Problem with Secondary ignition
Problem with Secondary ignition…
Posted: Thu Feb 15, 2024 6:34 pm
by sonex1020x
Hi all ! George in Utah here flying legacy Sonex 1020 and Aerovee #356 normally aspirated. At runup the other day, noticed a larger RPM drop and rough running on the secondary igniton. Figured a fouled plug, so made an uneventful takeoff and flew for 45 minutes. Did not do an airborne mag check. After landing, decided another runup was in order and when switched to secondary, Very rough and could barely keep running. EGT on cyl #2 was falling off the scale on the secondary, obviously not firing. I’m not very savvy about electronics, so I’ll tell you what I did to diagnose the problem as best I can.
  1. Looked for anything obvious, wiring , loose connections, etc. and found all looked as normal.
  2. Replaced #2 sparkplug with a new one. The “old” one ( 5 hrs time) looked fine but sooty.
  3. Pulled ALL the ignition wires and checked resistance : #1 -10K ohm at 24" , #2 - 13K ohm at 32" , #3- 13K ohm at 30 " , #4 - 14K ohm at 27". These values seem okay ? Didn’t seem these values would explain #2 cylinder not firing.
  4. Trigger cap magnet still magnetized? Yes.
  5. Resistance check of both coils ( the co-pilot side one dedicated to #4 and #2, the pilot’s side is #3 and #1)
    1 - Primary, terminal to terminal at 3.3 ohm on both coils.
    2 - Secondary, a meter’s probe in each ignition wire hole = 13.4 K ohm on co-pilot side ( cyls. #4 and #2), and no reading at all on the pilot’s
    side coil(cyls #3 and #1). This was the OPPOSITE of what I was expecting (assuming 13.4Kohm is good and 0k ohm is bad). I was
    expecting a bad #2,#4 coil !
  6. Turned on Master and secondary switch and checked for 12v at top terminals. Yes, and coils warmed up quickly.
  7. Decided to measure resistance at ignition wire holes again just for grins. No change on co-pilot side, still 13.4K ohms, but now on pilots side
    read 27.3K ohms! VERY confused now ! Another check after about 5 minutes or so and still 13.4K ohm on co-pilot side, but now back to
    ZERO on pilots side. What am I missing here?
    I am not sure how to check the triggers, so didn’t go on any further. It seems I DO have a bad coil ( chime in here if you agree or not), but it is not the one that would explain cyl #2 not firing. And, does only one half of a coil go bad ? I’m at a loss and could use your help in diagnosing the problem. Can I afford to just buy new coils, triggers, wires and trigger cap? Sure, but would rather not. I hate to think of these parts as just consumables needing to be replaced every so often. BTW, my Aerove has over 320 relatively trouble free hours on it.
    Thanks for your help in advance. George.
Re: Problem with Secondary ignition…
Posted: Thu Feb 15, 2024 7:02 pm
The secondary should have less turns, and probably less resistance. So the 0 ohm may be ok. I’ve not measured mine.
How are your coils grounded? Just through the firewall mount or do you have a dedicated ground? If through the firewall maybe that ground connection has degraded with age. You could run a dedicated ground to the coil mounts and see.
You can see my dedicated ground wires.
Posted: Thu Feb 15, 2024 7:05 pm
If just the #2 temp falls off I’d suspect a coil as opposed to a trigger. You could swap coils to see if it follows the coil. Or swap the #4 and #2 plug wires at the coil.
Posted: Thu Feb 15, 2024 8:00 pm
Hey Guys/Bryan,
Bryan Cotton wrote:The secondary should have less turns, and probably less resistance.
That’s backwards isn’t it? Isn’t the “coil” is a step up xformer with many more turns on the Secondary?
I’ll be at the hangar tomorrow and will measure my 3 Ohm Dyna Coil if this hasn’t been resolved.
Posted: Thu Feb 15, 2024 11:21 pm
WesRagle wrote:Hey Guys/Bryan,
Whoops you are right, I goofed.
Posted: Fri Feb 16, 2024 1:10 am
sonex1020x wrote:At runup the other day, noticed a larger RPM drop and rough running on the secondary igniton. Figured a fouled plug, so made an uneventful takeoff and flew for 45 minutes.
