SNX-C03-06 Elevator Pushrod
Posted: Thu Dec 17, 2020 12:46 am
by Jason
I’m at the stage of reassembling the Fwd Side walls and Firewall along with all of the innards. Thinking ahead and looking at the access needed to install the long Elevator Pushrod C-03-06 it dawned on me it might have to go in before the Fwd fuselage is installed and riveted. The angle it needs to be inserted at through the black plastic bushing and support angles might not be accessible once the Fwd fuselage is permanently installed. Any help or thoughts here from someone would be appreciated. I’m plans building and have not ordered the pushrod yet. Thanks.
Jason Smith
Sonex #460
Re: SNX-C03-06 Elevator Pushrod
Posted: Thu Dec 17, 2020 4:04 am
Hi Jason.
In the A model, I’m pretty sure the pushrod can be inserted through the hole in the tail end of the fuselage. The rudder fin may have to be removed.
Steve
Sonex 892
