Separate Prop Crush plate/Spinner from Prop?
Posted: Mon Jan 05, 2015 7:27 pm
by SonexN369UR
I removed my prop from Aerovee engine to change my prop for the Turbo I am installing. Problem is I cannot seem to separate the prop spinner from the prop. I have tapped and tapped to no avail!! Any thoughts or advice would be most welcome and appreciated. I COULD buy a new spinner but I’d rather not.
Jack L
N369UR
Re: Separate Prop Crush plate/Spinner from Prop?
Posted: Tue Jan 06, 2015 7:14 am
by sonex892
Jack
If all else failed. I would probably try heating the spinner with a hot air gun then tap the spinner with a rubber mallet?
Steve
Sonex 892