It was hard for me to read past this line. Not trying to be difficult but this seems to me to not be a great idea.
Certainly you are the PIC and I respect that, but flying a plane with a known ignition issue is not something I recommend …
Best,
3.0 Corvair/Tailwheel
Posted: Fri Feb 16, 2024 5:04 am
sonex1020x wrote:3) Pulled ALL the ignition wires and checked resistance : #1 -10K ohm at 24" , #2 - 13K ohm at 32" , #3- 13K ohm at 30 " , #4 - 14K ohm at 27". These values seem okay ? Didn’t seem these values would explain #2 cylinder not firing.
George.
If my memory serves me correctly from my old school mechanic days you should expect 4000 to 8000 OHMS per foot of ignition lead.
Posted: Fri Feb 16, 2024 10:28 am
by sonex1020x
Thanks Dale, but looking for helpful information, not lectures. George.
Posted: Fri Feb 16, 2024 2:04 pm
sonex1020x wrote:Thanks Dale, but looking for helpful information, not lectures. George.
George,
You are PIC and have the right to fly a broken airplane. It wasn’t meant to be a lecture but a warning that others will hopefully adhere to.
If you want my personal helpful information … install a Corvair conversion! 8~)
3.0 Corvair/TailWwheel
Posted: Fri Feb 16, 2024 4:03 pm
Hi Guys/George,
I measured the resistance of a known good 3 Ohm DynaCoil. The primary measured 3.0 Ohms and the secondary as measured tower to tower measured 12.6 KOhms. Measuring from a tower to the core laminates measured OPEN.
EDIT: I contacted tech support at Dyantek and they said that the above measurements are the suggested trouble shooting procedure for their coils. The 3 Ohm and 12.6 KOhms are as expected.
Posted: Sat Feb 17, 2024 12:28 pm
by sonex1020x
Dale,
I resent your implication that i might be a careless pilot willing to fly a" broken airplane". You know NOTHING of my airplane, my experience or flight conditions that day. You should know that all takeoffs are optional, and carry varying risk that you can choose to accept or not. In my 56 years of flying, I have rejected or aborted my share of takeoffs for different reasons. I have never had an incident, accident, or even scratched an aircraft (outside of the hangar ,anyway :slight_smile: ) in those years. You may elect to not takeoff with a certain crosswind component, where i might feel it is safe. This does not make me an inherently reckless pilot. I posted many questions that i had regarding my ignition problem, none of which were “do you think I should takeoff with those conditions?”. Unsolicited and derogative advice is never appreciated. Secondly, you mock all of us Aerovee owners with your “Install a Corvair” ! If you want to continue to espouse your amazing conservative safety values and ideas, there are other places on this forum in which to do that. George.
Posted: Sat Feb 17, 2024 12:36 pm
by sonex1020x
To all you others who shared valuable information, Thank you ! FYI I ordered two new coils and a set of plug wires today, so hopefully that resolves my issue. And, did you know that Sonex considers a “set” of plug wires to be only two? No information on their Web Store to indicate a “set” is only two wires, not 4. If you go to any auto parts store to get a set of plug wires say, for a Chevy V-8, you will get 8 wires ! Go figure ! Thanks again, and I will re-post with results hopefully soon. George.
Posted: Sat Feb 17, 2024 12:43 pm
sonex1020x wrote:Dale,
George,
I certainly didn’t mean to strike a nerve with you. But differing degrees of crosswind experience and willingly flying a plane with a known ignition issue do not comport.
BTW … my “install a Corvair” remark was totally in jest as should be noted by the smiley face …
Best,
Posted: Sat Feb 17, 2024 2:29 pm
by tps8903
sonex1020x wrote:To all you others who shared valuable information, Thank you ! FYI I ordered two new coils and a set of plug wires today, so hopefully that resolves my issue. And, did you know that Sonex considers a “set” of plug wires to be only two? No information on their Web Store to indicate a “set” is only two wires, not 4. If you go to any auto parts store to get a set of plug wires say, for a Chevy V-8, you will get 8 wires ! Go figure ! Thanks again, and I will re-post with results hopefully soon. George.
