MGL OAT Probe & GPS Antenna
Posted: Sun Jun 20, 2021 4:00 pm
by Stevetin
Hello Fellow Builders. I’m currently installing MGL XTreme EFIS & EMS in my Waiex. Any suggestions as to a location(s) to mount the OAT probe and GPS antenna?
Steve
Re: MGL OAT Probe & GPS Antenna
Posted: Sun Jun 20, 2021 5:35 pm
by garyb
Hi Steve
I mounted my GPS antenna on top of the glareshield and the OAT probe is inside the wing leading edge.
Regards,
Gary
Posted: Mon Jun 21, 2021 3:56 am
Stevetin wrote:Hello Fellow Builders. I’m currently installing MGL XTreme EFIS & EMS in my Waiex. Any suggestions as to a location(s) to mount the OAT probe and GPS antenna?
Steve
If you have a fresh air NACA vent feeding the cabin that is a great place for the OAT probe. It’s easy to drill the back of the vent to insert the probe. Place the hole where the vent is deepest. The probe won’t be visible, unless you look into the vent, and finally you you will get a very accurate outside air temperature measurement.
GPS antenna on the glareshield. You can cover it with the black cloth that you’ll use to eliminate glare.
Posted: Mon Jun 21, 2021 11:40 am
by Stevetin
Thank you for your suggestions!
Steve
