GPS Receiver
GPS Receiver
Posted: Tue Apr 05, 2022 8:29 pm
Attention Electronics Wizards;
I seek your wise council.
I have a Dynon SkyView display in my new Sonex - It has come to my notice that the addition of a GPS receiver will make significant improvements to its utility.
Dynon make two GPS receivers; the SV-GPS-250 and the SV-GPS-2020.
It seems to me (the epitome of technological ignorance) that the 250 is likely to do all that I may want, for now and at 1/3 the price of the 2020 appeal to my short arm/deep pocket principals.
However the 2020 seems to have features that are pretty much required by Uncle Sam. As Australia often follows the direction set by Sam I wonder if I should dig deep and purchase the more capable unit?
Your thoughts Gentlefolk
Re: GPS Receiver
Posted: Wed Apr 06, 2022 9:56 am
SV-GPS-250 https://shop.dynon.com/products/sv-gps-250-a-gps-antenna-receiver-module
SV-GPS-2020 https://shop.dynon.com/products/sv-gps-2020-gps-antenna-receiver-module
IMO the only question would be is Australia planning to implement and/or require ADS-B? If not looks like the SV-SPS-250 would be sufficient.
Re: GPS Receiver
Posted: Wed Apr 06, 2022 10:00 am
by 13brv3
From this page https://www.dynonavionics.com/gps-receiver-module.php
Choosing the right GPS: US customers that are planning to equip their aircraft for compliance with the FAA’s 2020 ADS-B Out mandate should install an SV-GPS-2020 as their primary GPS. US customers that use an SV-GPS-2020 can utilize a second SV-GPS-250 as a position source backup. At this time, Dynon does not make any claims about the SV-GPS-2020’s applicability or useabillity outside of the US to satisfy ADS-B Out or other requirements. Therefore, non-US customers will generally equip with the SV-GPS-250.
Re: GPS Receiver
Posted: Wed Apr 06, 2022 8:42 pm
XenosN42 wrote:SV-GPS-250 https://shop.dynon.com/products/sv-gps-250-a-gps-antenna-receiver-module
Thank you for your succinct and response - I need to do more research.
Re: GPS Receiver
Posted: Mon Apr 18, 2022 6:03 pm
Follow up - I will be mounting my GPS receiver on the glair shield. It will be painted matt black to minimise visual distraction & fit in with rest of paint job. Dynon have stated that any paint that will stick to the plastic housing is okay to use.
Re: GPS Receiver
Posted: Mon Apr 18, 2022 9:52 pm
by sonex1566
Skippydiesel wrote:Follow up - I will be mounting my GPS receiver on the glair shield. It will be painted matt black to minimise visual distraction & fit in with rest of paint job. Dynon have stated that any paint that will stick to the plastic housing is okay to use.
Go on…have a little bit of class. Put a XXXX bar mat across the top with a dancing Elvis hanging from the compass!
Re: GPS Receiver
Posted: Tue Apr 19, 2022 8:07 am
Just don’t paint the antenna. Painting ANY antenna is not recommended.
Re: GPS Receiver
Posted: Tue Apr 19, 2022 9:45 am
I have heard that covering with vinyl is a better alternative to painting. You can get sample sized pieces for very little money from metro styling:
https://metrorestyling.com/
Re: GPS Receiver
Posted: Tue Apr 19, 2022 2:01 pm
I agree with Graeme that painting GPS antennas is not a good idea although some have gotten away with it. My GPS antenna (for the EchoUAT) is white so I mounted it on the white turtle deck. Mounting on the glare shield had a couple of concerns as to how much heat it would get but mostly about possible interference with other equipment (iFly GPS, Comm Radio, EZ Autopilot). I tend to end up with “stuff” stacked on the glare shield during cross country flights so I try to keep that area clean.
At the end of the day I don’t believe it makes a lot of difference but I wanted a great GPS signal as mine is tied to my ADS-B out (required) and my ADS-B in (traffic & weather) that is displayed on my iFly.
FWIW,
Re: GPS Receiver
Posted: Tue Apr 19, 2022 10:47 pm
Hi Skippy,
there are a couple new units on ebay, $215, and $190. gps-250.
i have a dynon set up , flying, with gps250, then had to upgrade to the gps -2020
to be compliant with the faa cert requirements. i believe it is the SIL level.source integrety level.
accuracy. the faa was changing some requirements as people started selling hardware/software.
so dynon came out with the gps 2020 to meet the requirements.
navworx got caught up in this, tried to cheat, got caught, and suffered their demise.
dont know of the requirements in OZ.
or what they will require in the future.
basically the atc system will be adsb display only, with no ground based radar systems.
so accuracy is a must, for aircraft taxiing on the ground to aircraft separation in the air.
michael.
Re: GPS Receiver
Posted: Wed Apr 20, 2022 9:46 am
While Dynon says that painting their gps antenna/receiver is not a concern, I just wouldn’t bother to do so. My Sonex has both the gps2020 and gps250 (as a backup) mounted on the black glareshield and their white color has never been noticed while flying. They do not create any noticeable reflection and are not a visual distraction at all, so not worth painting. Just my opinion.
Re: GPS Receiver
Posted: Wed Apr 20, 2022 8:32 pm
by 13brv3
It’s actually odd that Dynon told him he could paint it, because all of their documentation says NOT to paint it. It’s hard to believe paint will make any difference though, unless it’s some sort of metallic paint. Probably an overcautious rule.
I had a GPS251 on my black glareshield, and never thought one moment about it.
Rusty
Re: GPS Receiver
Posted: Thu Apr 21, 2022 10:37 am
FWIW: The instructions with my Garmin GPS were clear. Do NOT Paint.
Re: GPS Receiver
Posted: Thu Apr 21, 2022 12:05 pm
by 13brv3
The GPS250 seems to be the most available used item that Dynon sold, thanks to the ADSB upgrade. Here’s one for $50 in North Carolina via Facebook Marketplace. https://www.facebook.com/marketplace/it … 532409327/ Likely no help for the OP though.
Rusty
Re: GPS Receiver
Posted: Thu Apr 21, 2022 4:55 pm
13brv3 wrote:It’s actually odd that Dynon told him he could paint it, because all of their documentation says NOT to paint it. It’s hard to believe paint will make any difference though, unless it’s some sort of metallic paint.
Rusty
I’m not finding it in Dynon’s current installation manual but Dynon’s earlier manuals clearly said that it was ok to paint the gps antenna/receiver. As Rusty says, though, seems like only some kinds of paint containing metallic substances would be an issue.
Re: GPS Receiver
Posted: Thu Apr 21, 2022 6:12 pm
by 13brv3
builderflyer wrote:I’m not finding it in Dynon’s current installation manual but Dynon’s earlier manuals clearly said that it was ok to paint the gps antenna/receiver. As Rusty says, though, seems like only some kinds of paint containing metallic substances would be an issue.
I don’t see anything in a quick search of the manuals, but at the end of each of the item descriptions for the GPS units they say must not be painted.
https://shop.dynon.com/products/sv-gps- … ver-module
Cheers,
Rusty
Re: GPS Receiver
Posted: Sun Apr 24, 2022 7:13 pm
Thank you all for your very informative responses.
On the strength of Dynon’s written response to me, I painted & installed my GPS antenna.
All your advice regarding the nil visual impact and Dynon’s installation advise (not to paint) has come after my hasty actions. In future I will take the time to allow for your collective advise to come in.