Hi George.
Not sure if it was mentioned already. A resistance test on coils isn’t always accurate. I tested coils that appeared fine but after replacement it was obvious that one of them was bad.
I got bit by the spark plug wire ordering issue as well.
Posted: Sat Feb 17, 2024 5:43 pm
by sonex1020x
Thanks Chris. I tried reasoning with Sonex and simply said they should note on their web store that a “set” of wires is only two. They said it is how their supplier sells them to Sonex. I replied, I’m not buying from your supplier, I’m buying from you. George.
Posted: Sun Feb 25, 2024 6:51 pm
by sonex1020x
Hi all ! George with an update. I purchased two new coils and new secondary ignition wires in hopes of solving the #2 cylinder not firing on the secondary ignition. No joy. Problem still exists. Barely will run on secondary only, and the #2 egt starts falling off. It runs just fine on the Primary ignition with all 4 egts reading as they should. Do you know if a bad trigger can result in just one cylinder not firing? And, what’s the best way to test the triggers? And, it looks like they can be replaced with the engine still mounted, but may have to take off the starter? Any ideas? I did email Sonex and will see what they say. I hate just replacing parts until the problem is solved, but may have to do that. I did check the magnet on the trigger cap and it seems strong. I looked on the Sonex web store and it appears they sell the set of two,prewired triggers that need to be mounted on the plate that is attached with six allen screws. Anybody done this replacement? Thx, George.
Posted: Sun Feb 25, 2024 8:00 pm
One trigger fires one coil. One coil fires two cylinders.
If the second cylinder on any particular coil is not misfiring, the trigger would not be the culprit.
My next move would be to swap plug wires from the “bad” cylinder to it’s counterpart on the coil in question.
If the problem doesn’t move, it’s something non-electrical. .
Posted: Mon Feb 26, 2024 10:26 am
by sonex1020x
Well, that makes sense to me as well, but, if it’s not electrical but mechanical, why does #2 cylinder fire normally on the Primary ignition. Next time i’m out I will swap the plug wire from the number 2 location on the right coil, with the #4 plug wire on the same coil and see what happens. But the coils are new, so not really sure what that tells me? Confused in Utah !! George.
Posted: Mon Feb 26, 2024 10:44 am
By mechanical I mean a problem with a wire shorting or a plug.
If you use anti-seize on the plugs, it’s not uncommon to accidently get some on the plug or wire. Either can cause the spark to jump in an unintended location.
Many moons ago in auto shop, we used to remove a wire from the distributor of someone we disliked and draw a line from the terminal to the body of the distributor with a pencil. “Pencil lead”, being mostly carbon, gave the spark a handy little shortcut to ground and was maddening to diagnose.
Lessons learned.
Posted: Mon Feb 26, 2024 11:15 am
by BobDz
Lessons learned.
I did the same thing! Many many moons ago.
Posted: Mon Feb 26, 2024 1:42 pm
by sonex1020x
Ignition wires are new and routed correctly. All plugs new(less than 5 hrs time on them) and #2 lower plug replaced with brand new when problem arose. I guess next step is to undo my entire FWF wiring harness and individually inspect all wires pertaining to the secondary ignition. Still can’t for the life of me see how only one cylinder is affected. George.
Posted: Mon Feb 26, 2024 3:19 pm
Bryan Cotton wrote:How are your coils grounded? Just through the firewall mount or do you have a dedicated ground? If through the firewall maybe that ground connection has degraded with age. You could run a dedicated ground to the coil mounts and see.
George what does your grounding look like?
Posted: Mon Feb 26, 2024 7:31 pm
by sonex1020x
Hi Bryan. Coils are grounded to firewall and to the neg. batt post. Triggers are grounded to a “forest of tabs” block with everything else. Still just perplexed as how only one cylinder can be affected.George.
