Forward skin to rib contact
forward skin to rib contact
Posted: Tue Feb 26, 2019 11:50 pm
by wingnut99
We installed the forward skin on the right wing last weekend and everything went smoothly until we flipped it over and started attaching it to the other side. Once you bend it over the nose it gets a little belligerent about wanting to press down against the ribs, especially the front 2 rows of rivet holes. The front row has almost a quarter inch gap between the underside of the skin and the rib looking from the open end of wingtip. My mentor says that’s normal and I’ll need to make small aluminum washers and stack enough of them to fill the gap on each rib so that the skin is tight against each rib. Did any of you have this issue and the ratchet straps can only get the 2nd side that close or is there a method to get that skin down tight against the ribs all the way to the tip of the ribs?
Re: forward skin to rib contact
Posted: Wed Feb 27, 2019 2:42 am
by thomas
For what it’s worth, I’m currently building my wings and spent quite a bit of time over this issue. I thought about the aluminum washer approach but decided not to go that route because the profile of the ribs are what define the airfoil for the skins. Washers will likely alter that profile. How much can you deviate from the airfoil without appreciable performance problems? I didn’t want to find out so I took a step back and used the vacuum (re)bending method to tighten up the nose radius. SonexFlight has a great podcast on this method.
A lot can go wrong with extra handling of the skins so I don’t think it’s a decision for everyone. I had to buy a replacement right skin after oil-canning my first one. I killed nearly 20 hours in the shop with setup, handling, and bending, and at least as much time head scratching. However, the forward skins now fit reasonably well and I have less pronounced ballooning of the skins between leading edge ribs with the tighter radius.
Posted: Wed Feb 27, 2019 7:16 am
Many builders re-bend the skins using either the vacuum bag method or the Tony Spicer bend brake method. You may also need to file round notches at the front of the nose ribs to avoid getting little bumps in the skin. There’s bound to be someone with a picture of this but unfortunately not me. You should be able to get the skins to fit reasonably well without using lots of force. If you do have to use a lot of force to fit the skins you’ll end up with large dimples around all the rivets - looks terrible and probably isn’t great aerodynamically.
Posted: Wed Feb 27, 2019 7:43 am
I riveted the tops first, so they would have the best surface. The last two rows on the bottom we did as a two man operation. It was not 1/4" for me. I pressed the skin down hard and Adam pulled the rivet.
Posted: Wed Feb 27, 2019 9:16 am
peter anson wrote:You may also need to file round notches at the front of the nose ribs to avoid getting little bumps in the skin.
I did a little bit of this when it was clear that the front edges of the nose ribs were forcing the leading edge radius slightly open in certain places. The ribs come pre-bent, but that still doesn’t mean they’re all exactly the same, and even a slight variation of how the flanges were bent can change the geometry of the leading edge radius a little bit and affect the whole skin.
Posted: Wed Feb 27, 2019 10:07 am
by wingnut99
Thanks for all the comments. My thought was why isn’t the leading edge bent to the correct profile to start with? None of these solutions would be necessary if it just slid over the ribs with the correct bend. If I shove spacers in the gap then the wing profile is going to be affected and that has to change the performance from what Sonex designed the wing to do, maybe not substantially but I will also have to alter the other wing the exact same amount or that will result in unequal lift. That can’t be good. I’ll check out the vacuum bagging technique and maybe just increasing the bend somehow. It just needs a tighter bend in the radius. If that is being intentionally under bent as part of the 51% rule, they need to rethink that one. How many builder’s have access to a 11’ brake?
Posted: Wed Feb 27, 2019 12:52 pm
I had a terrible time trying to get the skins to lay down. If I put the top of the skin down first, the bottom would dimple. Put the bottom down first…you get the idea. I saw the “brake” they use at Sonex. It’s made of some of the finest Home Depot pine stock available. It has it’s best days behind it, and is apparently unable to make a consistent bend. Check your LE skins and you’ll see pressure marks on the ends but not the middle, and no where along it’s length does the angle match what’s showing on the print. I know…I know…there isn’t an actual degree measurement on the plans, but it definitely shows an acute angle (about 80deg). Look at the Sonex tips and tricks for leading edge install, and you’ll notice their skin has a noticeable less-than-90 bend. Out of the box, our skins were 115deg.
I vacuum bagged. I didn’t listen to the pod-cast, so this may have been addressed. DON’T PUT THE AFT EDGES EVEN WITH EACH OTHER!! The top of the skin is about 3/4in longer than the bottom from the tangent line, and if you don’t account for it, it WILL relocate the radius. Ask me how I know.
Posted: Wed Feb 27, 2019 5:30 pm
by Corby202
I also had to reform the LE using a vacuum. I taped an extra strip of aluminum along the bottom skin so both edges would meet and be taped evenly. Cant remember the size of pipe I used 38mm perhaps. One of the problems I think is because the nose ribs supplied with the kit do not match the plans hence the smaller radius required to get the skins to sit down properly.
