Prop advice needed
Prop advice needed.
Posted: Sun Sep 26, 2021 8:46 pm
by zzdeck
Have an Aerovee turbo on a legacy Sonex. Who should I buy the prop from, and should it be a climb or a cruise prop.
Thanks in advance for the help.
Re: Prop advice needed.
Posted: Mon Sep 27, 2021 10:53 am
Prince Carbon P tip is an option.
Use the ordering wizard on this page for a recommended prop.
http://www.princeaircraft.com/PriceOrder.aspx
Be aware typical production time is 6 months…
Sensenich is another option but I have no experience with their prop for the AeroVee
Posted: Tue Sep 28, 2021 12:26 am
Here’s Sonex’s recommendations from Sensenich:
https://www.sonexaircraft.com/propeller-options/
Prince propellers are great, but you’ll have to find someone flying with one to vouch for its performance and dimensions.
Posted: Tue Sep 28, 2021 9:46 am
If you haven’t been to Sonex, there are propellers mounted on the walls EVERYWHERE. John said they were all tested on AeroVee’s. He recommends the Sensenich. The lengths are obviously the same but the pitch can be different between manufacturers.
Posted: Tue Sep 28, 2021 11:12 am
by zzdeck
Thanks for the manufacturer advice! Now what are y’all running, cruise or climb props
Posted: Tue Sep 28, 2021 2:07 pm
zzdeck wrote:Thanks for the manufacturer advice! Now what are y’all running, cruise or climb props
Prince Wood Carbon P-Tip 54” diameter x 44” pitch gets me AeroVee recommended 3,100 RPM static at a standard day. It’s not a “climb” or a “cruise” - it’s what it is. :slight_smile:
Posted: Tue Sep 28, 2021 2:30 pm
I believe zzdeck is asking about the correct propeller for the Turbo. Sonex lists 54x50 Climb and 56x52 Cruise. Personally, I’d probably choose the climb prop, but I’d really want to hear what others who’ve flown that combination think.
Posted: Tue Sep 28, 2021 7:02 pm
gammaxy wrote:I believe zzdeck is asking about the correct propeller for the Turbo. Sonex lists 54x50 Climb and 56x52 Cruise. Personally, I’d probably choose the climb prop, but I’d really want to hear what others who’ve flown that combination think.
I know the Prince selection wizard will bring up a different prop for the AeroVee Turbo.
Posted: Wed Sep 29, 2021 11:09 am
by zzdeck
Yes grammaxy, I am specifically asking about a prop for the Aerovee Turbo. Sonex lists two recommended props, one a cruise prop and the other a climb prop. And Sonex’s FAQ states that Sonex leans toward the climb prop. What I’m requesting is feedback from Aerovee Turbo builder/pilots as to their experience and preferences with climb versus cruise props. Right now I’m thinking climb. Anyone think that is the wrong decision?
Posted: Wed Sep 29, 2021 1:07 pm
zzdeck wrote:Yes grammaxy, I am specifically asking about a prop for the Aerovee Turbo. Sonex lists two recommended props, one a cruise prop and the other a climb prop. And Sonex’s FAQ states that Sonex leans toward the climb prop. What I’m requesting is feedback from Aerovee Turbo builder/pilots as to their experience and preferences with climb versus cruise props. Right now I’m thinking climb. Anyone think that is the wrong decision?
…I signed on to ask the very same question and yours was on top. I too am ready for a prop and wondering if anyone has any insight as to the difference between the cruise and climb props for the turbo aerovee. My gut tells me go with the climb prop.
Posted: Wed Sep 29, 2021 6:27 pm
After testing, on my turbo, a Sensenich climb 54x50, cruise 56x52, Prince P-tip cruise 54x50, and Ed Sterba hybrid climb/cruise 54x52 props, I have come to the conclusion that Sonex knows what they are talking about.
I am flying behind a Sensenich composite-covered wood prop suggested by Sonex at 56x52. However, my personal experience is that I would be equally happy with the Prince P-tip 54x50 cruise. I live in Phoenix and still get about 800 fpm in the desert heat. Better in the, very cold, winter here at 70 degrees.
If I want better climb than the Sensenich, I have the Sterba in the hangar. But I fly off of a 7000-foot runway and am satisfied with pretty much leaving the one prop on it.
Posted: Thu Sep 30, 2021 10:58 am
pappas wrote:After testing, on my turbo, a Sensenich climb 54x50, cruise 56x52, Prince P-tip cruise 54x50, and Ed Sterba hybrid climb/cruise 54x52 props, I have come to the conclusion that Sonex knows what they are talking about.
What are your thoughts on the Sensenich climb prop offered by Sonex? I’ll be flying out of KDYL that is 3000" hard surface and 3PA2 that is shorter and turf.
peter
Posted: Thu Sep 30, 2021 4:59 pm
by OneTallShort
So my choice was for the Sonex climb prop. My logic is that the turbo runs better and faster at altitude. But you have to get up there first. For most short flights, pattern work, aerobatics, climb is better and more fun. So if you want to go fast, go high.
That said I haven’t flow yet behind my choice, but that’s why I bought my prop.
Posted: Thu Sep 30, 2021 6:00 pm
by zzdeck
Thanks to all who replied. I’ve decided to convince my partner that a composite Senserich, climb prop, is the way to go.
I think there is a bigger chance I’d regret getting a cruise prop than regret getting a climb prop. And wasn’t minimizing regret something that was covered in an engineering decision making class I took years ago??? Memory too far gone to remember for sure.
Posted: Thu Sep 30, 2021 6:22 pm
by Spaceman
GraemeSmith wrote:Prince Carbon P tip is an option.
10.5 months and counting here… :confused:
Posted: Thu Sep 30, 2021 10:18 pm
Peter,
I have about 8 hours of testing the Sensenich recommended climb prop. It works great and 3000 feet of runway is probably 2400 feet more than you will need, but use it all anyway!
I just like flying higher and faster. The cruise prop still climbs just fine, even in the Phoenix heat. I just keep it in ground effect until I get to 70 mph before pulling back on the stick in the summer. Winter is no problem. With the climb prop, I rotate at 60 and climb immediately.