Posted: Tue Feb 27, 2024 9:47 am
by Tnhelm
I had a problem with one cylinder not firing on one plug after startup. I thought it was a bad coil. However, before changing the coil, I began checking the other cylinders with a spark tester and discovered I had a second weak spark on another plug. Turns out that when assembling the plug wires I had misinterpreted the instructions and not properly installed the plug wire end clips, (failed to fold center lead back over the outer portion of the wire to make contact with the clip). Considering you have changed the wires already, this is not likely the case. In my case, the only reason the engine was running fine (over 40 hrs) was because the spark was jumping the gap in the wire socket to the wire as evidenced by black residue in the coil socket.
Tnhelm
OneX 0137
Posted: Tue Feb 27, 2024 1:55 pm
by sonex1020x
I will definitely check the new plug wires I assembled, but it seems odd it’s still the #2 cylinder not firing. Will also swap the wires on the right hand coil and see if now #4 EGT falls off. George.
Posted: Tue Feb 27, 2024 2:07 pm
by BobDz
George
This is out there, but a post on another forum madame think of it. In high school we used to take a pencil and put a mark down a spark plug wire, and then watch our fellow classmates pull out their hair trying to figure out why it was misfiring. Not saying you have a pencil line, but is there any exterior contamination that could be causing a short? Run the engine in the dark and see if there is any arcing.
Posted: Sat Mar 02, 2024 12:19 pm
by sonex1020x
Hi all. Update. After installing 2 new coils, new ignition wires, plugs, and verifying all that done correctly, no joy. She still runs just fine on the primary ignition, but very rough on just the secondary, with the #2 cylinder’s EGT falling off. All the other 3 EGT’s are normal. Sonex recommended testing the triggers by using a voltmeter, pos probe on the orange wire at the coil, neg probe on good ground. With trigger cap magnet aligned with the trigger, I should get batt voltage. rotated another 180 degrees, should get around 1.5 volts. This of course with the secondary ignition on. I tried this and got batt voltage no matter how the prop was positioned, clear through 360 degrees. Never saw a lower voltage reading. This was consistent with both trigger assemblies. I have no idea what the results of this test is telling me. Any ideas ? Clearly my coils,wire and plugs were fine and weren’t the culprit . I hate to spend another $242 for triggers if they are not bad. George.
Posted: Sat Mar 02, 2024 1:00 pm
Like you, I’m somewhat skeptical that a trigger can cause one half of a coil to fail. I would assume you gap per the aerovee manual to 0.032" for the primary ignition. It might be interesting to try a closer gap on the #2 plug and see what happens. Also have you checked compression? As pressure gets lower there is less resistance for a spark to jump, which is why some airplanes have pressurized mags if they are going to altitude. Maybe the #4 cylinder is weak and the current is all going in that direction from the coil, but with the smaller gap on the primary plugs this has not manifested itself there yet. That would be an easy experiment to try if you had some old plugs laying around, which I bet we all do!
Edit: one way to rule out triggers would be to swap them.
Posted: Sat Mar 02, 2024 5:40 pm
Hi George,
I’ve heard rumors that the new Sonex secondary ignition module shuts down after some period of inactivity to keep from burning up coils. Does anybody know if that is true?
Anyway, let me try to explain the way the secondary worked back in the day on my AeroVee. It might at least provide some food for thought. Since I owned an AeroVee Sonex LLC has changed coils and obsoleted the old trigger module. Things might be a little different now. But here’s how mine worked.
While the secondary ignition switch is on, there is 12 volts on one side of the primary winding. The other side of the primary went to the ignition module. The ignition module side was basically GROUNDED while the trigger magnet was NOT aligned with the sensor in the trigger module. When the trigger magnet WAS aligned with the sensor in the trigger module the ignition module side was OPEN.
So, for most of the time the ignition module side of the coil was grounded and the coil was charging, then, when the magnet passed the (hall effect) sensor in the ignition module, the ignition side of the primary opened up. Much like a set of points opening up.
Here is a pic Chris Madsen posted a long time ago that illustrates whats going on. The pic shows the current passing through the primary of the coil. The current jumps to zero when the magnet passes the sensor. This causes a large induced voltage in the coil secondary winding and the plugs (should) fire.
