Has anybody installed gear leg fairings for the Onex flat bar gear legs? If so, are the results worth the effort?
I did test a temporary foam fairing, taped in place, over the length of gear leg that bolts to the fuselage belly - did not see any observable speed gain. I suspect the air at that location is quite mixed up by the engine cooling air exit duct, exhaust pipes, etc.
