Sonex - B panel size?
Posted: Sat Apr 03, 2021 5:17 pm
by sjakulski
Assuming a panel blank is included with a kit purchase, is it oversized for modifying as desired or is it a fixed size? Could someone point me to the dimensions of it… Thanks Steve J
Re: Sonex - B panel size?
Posted: Sat Apr 03, 2021 7:58 pm
by lakespookie
If you go to the panel section of the forums there is a link to the panel builder website that you can use to prototype a panel, Additionally it also has the dimensions in one of the top posts.
Posted: Fri Aug 06, 2021 12:20 am
by lakespookie
To add to this if you want to go with a 10 inch glass display you will have to make some modifications my panel post has an example of a 10 screen and how much it goes above the traditional panel height.