Here is a pic of the voltage on the ignition module side of the coil primary when the ignition module opens the circuit.
If you compare the two pics, when the current in Chris’s pic goes to zero you can see the large voltage spike on the voltage pic. That spike starts the spark event. Then there is a flat spot on the voltage pic. That’s while current is actually “jumping” the plug gaps.
Next comes the ringing on the voltage pic. That when there is no longer enough voltage on the coil secondary to arc the plug so the current in the coil secondary suddenly stops. That sudden stoppage reflects back on the primary much like what happened on the secondary when the current in the primary suddenly stopped.
Anyway, what comes next, after the ringing, the ignition module side settles in at 12 V. At that point the circuit is still open and no current is flowing in the coil primary so all you see is the 12 V power on the other end of the primary winding. That continues until the magnet clears sensor. At the very end of the voltage trace you can see the magnet clear the sensor and the module side of the primary is again grounded and the process repeats.
For dual plug coils to fire both plugs at the same time there is only one secondary winding. So, the plugs are in series with the secondary winding. In theory the secondary winding is “sucking” current from one plug and “pushing” it to the other plug. Not always the case though. If the coil arcs internally or if there is enough inner-winding capacitance (or some such techno babble) there may be enough current/charge available to fire only one plug.
Enough of that. So what to do.
Assuming you have done whatever you deem appropriate to ensure that you can fiddle with the prop while the secondary ignition is on without the engine firing, I would start by seeing if you can fire the plugs by exercising the ignition module by hand. You can do that hooking a volt meter to the ignition module side of the coil primary and moving the prop so as to make the trigger magnet pass in front of the sensor. You should see 12 volts (after a healthy spike) while the magnet is passing the sensor and zero volts while the magnet is clear of the sensor. If that works, then you have a good idea that the ignition module and trigger magnet are OK. This assumes the new ignition module works the same as the old ignition module.
Posted: Sun Mar 03, 2024 9:54 pm
by sonex1020x
Hi Wes. That’s alot of information,most of which goes over my head… Just a re-cap of what I’ve tested and the results, before I just go ahead and order new triggers for $242 ! Removed all 4 bottom pugs, and grounded them, one at a time, to observe for spark. Secondary ignition on, rotated prop and saw spark on #1 and #3 cyls. No spark observed on #2 or #4 . Remember, both coils new. Tested triggers per Sonex by aligning trigger magnet with module and measuring voltage (again, secondary on ) at orange wire/coil junction. I got batt voltage. Rotated prop to 180 deg and looked for about 1.5 volts per Sonex. but still got batt voltage. I got the same reading no matter where the prop was positioned. Never saw a lower voltage. This was consistent with both trigger’s orange wires. Just looking to know if this test proves anything. Thx. George.
Posted: Sun Mar 03, 2024 11:17 pm
My personal belief, from the beginning, is that the trigger is bad. Had a similar incident on my Aerovee Sonex many years ago …
FWIW,
Posted: Mon Mar 04, 2024 2:40 am
Hi George,
If you can manually fire two plugs but not the other two it seems it must be the secondary module.
The only other thing I can think of is checking the grounds.
From AeroVee manual:
Note: A ground wire must be installed under one
screw of each Trigger and routed to a ground point
on the engine or airframe.
Good Luck,
Posted: Mon Mar 04, 2024 7:52 am
Are both of your triggers the same distance from the magnet? Mine were not from the factory and I had a measurable difference in timing between the two. .
Posted: Mon Mar 04, 2024 11:04 am
My secondary ignition draws 10 amps, but only if the engine is rotating. If the engine is not running and I turn on the secondary ignition there is a 10 amp spike then nothing. My engine serial number is about 850 or so. Hope this helps.
Posted: Mon Mar 04, 2024 8:57 pm
by sonex1020x
Ordered two new triggers today as per Sonex advise. I’ll let you know how it goes… George
Posted: Mon Mar 04, 2024 8:59 pm
Hi Bill,
bvolcko38 wrote:My secondary ignition draws 10 amps, but only if the engine is rotating. If the engine is not running and I turn on the secondary ignition there is a 10 amp spike then nothing. My engine serial number is about 850 or so. Hope this helps.
