Feel free to add your completed aircraft to the table below to help other builders with their weight and balance. Rather than adding your information in a new reply below, hover over the table and click the pencil icon on the top right part of the table to add your information.
| Aircraft Type | User/Tail Number | Empty Weight | Moment | Gear | Engine | Finish | Equipment |
| Sonex | 19-7898 | 675 | 43330 | Taildragger | Jabiru 3300 | Yes | Prince Prop |
| Sonex | N157SX | 670 | 43747 | Taildragger | Jabiru 3300 | Yes | ACK 496/121.5 E-04 |
| Sonex | N50NX | 634 | 40400.6 | Taildragger | AeroVee | None | EBC 102A ELT |
| Sonex | N875SX | 668 | 43841 | Taildragger | AeroVee | None | ELT |
| Sonex | VH-MND | 665 | 43289 | Taildragger | 2.4L VW | Yes | |
| Sonex | N629SX | 671.7 | 40798.8 | Tri-gear | AeroVee | None | King ACK ELT, MGL Xtreme Mini EIFS, Sandia STX 165R remote transponder, MGL V6 Com, standard Odyssey battery in engine bay, led nav/strobes . Partially painted. |
| Sonex | SN 439 | 655 | 42129 | Taildragger | AeroVee | None | ACK E-04 ELT, magnetometer, MGL EFIS, no steam gauges, smoke system, polished, ELT, transponder, MGL radio |
| Sonex | N1517S | 685 | 42681.5 | Taildragger | Turbo AeroVee | None | ACK ELT |
| Sonex | 19-8706 | 640 | 41784.9 | Taildragger | Jabiru 2200 | Yes | none |
| Sonex | N920MB | 652 | 42699.8 | Taildragger | AeroVee | None | ELT, Baggage Sling, Empty Weight includes smoke system components and oil separator. |
| Sonex | N462SX | 680 | 43828 | Tri-gear | AeroVee | Yes | Sandia Transponder, ELT |
| Waiex | S5-MMX | 652 | 42675 | Tri-gear | Jabiru 3300 | None | nil |
| Sonex | nwade | 676 | 43917 | Taildragger | Turbo AeroVee | Yes | ACK ELT, Trig TT22, MGL SP-6, sm fire extinguisher |
| Waiex-B | 19-1614 | 739 | 47627 | Taildragger | Rotax 912ULS | Vinyl Wrap | 2 antennaes |
| Xenos | bvolcko | 800 | 54877 | Taildragger | AeroVee | Yes | MGL SP-6 magetometer |
| Sonex-B | N239SX | 731 | 46640 | Tri-gear | Jabiru 3300 | Vinyl Wrap | MGL avionics suite with autopilot servos, Trig Transponder, Sonex sourced leather seats, standard battery |
| Sonex-A | N726CJ | 654 | 41800 | TW | RevMaster | Yes | Prince Prop, Matco Brakes & Wheels, EarthX bat. |
| Sonex-A | ZK-SXR | 645 | 41562 | Taildragger | Rotax 912ULS | None | MGL Extreme V10 EMS2 |
| Sonex-B | N830EH | 726 | 46868 | Taildragger | Jabiru 3300 | DIY Single-Stage Paint | Prince Prop, EarthX battery, Sonex heated seats, Dynon SkyView (com/transponder/ADS-B in and out, autopilot, Garmin GPS175, ELT in tail, compass |
