New AeroConversions Accessories Available!
Posted: Thu Aug 11, 2016 12:40 pm
by markschaible
Hello SonexBuilders.net!
Sonex Aircraft is excited to announce three new accessories from our AeroConversions product line that can be used in Sonex Aircraft, or any other experimental!
Hollow Spinner/Crushplates:
Sonex Aircraft’s trademark machined Spinner/Crushplates are now manufactured with a new hollow design, cutting weight in half! Our spinners double as propeller crushplates and are machined from solid aluminum billet. Available in two prop hub pattern options fitting AeroVee, Jabiru/CAMit, Rotax, UL Power engines and more, AeroConversions Spinner/Crushplates can be used on a wide variety of experimental aircraft.
ABS Molded Fairings:
A new feature in B-Model and SubSonex kits, AeroConversions ABS Molded Fairings are made from .063" thick white ABS plastic, are durable, lightweight, can be installed easily and can accept paint with high-quality results. Retrofit your existing Sonex Aircraft project with these new fairings. Cable, pushrod, counterweight and other fairings available and prices start at only $3.90!
ESF Foam Cubes:
Used primarily in the SubSonex Personal Jet, we are making Explosion Suppressant Foam (ESF) Cubes available for any experimental aircraft builder interested in reducing fuel sloshing/surging and improving fire/explosion resistance. Approximately 2.52 cubes are used per gallon and ESF Cubes are sold per cube at $1.50 each!
All of these great new accessories and more can be found on the AeroConversions Accessories page at: http://www.aeroconversions.com/products/accessories/index.html
