Piloted Drill Bit 3/8 x 1/4
Posted: Fri Jan 29, 2021 9:34 am
Hello Everybody, Does anyone have a piloted drill bit 3/8" x 1/4" they could loan to me? I need to drill aluminum with existing 1/4" holes and want to keep them concentric.
Thanks, Rick Caldwell
Re: Piloted Drill Bit 3/8 x 1/4
Posted: Fri Jan 29, 2021 4:31 pm
Hi Rick
Will drill bushings work?
I think our tool loan program has either the drill bushings or the drill bit you need.
Posted: Fri Jan 29, 2021 7:11 pm
Hi Robbie,
Bushings will help keep the bit square but I was looking for a piloted bit to stay concentric with the existing 1/4" holes. I can set up on the drill press multiple times as an alternative to using a piloted bit. I was just going for the fast, foolproof method if possible. Pan Am Tools had a min. order of six when I went to buy one this morning.
Thanks, Rick
Posted: Fri Jan 29, 2021 9:25 pm
Hey Rick
Let me dig around and see what I have. My drill bushings did exactly that. Made it so you can center the smaller drill on the larger hole.
I’ll check tomorrow. I know Dale (Bipbuilder) sent me some drill bits recently.
Posted: Fri Jan 29, 2021 10:17 pm
Rick,
If Robbie doesn’t come up with the piloted drill bit, let me know…I have what you need.
Posted: Sat Jan 30, 2021 11:08 am
Rick
I just checked. I do not have these drill bits. Apologies
Posted: Sat Jan 30, 2021 11:32 am
The Yard Store has these and many others 1/4 x 3/8 double margin bit $10
Posted: Sat Jan 30, 2021 7:23 pm
Hi All, Thanks for the offers. I found one today locally to use.
Posted: Wed Sep 29, 2021 8:44 pm
Ok, Sonex Builders. We have a builder in Maryland finishing a legacy Waiex kit and he needs to borrow piloted drill bits.
“1/4 to3/8 and 3/8 to .0375 I think. I’m listening to sonex flight podcast 51”
Who can help him please?
Posted: Thu Sep 30, 2021 10:17 am
Not expensive and good to own.
https://www.yardstore.com/drilling-and- … with-pilot
Re: Piloted Drill Bits 3/8 x 1/4
Posted: Tue Sep 26, 2023 2:55 pm
by DWest
Hey all,
I’m building up the wing spars for my -B. Do we need these piloted bits for drilling the attach blocks and spar for mating or just when rigging the wings to the fuse?
Also, confirming these are the 2 needed to get the job done without having the hole wander or wallow out, misalign, etc,etc.
1/4 to 3/8 and then 3/8 to .0375 for the “tight fit hole”?
https://www.yardstore.com/drilling-and- … -pilot-usa