So does that mean that you can’t hand prop the engine with the secondary anymore? I think hand starting with only the primary on an AeroVee would be frustrating. Do you know how long after the engine stops rotating until the ignition module powers down?
Posted: Tue Mar 05, 2024 10:45 am
I never tried to hand prop!
My assumption is that if there are no signals coming from the trigger, then there is no current flow through the coils.
Posted: Fri Mar 08, 2024 3:47 pm
by sonex1020x
Hi all. When I removed my old and “hopefully” defective triggers, I noticed a white paste spread on the backs of them where they contact the stator plate. I asked Sonex what this was, and they said it was heat sink paste. They suggested that, or dielectric grease should be used. Any experience with heat sink compound? Some sites online say diaper rash cream with Zinc Oxide can be used, but not sure how permanent that would be. Thx ! George.
Posted: Fri Mar 08, 2024 4:07 pm
Diaper paste cream other than being the same color is not the same as heat sink paste. The correct stuff is less than $10 on Amazon. It’s not worth the few dollar savings to use the wrong material.
Posted: Fri Mar 08, 2024 4:11 pm
I’ve used heat sink compound with heat sinks before. Including stuff from my job, computer stuff, and when I built my LED landing light mounts/heat sinks I used it there. Easy to find on Amazon.
https://www.amazon.com/gp/aw/d/B07KQ1T158
I’d go with heat sink compound.
Posted: Tue Aug 06, 2024 2:19 pm
by Squeaky
I have read these posts with interests because I have the same problem. Any answers or insights would be very helpful to me! My Aerovee would not run at all, now runs rough on secondary ignition. Primary ignition runs good. It has 10 hrs TT before I bought it used. Coils check good with ohm meter but don’t see any activity at either trigger. Ken
Posted: Wed Aug 07, 2024 5:36 pm
If you have EGT on each cylinder you can usually tell which ones aren’t firing (this helps if the problem is specific to a trigger or coil). From your description, I’m not sure how you tested the triggers, but if you really don’t have any activity at either trigger, it shouldn’t run at all.
Do you have a copy of the Aerovee manual? I’d go through the section about the secondary ignition and make sure everything looks right, especially the timing of the magnet.
In my experience the coils and triggers fail more often than I’d like and can be difficult to diagnose with a multimeter. Often, the failure happens at high voltages and maybe temperatures. It’s often easier to just replace with new parts. But, with only 10 hours, I’m more suspicious of installation issues.
Posted: Wed Aug 07, 2024 6:59 pm
Squeaky wrote:I have read these posts with interests because I have the same problem. Any answers or insights would be very helpful to me! My Aerovee would not run at all, now runs rough on secondary ignition. Primary ignition runs good. It has 10 hrs TT before I bought it used. Coils check good with ohm meter but don’t see any activity at either trigger. Ken
Did you check for spark? Check timing? Would be helpful if you listed what you have done so far.
Posted: Fri Aug 09, 2024 11:56 am
by Squeaky
Thanks Bryan and Chris! Coils both read 1.9 ohms across primary windings but it says they are 3 ohm coils. Secondary windings are both 13.3 kohms. Triggers both read battery voltage at coil yellow wires when magnet is not aligned under trigger.
Posted: Fri Aug 09, 2024 1:20 pm
by Squeaky
Voltage does not change when rotating prop - at yellow wire that is.
Posted: Fri Aug 09, 2024 1:26 pm
by Squeaky
Also it does run on secondary roughly at idle. I haven’t tried higher speeds or noticed EGT. The first thing I changed was rotating magnet cap 180 degrees.
Posted: Sat Aug 10, 2024 6:14 pm
If you haven’t already, check out page 45 of the Aerovee manual: http://www.aeroconversions.com/support/ … Manual.pdf
It’s not clear if rotating the magnet cap 180 degrees was just a guess, but the manual will confirm whether you have it correct now (by comparing to the primary ignition magnet).
