I’m in process of calibrating my fuel level sender and need some guidance. My components are: G3 iEFIS Lite, RDAC & RED Capacitive Fuel Probe. Sonex with a 20 gallon tank.
100LL - Avgas
All grounds go directly to the engine block
I have confirmed that the fuel level probe is putting out a voltage as follows when removed from the RDAC:
20 gallons – 4.7 volts
16 gallons – 4.4 volts
12 gallons – 4.0 volts
When I go onto the fuel level calibration page for RDAC 1, Fuel Tank 1 – the EFIS displays a current raw reading of 3908 – no matter what the fuel level is. I’ve confirmed that the RDAC PU voltage is off – switched it back and forth to make sure. I even moved the fuel probe sending wire (yellow out of the RED box) to the fuel level 2 input – in case something was wrong with fuel level 1 circuitry. No change – still reads 3908 regardless of the fuel level.
I did notice that the current raw reading on the calibration page is 92 when the sending wire is removed from the RDAC.
Any thoughts as to what I should try next?
Bill
N67WX
