Rivet squeezer for wing spar
Posted: Sun Feb 26, 2017 7:59 am
by surfly
Good morning,
Please share with me methods used in setting the rivets into the Onex wing spar. I haven’t been able to find rivet squeezer jaws wide enough to do the job.
Surfly
Onex 0176
Re: Rivet squeezer for wing spar
Posted: Sun Feb 26, 2017 1:35 pm
by Mike53
I used a c-frame which worked beautifully .Just make sure you do it on a solid surface with no bounce or give .
The c-frame can then be used for dimpling the forward skins which is a bonus. http://www.onexmike.org/spar–inboard.html
Mike
Posted: Sun Feb 26, 2017 6:27 pm
by dhogue
I know you are inquiring about a rivet squeezer but I’ll pipe in anyway.
I used a 4x rivet gun and a very dense tungsten bucking bar and did it by myself. I had to replace 7 of the longest rivets with bolts as I elongated those 7 holes when extracting them as they were unacceptable.
Posted: Mon Feb 27, 2017 1:07 am
by wlarson861
A pneumatic squeezer big enough to handle a sonex spar is a bench mount type. I have seen one at Sonex’s warehouse set up on a bench that I assume they use to rivet the spars that they sell pre-built. Ats has several but as you can see they are very expensive.
https://www.aircraft-tool.com/shop/sear … +SQUEEZERS
Posted: Mon Feb 27, 2017 12:29 pm
by gcm52
I have a big Chicago pneumatic 351 rivet squeezer that I used to set rivets on my Zenith 701 wing spar, but it did not work for the Onex. I ended up setting the rivets with a rivet gun. I too screwed up about four rivets and put in bolts for those four. Sonex also has a method for setting the rivets with a hammer and a bolt, you could look into that as well.
Posted: Mon Feb 27, 2017 2:58 pm
by Bruce593SX
I did the hammer/bolt method, was surprisingly easy, just get the sonex bucking bar and do it on the concrete floor
Posted: Tue Feb 28, 2017 11:13 am
by markschaible
Hello SonexBuilders.net,
Checkout our video on solid riveting with the bolt & hammer technique (our recommended technique for our spars), and see a bunch more helpful video tips at: http://www.sonexaircraft.com/support/vi … l#drilling
