote:Reinhard Metz did an article in Kitplanes a while back.
Any chance you have this as a PDF?
Re: Statis Ports
Posted: Tue Feb 27, 2024 11:27 am
by pilotyoung
Here it is.
Re: Statis Ports
Posted: Tue Feb 27, 2024 1:06 pm
by BobDz
pilotyoung wrote:Here it is.
Thank you!!
Re: Statis Ports
Posted: Tue Feb 27, 2024 3:14 pm
Very cool. Where is Graham when you need him?
Re: Statis Ports
Posted: Tue Feb 27, 2024 3:46 pm
by 13brv3
Back when I was researching static ports, I read that article. I wasn’t going to go though all the testing, so I took my best shot at locating it similar to where it was on the RVs I’ve built. I had previously tried it on the pitot/static tube, and open in the wing, and cockpit. This works at least as well as those, but at some point you lose the ability to really prove if it’s exactly right. Obviously there’s one on each side tied together. Bottom line, no guarantees on this location :slight_smile:
Re: Statis Ports
Posted: Wed Feb 28, 2024 9:24 am
by pilotyoung
Thanks for showing the picture and telling your experience.
