Major airframe modification
Posted: Mon May 01, 2023 10:44 am
by lpaaruule
Anybody have experience with modification of an existing airframe from a regulatory standpoint?
For example, I know that there has been extended wingtip modifications. That seems like a major modification because it could result in much more main spar stress.
With that in mind, and the fact that having a sport plane doesn’t mean as much as it did before basic med, if each wing was shortened 14", what would be involved to stay legal?
I like the idea of the Sonex high wing, and Xenos detachable wingtips. I know that Glasair III has something similar.
Re: Major airframe modification
Posted: Mon May 01, 2023 5:41 pm
It’s an EXPERIMENTAL. Knock yourself out. You do the math. You figure if it is safe. You put it back in Phase 1. You test it. It’s legal if you survive!
Posted: Mon May 01, 2023 8:49 pm
by lpaaruule
I suppose the hard part would be insuring it. Also if ever decide to sell, it would might complicate things.
It’s probably not worth the hassle.
Posted: Wed May 03, 2023 8:45 pm
Cant speak for Uncle Sam (& friends) but here in Australia, Graeme’s advice is good.
Insurance - no problem. Your premium may initially be higher but then I pay additional cause its a tail wheel.
Selling - As long as you declare all structural and other potential safety issues (in writing dated & signed by both you & purchaser) its “Caveat Emptor”
Posted: Sun May 07, 2023 2:45 pm
by lpaaruule
Thanks for the input.
I suppose hiring an aircraft structural engineer isn’t out of the question either.
Posted: Mon May 08, 2023 6:52 pm
lpaaruule wrote:Thanks for the input.
Always a good strategy to run modifications past a number of experienced builders - humans don’t have origional thought/concepts, we build on the experience of others. In doing so we minimise the risks of failure/error and the time taken to “jump” to a hopefully workable solution.