Posted: Wed Feb 27, 2019 8:38 pm
wingnut99 wrote:My thought was why isn’t the leading edge bent to the correct profile to start with?
Indeed, why not?
Area 51 had a caution about vacuum bagging and I have another. I have not heard of anyone else having this problem but it will give you an idea of how critical this is. I scratch built so had to bend my own LE skins so decided to try the vacuum bag method. I had the skins water-jet cut but made a small mistake on my drawing and had the forward-most pilot holes 0.2" further forward than shown on the Sonex drawing. There was still plenty of room for riveting so no problem, but it meant that those holes were a little closer to the location of the bend. They formed a slight weak line and that is where the skin bent, so scratch $150 worth of material and $100 worth of water cutting. OK, my error caused the problem but it shows how close you are to producing scrap using this method.
If you go for the Tony Spicer method, one of the things I found was that a large wooden beam with the bending pipe attached is not stiff enough to bend the skin evenly. I got around this by “pre-bending” the tube/beam assembly to allow for the deflection. A friend who is building a Xenos, which has a smaller nose radius so smaller more flexible tube, made an arrangement to apply force to the middle of the tube/beam assembly as well as the ends. His end result was an almost perfect fit with almost no dimpling around the flush rivets. It really was worth the extra effort.
Posted: Wed Feb 27, 2019 10:59 pm
by wingnut99
I watched a YouTube video on vacuum bagging and it looked pretty successful. The builder marked the centerline of the radius and clamped the pipe down in the exact location. Since mine are pre-bent I don’t think it would take that much suckage, I just made that up, to get the additional tightening I need to get the contact to both sides of the rib portion that everyone struggles with. I think I’m going to get a 1 1/4" gas pipe and some plastic sheet and see if I can tighten it up. If I can’t then I’ll get some 2x4 and make a trough like Tony Spicer used and use the pipe with a 2x6 or 2x8 spine on top of it and draw the pipe down into the trough with the bend underneath getting pressed into shape. More work than bagging but whatever it takes.
Posted: Thu Feb 28, 2019 2:15 am
by rk2436
It’s hard to believe that after almost 20 years Sonex has never corrected the incorrect bend radius on the LE skins. Is the vertical stab Fiberglas tip still wongo too???
Posted: Thu Feb 28, 2019 4:26 am
For what it’s worth, I used PVC and not steel pipe. It’s world’s cheaper for one thing. I also found that any contamination larger than what’s comfortable in your eye will leave a mark on the skin. My first attempt was botched because of the roughness of the steel pipe, and because I laid the vacuum hose on top of the pipe. When atmospheric pressure took over, you could clearly see the corrugation from the vacuum hose in the skin. I drilled holes in the PVC to evacuate the air in my second attempt. All went very well.
Getting the pipe exactly on the bend tangent isn’t all that critical if you’ve accounted for the upper-to-lower lengths of the skin. Nature will put the bend exactly half-way between the edges.
Posted: Thu Feb 28, 2019 9:30 pm
by wingnut99
I hadn’t considered using pvc but it would be much cheaper and all its doing is filling the gap inside the skin as the vacuum draws it around it. I’ll try that first. I wonder if it would still be strong enough to press the skin into a LE wooden form as in the Tony Spicer method of would the 2x squish it and deform it enough to prevent it from pressing the skin into the form?
Posted: Fri Mar 01, 2019 6:10 am
Not a chance.
Posted: Wed Mar 06, 2019 10:23 pm
by wingnut99
I pulled my forward wing skin off last weekend and finished bending it. The plans show it pre-bent to 100°. Honestly it’s almost completely flat when you lay it down. There may have been 10° on each side of the bend but no more. Mine was bent pretty good after having it already installed but the vacuum bagging was slick. I bought a 10’ X 1 1/4" galvanized gas pipe, marked the center of the line where the bend was supposed to be, laid down a doubled up sheet of plastic. Next I pulled the sides of the skin up toward eac other and taped them together. I had to repeat the process until I had a nice U shape with just a couple of inches seperating the 2 edges and taped the edges of the plastic to seal it. I used a couple of conduit straps to anchor the pipe down so the assembly couldn’t move and also taped the sheet of aluminum to the pipe on the bottom ends for good measure. I wrapped one end around my shop vacation nozzle and used a long plastic wire tie to seal it up and flipped on the vacuum. 5 seconds later my skin had enough bend to fit the nose of the ribs with very little effort. I went ahead and vacuum bagged the other skin while I had the setup in place. I bought the steel pipe in case it didn’t work and I had to go Tony Spicer on it. Now I’m going to be cheap and return the pipe. You can’t tell it was even used. You gotta love YouTube. It worked just like in the video.
