Highwing Build - dreynol
IIRC, a lot of us used a couple of those steel 12" rulers. The ones you can slide a square attachment on. They are close to the dimension you need.
Yep, same as Bryan. I used a ruler whose thickness was close to the specified dimension and laid the part down on a table with the ruler between the table and the hinge. It probably isn’t “exactly” the offset specified, but apart from some kind of fixture I don’t know any other way to keep it straight.
I also suggest drilling and Clecoing the ribs to the skin before attaching the hinge.
Obviously, don’t drill the holes thru the skin into the ribs on the short side where the hinge will eventually go until you’re ready to center drill the hinge into the assembly.
I used three planed 2x4s to ensure my control surfaces (I used the same technique for the rudder, ailerons, elevators, flaps) weren’t twisted before drilling the hinge. The little flange that overlaps (which the hinge also attaches to) is where a twist will occur. So save it for last and make sure it’s flat before drilling thru the hinge, the two overlapping skins, and the holes on the short face of each rib or you’ll end up with a twist.
Very similar but different, I used a section of the ever present 1" x 1" by 1/8" angle. The fillet is curved and the radius matches the radius of the barrel on the hinge. I milled one side down to as close as I could get it to spec. I only needed a few inches of angle. Use is same as above.
I like the wooden form block. I did the same with HDPE. In addition to laying out the measurments, It is helpful when drilling the holes in both the skin and ribs. I also made a set of form blocks for the various channel material. This will provide support for drilling as well as support for mounting on a vice for a drill press. I like using wood in my vices as soft jaws. The woodgrain holds the part firmly and doesn’t damage the material.
I like the photo, workmanship looks quite nice.
Thanks, I should get some feeler gauges - Cotton’s law strikes again!
I also made a “rib” out of a 2x4 for drilling. And check out this simple tool- a piece of scrap that hooks on the leading edge of a control surface, with markings for the pilot hole locations. Makes for a lot less measuring.
That was a piece of C140 wing skin. I went back to fabric, it’s lighter. So I measure the pilot hole locations from the edge, use a T square to draw a line, then my tool to mark the line for drilling.
Good idea! I have a bunch of rulers and can break out the calipers to find the closest.
Thanks for the recommendation!
I have some 4x4s that I need to square up
Thanks!
I’m going to use the block for drilling as well, but it made the measurements so much easier that it was worth it just for that
Ahhh, very nice!
Did the pilot hole drilling today.
I think it came out alright - everything lined up reasonably well & it seems like I avoided putting a twist in it.
Also learned that a can of acetone holds my laser level quite nicely.
Also had a brief moment of terror - everything was looking straight & level, then I flipped things over to drill out the final holes on the other side & things were horribly out of aligment.
Turns out the rudder drive assembly stuck out past the 4x4s & pushed things out of place.
Figured it out quickly, but it certainly got my heart rate up there for a sec!
Nice job!
Might just be the light, but this area looks a little jagged and (if so) will likely lead to a stress crack. Might want to consider using a small diameter round file to smooth/round out the corner so the stress on the drive assembly can disperse a little. Again, it might just be the light playing tricks on me. :slightly_smiling_face:
In case it’s helpful, I did a presentation for my EAA Chapter last year discussing stress fatigue and fractures. Feel free to peruse:
Nope, you nailed it - sharp eye!
After I trimmed the skin, I did enough deburring to keep myself from getting cut open but I’m doing another pass after I get everything final sized.
Thanks for the presentation as well!
I’ve been traveling & bogged down with work lately, but slowly making progress. Final size drilling is complete & I’m working on deburring.
What’s the best way to get to the inside of the holes at the narrow end of the ribs?
I have one of these, but it feels like I’m having to be a bit too aggressive to get the small burrs. Scotchbrite pads work, but are quite slow.
Do you mean the rivet holes for attaching the skin? I used a flat jewelers file. Like this:
Ah, those seem perfect - I’ll grab some on my way home.
At the old Sonex weekend class, John Monnett shared that he uses a 6" stainless ruler for a lot of deburring. It works, but I prefer the files. You will find them handy for many deburring and smoothing tasks, they are critical for building a sheetmetal aircraft. Plus, the purpose of the hobby is to buy tools.
If it’s a rounded surface (like a wing rib) I use 600 grit wet/dry sanding pads or a square of Scotch Brite. And a fine tooth file if it’s a flat surface.
For an expensive solution (but you can sometime fine them cheap on EBay) the Cogsdill deburring bit works wonders.
I prefer to use these :
Yes, they break easily. But, they break into very roughly 1 inch lengths. Perfect for those tight spots.
