Loose Wheel Pant
Loose Wheel Pant
Posted: Wed Jul 31, 2024 1:19 pm
by Friesen5
Good Morning,
My wheel pants are slightly loose and I can move them with my hand when they are mounted on my landing gear. I have the hydraulic brake option (which I really like), and the wheel pant mount is the 1/16" aluminum plate that is attached to the mounting tab with a clevis pin. I think my mounting tab hole might be slightly enlarged.
I’ve flown with the loose pants, but I’m not comfortable doing it. I did take a video and sent it to Kerry Fores when he was still at Sonex. He said it was okay, but… So, I’ve been flying sans wheel pants.
Could you share your experience with the mounting plate and wheel pants?
Would you consider it unsafe to fly with a slight movement in the wheel pants?
Another question - My 1/16" plate ended up tilting forward. The plans show it level with the airplane. It works this way, but where did I go wrong?
Mervin Friesen
Sonex 122
Jab 2200
Re: Loose Wheel Pant
Posted: Wed Jul 31, 2024 2:46 pm
I’ve had that issue. The tab is drilled to 3/16" but the other holes are 1/4". I switched to a 1/4" bolt. Had to use one of the small squished metal locknuts as there is not much room on the axle.
Also the plates in the kit are made for nosedraggers. If you have a tailwheel aircraft you have to make your own.
To enable higher torque/tightness, I have replaced the Philips Head screws with Allan Key Button Head and added what we call Fender Washers (extra large) under each screw. Screws & washers are stainless steel.
So far so good - pants are staying nice & firm. :japanese_ogre:
Does anyone know the bolt size? 1/4-20? My Sonex is a substantial drive away and it’s difficult to buy hardware when I get there.
Hey astrodog, welcome to the forum. Which bolt are you talking about? I think my 4 screws that mount the pant to the plate are #8. Pant to axle is #10. There are three bolts that mount the brake to the plate and one of those goes through the weldment for torque reaction. Mine all started as #10 but I had to make the one through the weldment 1/4".
Welcome, Astrodog! Looking at my plans, AN525-10R8 washer head screws are called out to attach the wheel pants
Which I guess is a 10-32 machine screw, 1/2" long? If I have 1/2 in long 10-32 and 8-32 screws (per Bryan_Cotton), I have a fighting chance of getting it right. I appreciate the help. Just eliminating metric sizes improves my position.
