Sonex and Sonerai cruise speeds.
Posted: Mon Mar 08, 2021 11:28 pm
by jonathan6229
Ok, long time lurker both here and on the old Sonerai board, as I’ve long been lusting after either airframe. My question is simply, do the Sonex family and a Sonerai 2LS cruise at about the same airspeed? I get alot of TAS at 7000 feet numbers, without fuel burn or much other data. So, I’m struggling to compare the two, or perhaps they are different enough that they should not be compared? Anyone flown both? (and maybe I’m on the wrong msg board, and just need to find the right B-model project) But if anyone has any experience on them, I’d appreciate hearing it.
Re: Sonex and Sonerai cruise speeds.
Posted: Mon Mar 08, 2021 11:46 pm
I cruise at 100 kts, burning 4.5 gph. Sonex tail dragger with AeroVee engine. I can go faster, but at a much higher fuel burn.
Posted: Tue Mar 09, 2021 2:53 am
Ditto Mike’s number.
If I am prepared to put up with 90 Knots TAS I can get down to 3.5 GPH leaned out at about 5,000ft DA
Posted: Tue Mar 09, 2021 8:43 am
by bakerde36
I have owned both but the Sonerai 2 was a few years ago. My Sonex is not the fastest, I cruise about 110mph but I burn less than 4gph.
If I remember correctly my Sonerai Cruised about 125 with a Great Plains 2180. I think the Sonerai has a little faster roll rate and I really loved flying it but after about 40 minutes I had to get out of the plane it just wasn’t comfortable for long flights. I wished I still had the Sonerai but I think the Sonex is a better bird and love my Sonex. I have only flown it 2 1/2 hours non stop but I wasn’t uncomfortable execpt for my bladder. Good luck and make the plunge you won’t regret it. Densil
Posted: Tue Mar 09, 2021 11:08 am
by Sonerai13
My Sonerai II was set up for speed (and climb suffered accordingly) but I could get 140 mph in cruise burning 4 gph, powered by an 1835cc VW conversion. Great airplane to fly, tons of fun but not as practical as a Sonex.
Posted: Tue Mar 09, 2021 11:22 am
I have the Waiex B model with Aerovee Turbo. I set it up to run at 30 inches map, 3000 rpm, and lean it to an indicated 1350 +/- EGT temps. At those settings with my Ed Sterba 54 x 52-inch, cruise prop I religiously get a TAS between 135 and 139 mph burning 5.4 to 5.8 gph. If I run up to 35 inches of map and 3200 rpm, I can get about 144 mph TAS but I am burning 8.5 gph.
Posted: Tue Mar 09, 2021 12:15 pm
In my Sonex A model with the normally-aspirated Aerovee, I reliably get ~135mph at ~5+gph. I’m currently using the Sensenich 54x44, but have also used the Prince 54x46. I believe I get a little faster with the Sensenich.
Densil, with the 2400cc engine, I’d expect you to be a bit faster, but maybe we all define “cruise” differently
I usually cruise at wide-open-throttle.
Posted: Tue Mar 09, 2021 3:10 pm
by ldmill
After 310 hours on the hobbs, my Waiex with a Jab3300 consistently cruises at 146mph with a fuel burn of 4.9gph. This with wheel pants and gear fairings on at average altitude of 3500msl using a Prince P-tip prop. My GPSs readings would generally agree with this as well.
Lorin
Posted: Tue Mar 09, 2021 3:13 pm
Hi Jonathan,
Probably a silly question but … Have you sat in the airplanes you are considering. I have this airplane sitting in the shop:
I sat in it and the “office” is much tighter than my Onex and much much tighter than the Sonex cockpit. I believe the fun of flying comes from control feel rather than speed. The Sonex will be a bit slower than the Sonerai, but if you want to feel like you are going faster just fly lower
I do have to add, the Sonerai makes me smile every time I look at it.
Best of Luck,
Posted: Tue Mar 09, 2021 8:20 pm
I had a Sonerai IIL with the 1835 and speeds like Joe N. I did not put electrical system in it. It never needed more than 3 pulls to start it. I also pulled the front seat out. Loved it. I think I have another year to go to finish the Sonex B.
Posted: Tue Mar 09, 2021 11:34 pm
by jonathan6229
So, in regards to sonex airframes does the Jab3300 burn less then the Turbo Aerovee? So the turbo is just for hot and high situations? I do think a Sonerai is going to be a bit small for what I need. One consideration is that I’d be operating inside that Mode C veil, so I need ADS-B/Electric/Radio and all that added weight.
Posted: Wed Mar 10, 2021 12:32 am
jonathan6229 wrote:So, in regards to sonex airframes does the Jab3300 burn less then the Turbo Aerovee? So the turbo is just for hot and high situations? I do think a Sonerai is going to be a bit small for what I need. One consideration is that I’d be operating inside that Mode C veil, so I need ADS-B/Electric/Radio and all that added weight.
Having flown both the turbo and 3300 on the same airframe, I can say yes. Even with a Bing carburetor on the 3300 the fuel burn is lower than the turbo.
Posted: Wed Mar 10, 2021 9:10 am
by bakerde36
Hi Chris,
I think I was a little over Propped I was swinging a Prince Ptip 54x50. I also cruised about 2800 RPM at full Throttle which was about 3100 I was showing about 120-125mph. I sold my engine and am putting on a corvair and the guy I sold it to said is that how you had the carb I said yes and he said some of my problem he believed was I was creating a low pressure and probably not getting enough air into carb. Let me say I loved the Hummel engine I just want a little more performance as I live in the mountains and I am not a slender guy(yes I am fat).
Posted: Wed Mar 10, 2021 3:59 pm
I have built and flown both types. A Sonerai 2LS with Jabiru 2200, flew it for 5 years. Then built an A model Sonex with a 3300 Jabiru, which I’ve been flying for the past ten years.
At cruise speeds Sonerai was a 120kt aircraft at 2700 rpm, burning 15 LPH. The Sonex with 40 more hp, cruises at 130kts burning 20 LPH. They both fly fairly similar with the sonerai being the more sensitive of the two. Those full span ailerons on the Sonerai are magic.
I believe the Sonex is definitely the better allrounder of the two, with lower stall speeds, better visibility when landing, side by side seating and more baggage area. All the reasons I sold the Sonerai and built a Sonex.
The Sonerai is the better hotrod. With right prop and the same power a Sonerai will be always be faster than a sonex. I would love to have one of each type, both powered by a Jabiru 3300.
Steve
Sonex 892
Posted: Thu Mar 11, 2021 1:29 am
bakerde36 wrote:I think I was a little over Propped I was swinging a Prince Ptip 54x50. I also cruised about 2800 RPM at full Throttle which was about 3100 I was showing about 120-125mph.
Yeah, it sounds a little over-propped to me too. I suspect a few inches finer would be better and get you a few mph faster, but not nearly as much fun as the bigger engine ![]()
