MGL V6 Radio integrating with MGL iEFIS Lite
Posted: Sat May 04, 2024 5:50 pm
by JFYrineo
I’ve installed both my V6 radio and iEFIS. Wired and powered up. I enabled my V6 in the iEFIS setup menu as well as set the V6 in the Port #1. I see my COM1 on my iEFIS panel but it is “X’d” out and does not reflect the act/stby on the V6. Am I missing some other setup to make the radio freq. active on the iEFIS. I’ve verified my RS232 TX/RX wiring connections between the V6 and iEFIS.
Re: MGL V6 Radio integrating with MGL iEFIS Lite
Posted: Mon May 06, 2024 8:40 am
Your setup in the menu looks right. I’m thinking its a wire problem.
