What are…is… the range of tail wheel pressures used by others?
Contact Peter Anson - 6″ Pneumatic Tailwheels and Accessories | Peter Anson – Engineering ![]()
Thanks for the response, but…nothing against peter at all…but real world experiences are what my question was, actual users willing to tell what they are using and comfortable with.
I haven’t put my Anson tailwheel on yet, but would also be interested.
I use 35 psi on the Anson which is the max written on the tyre. Being so small, I have to add air occassionally, so it has also also been used around 25 psi.
I don’t notice any handling differences with the lower pressures.
Pre flight, I use my thumb to test how soft it is.
Thanks much! kind of what I am doing now, but plan to go up a small bit to something like 25–26 psi, and then see how tight circle efforts feel relative to 20 psi, and solid wheel.
Peter Anson uses & reports on, his own products - tad hasty in your comments. ![]()
Not in the slightest. Joe is looking for real world feedback.
So “feed back” from a guy who made his own Sonex, uses & makes makes parts for the same (including pneumatic tail wheels), is not in the “real world” of tyre pressures - You, Joe & I must live on diffrent planets ![]()
I have the newer/fatter pneumatic tailwheel from Anson (which uses an E-scooter tire/tube). I fill it to about 45 psi. This is partly because I expect to lose ~5 psi while unscrewing my tire-inflator (all of these TW tubes are so small, its easy to lose a lot of air). Its also partly because landing with low TW pressure has caused a flat in the past.
I’ve had 2 flats with my TWs, both due to landing with low TW pressure:
- The original (skinny) Anson TW tube got pinched between the tire and the metal rim during a gusty landing on a runway with some pavement cracks.
- The newer Anson pneumatic TW went flat due to some side-load on the TW during touchdown that caused the tube to try to shift. I had mounted the stem so that it - and the rubber of the tube at its base - were both held pretty rigidly by the stem-hole in the tire rim. The side-load ripped the base of the stem loose from the rest of the tube.
To be clear: I love my Anson tailwheels and highly recommend them! They provide better grip than the solid tailwheel, a better touchdown experience, and a smoother ride on less-than-perfect surfaces. You just need to carefully mount and inflate them to avoid problems. Note that the newer (wider) unit uses common tubes that you can find in more places.
Thanks Noel! thats the kind of info I am looking for. My wheel, tire and tube are E-schooter ones. If and when, this texas april weather subsides for a few days I will get to bring PSI up to 35 and see how it does. Thanks all for any comments!
