Hi Guys,
I installed the AeroConversion throttle quadrant today and installed the control cables. The throttle cable is routed well and moves easily. However, when I connect the throttle lever and operate the throttle it squeaks. Seems like the leather friction washer is the culprit. Anyone else experience this? Is there a solution for smooth, squeak free operation?
Can’t say I have ever heard mine speak. It has always been more difficult to tighten when the temps out are warmer. When it’s hot the throttle creeps.
I would advise against any lube on the leather to make the sqeak go away and recommend a noise canceling head set and high engine rpm
So, I got up this morning with a fresh frame of mind and started searching for the problem. I couldn’t let it go because the throttle action was rough and squeaky.
I honestly couldn’t tell where the squeak was coming from so I started at the throttle quadrant and began disassembly. I worked my way all the way to the AeroInjector before I found the problem. Turns out the hole at the intake side of the AeroInjector had a burr on the inside. The squeak was the slide rubbing against that hole.
I didn’t take a pic before cleanup, but here is a pic after cleanup.
If you look closely at this picture, you can see where the burr(s) were binding against the slide.
Everything back together and smooth a silk
You should have bored it out another mm or two before reassembly!