I don’t recognize the yellow wire you mention. I think the old triggers had 3 wires, one of them being orange. The new triggers seem to only have two. Because of this, I can’t really comment on whether your measurements seem correct. Also, I think these sorts of measurements can be tricky because the triggers go to sleep after a little while if they don’t sense the magnet. You should measure ~12v across the low voltage coil and see it drop near 0 when triggered. I can’t remember if it stays 0 while the magnet stays near the trigger or it returns to 12v after a few milliseconds. It’s certainly too brief to measure with a multimeter on a running engine and possibly also impossible when turning by hand. I’ve measured it before with an oscilloscope.
Posted: Sun Aug 11, 2024 12:26 pm
by Squeaky
Thanks, Chris. I don’t remember for sure what led me to change trigger magnet but I did confirm that it was 180 deg off. I have the three wire triggers with yellow, red and black. It must function somewhat to run somewhat but roughly. We tried two different timing lights with no spark flash at all from either coil.
Coils are marked as being 3 ohm on primary but meter measured 1.9 ohm on both of them. Any additional insights?
George: I had a very similar problem to the one you described and am still struggling to solve it. My rpm drops significantly when running on the secondary ignition only during the pre-flight runup at 2000 rpm and cuts out almost totally when switching to secondary ignition while flying at cruise rpm. In the past year I have replaced the coils twice, and that solved the problem then. Now the problem has come back. Since then, I have replaced spark plugs and spark plug wires, etc. but the problem persists. My engine s/n 306 is an older one. I have the 3 wire triggers (red, orange and black). After reading the forum over past years and thinking the problem might be with the trigger magnet, I removed the 5/32 cap screw and the washer it holds from over what I believed to be the trigger magnet. This exposed a red cylinder behind the washer. Is this red cylinder the trigger magnet? I held a screwdriver tip and then a paper clip against it to test for magnetism, but it did not stick, so either this is not the trigger magnet, or the trigger magnet is not magnetized.
Another issue is the Aerovee manual, on page 46, says that static timing is achieved by "rotating the trigger cap (A) until the mark on the cap (B) is centered on the sensor of the upper trigger (C). However, with the cap screw loose, I was unable to rotate the trigger cap by hand. I wonder if rotating it requires pliers or some other tool.
I have tried to get answers from Sonex, but I must be really stupid because their answers have left me still scratching my head. Questions remaining:
  1. What does the trigger magnet look like and how to you find it?
  2. How do you test it for magnetism?
  3. If it is not magnetized, what should be done to get it magnetized?
  4. How do you rotate the trigger magnet cap to align it with the trigger?
  5. How do you test the secondary ignition to be sure it is operating properly with the engine cowl off?
I know there are many geniuses out there in Sonex land who know or can find out answers to these questions. Unfortunately, I am not one of them. But I would be forever grateful to anyone who can help me resolve these issues and get my bird back in the air.
Ron in Atlanta
Hey Ron,
Welcome to the forum. The trigger shaft is shown in the alternator section of the manual, picture copied here:
There is a round magnet aligned with the white mark. So if you look at the red cylinder from the side you can see a magnet. You should absolutely be able to rotate the red cylinder with the magnet once that screw is loose.
What I did to check the secondary timing was to make a mark on the right side of the engine case, then another on the flywheel when the magnetron was in the firing position. I checked with a timing light and moved the mark on the case until they lined up when running. Then I checked the secondary against that mark. Obviously do this with a helper and idle speed is fine - the timing is fixed and not dependent on RPM.
Check out this post on the old forum via the wayback machine:
When I can, I’ll take a better picture. Here is the Sonex replacement part:
Bryan:
Thanks for responding.
Your photo of your trigger looks different from mine. Perhaps it is a newer version.
I would like to send you a photo of mine, but haven’t figured out how to include photos here.
I have been following your build with your son on the forum for a number of years and seen videos of some of your flights, on YouTube, I believe. You two surely have it together and have a great thing ongoing.
I would like to contact you by email, if possible, as I am old and not comfortable with the mechanics of using this forum. If you email me I can answer directly and will be able to attach photos, etc. My email is buyeasy123@gmail.com.
Thanks for all you do.
Ron in Atlanta
Should be able to turn trigger easily with one finger.
