Rotax 912 Build
Rotax 912 Build
Posted: Tue Mar 08, 2022 10:43 pm
by aschlem77
I’m building a Big bore Zipper engine. The parts are purchased from zipperbigbore.com, Jay and Hal have been great to work with. Im doing the 1622cc kit with the HP cam shaft and a through bolt kit for the case. This should yield 130hp. Plans are to add SDS or Edge fuel injection to complete the package. This project started with a 1000hr mid 2000’s 912UL. Additionally i will add the slipper clutch to the gear box and the HD starter. The engine is down to the case. I have already disassembled, cleaned, inspected the heads and lapped the valves, time to move on the the machining of the case and heads to receive the larger cylinders.
Re: Rotax 912 Build
Posted: Wed Mar 09, 2022 6:24 am
I am in owe of your project. Keep us posted. All the best
Re: Rotax 912 Build
Posted: Wed Mar 09, 2022 8:05 pm
by aschlem77
On the mill.
Re: Rotax 912 Build
Posted: Thu Mar 10, 2022 5:15 pm
by aschlem77
New cam is assembled and ready for the case
Re: Rotax 912 Build
Posted: Wed Mar 23, 2022 6:46 pm
by aschlem77
Through bolt conversion complete and one cylinder fit.
Re: Rotax 912 Build
Posted: Thu Mar 24, 2022 9:39 am
by gcm52
Very interesting! Please keep these photos coming.
Re: Rotax 912 Build
Posted: Thu Mar 24, 2022 6:43 pm
What milling machine are you using?
Re: Rotax 912 Build
Posted: Fri Mar 25, 2022 4:52 pm
by aschlem77
Bridgeport J2
Re: Rotax 912 Build
Posted: Sat Mar 26, 2022 10:45 am
by Matt541
Sweet! This is a direction I’ve considered as well. (Insert old school forum eating popcorn emoji..)
Re: Rotax 912 Build
Posted: Tue Apr 19, 2022 9:58 pm
by aschlem77
New pictures coming soon. Took a few weeks off. Here is one of me preparing to modifying a c-bore to fit the through holes I machined in the block. Had to remove .007 from the diameter of the pilot.
Re: Rotax 912 Build
Posted: Sun Mar 12, 2023 7:01 am
Any updates on this? Can’t wait to hear how it runs
Hi aschlem77
Not sure if you are on this forum. If you are, can you provide an update please
Is it still a 912 ? :smiling_face_with_horns:
