Hotter sparkplugs
After a long battle with a broken alternator and secondary ignition(trigger magnet) I’m trying to gain confidence in the Aerovee again. I lost that a bit when in one flight the alternator and the secondary ignition both stopped working and rough running on only the primary ignition.
I’ve figured out that the rough running must be mixture too rich. Couldn’t lean far enough to fix it. And if plugs are fouled, its not easy to get them working again without the secondary ignition. Adjusted the needle and now on the ground it’s running good on only the primary. Have to go up to test it in flight. But still the front cylinders run richer than the rear and the plugs foul more easily. To prevent this the suggestion is to put hotter plugs in the front cylinders. Autolite isn’t easy to get here in Europe, but NGK is no problem. The NGK equivalent is the DR8ES. So, I ordered the DR7ES which is hotter. Is this a good idea to try out?
AlexZ,
Good job on figuring out you needed to adjust the needle. I had to do that a few times but never need to mess with it anymore. At least not until I start modifying things again.
Your idea is interesting. I have no idea if it will work, but you could just put in two hotter plugs on the primary and leave the secondary as is.
I lean my engine aggressively, because it’s happy there. Typically I’ll run the backs at 1350°f - 1390°F and that gets the fronts lean enough to be happy.
AlexZ, Have you considered iridium plugs? They may not be available where you are.
Iridium Spark Plugs - Firewall Forward / Aerovee - SonexPilots.org
I haven’t tried the “hotter” spark plugs yet. The strange thing is that leaning out the mixture doesn’t work. I’ve adjusted the needle to a richer mixture. Then I flew again. On the secondary (electronic) ignition, it runs perfect, and I can lean it out significantly down to 18 l/h at 3000 RPM. However, as soon as I switch off the secondary ignition, the engine starts to stutter, and the front cylinders, cylinders 2 and 4, don’t perform well. To get them running properly, I have to go to a full-rich setting, consuming 22 l/h. It’s quite odd that cylinders which, in my view, are already running rich, need to be made even richer to run good. I’ve already replaced the magnatron for these two, but that didn’t help. Perhaps I should try tightening the gap on these spark plugs.
Hi @AlexZ
If the plug “behaves” itself when fuel is added, it seems that would indicate the plug was initially too hot and needed some fuel cooling. That would seem to imply that a colder plug rather than a hotter plug might be the answer. Am I thinking wrong?
I’m not saying that is the answer, just questioning why a hotter plug would be the answer.
In my OP I mentioned that I had figured out that the rough running must be mixture too rich. There the thought for a hotter plug came from. Now it seems that was a preliminary conclusion. In practice I have to run rich to run good on the primary.
The reason I didn’t try the hotter plugs yet is the fear for detonation. So, maybe first a tryout with colder plugs would be on the saver side.
