Frayed cable ends
Frayed cable ends
Posted: Sat Mar 01, 2014 12:40 am
Any tricks for keeping cable ends from fraying? I have had to remove and reinstall the brake cables a couple of times, and it’s always a real trick trying to get a frayed cable through the little hole in the cable fitting.
Mike Smith
Re: Frayed cable ends
Posted: Sat Mar 01, 2014 1:43 am
by Fastcapy
Posted: Sat Mar 01, 2014 10:33 am
by radfordc
For the small diameter brake cable the only way I’ve found to prevent fraying is to solder the cable before cutting. Make sure the cable is hot enough so that the solder wicks into the strands and then wipe away all the solder on the surface. When you cut the cable the ends should stay put.
Posted: Sat Mar 01, 2014 3:49 pm
Brilliant Radford. Thanks
Gordon
Posted: Sat Mar 29, 2014 12:43 am
by n502pd
To get the solder to stick easier, and be ‘sucked’ into the inner strands, use a liberal ammount of plumbers flux. should be able to find it at a good hardware store. Also use a small propane torch, or at least a 200 watt solldering gun… I have been doing this very thing for many years and if you cut the cable with sharp cutters about 1/2 in into the length of soldered cable, it will stay together… Practice does help!!
Posted: Sat Mar 29, 2014 12:48 pm
by corton
Just to add to Joe’s discussion, make sure the plumber’s flux is NOT acid-based.
Of course, it’s literally been 20 years since I’ve touched that type of flux, so there it may not be made anymore (the acid kind).
Posted: Sun Mar 30, 2014 10:01 pm
by n502pd
Very good point!! I forgot that. I am pretty sure they make both kinds. I did look at my little tin of flux and it is about thirty years old! go figure!!
Posted: Wed Apr 23, 2014 12:05 pm
by billmaxmcw
You can get crimp-type ends at bicycle stores; they use them for brake and shift cables.
Bill
Posted: Wed Apr 23, 2014 11:15 pm
by tonyr
billmaxmcw wrote:You can get crimp-type ends at bicycle stores; they use them for brake and shift cables.
Bill
That would be ok to stop fraying, but I think the objective is to get them back through the swivel holes and no fraying… ?
Posted: Mon Sep 15, 2014 10:03 am
by LLR
This looks promising: http://www.eaavideo.org/channel.aspx?ch=ch_hints_general
~Larry
Sonex 1680
Posted: Mon Sep 15, 2014 6:11 pm
by tonyr
Thanks for posting Larry , that’s brilliant!
Posted: Sun Oct 19, 2014 9:59 am
by Gripdana
How about a little solder? My brake cables had it on the ends when I got them.
Posted: Mon Oct 20, 2014 11:27 am
There is a great solution to frayed cable ends demoed on the EAA web site: http://eaavideo.org/video.aspx?v=3742597802001
