Exhaust Manifold Flange Gap
Posted: Wed Mar 27, 2024 11:59 am
by DDUSCG
I’m the new owner of N998PC and loving it. Right now I’m working to fix a leaking exhaust manifold. 3 of the 4 connections were showing signs of leakage but the number 4 cylinder looks to be more of a flange issue. The flange doesn’t sit flush on the head. I’m planning to cut the pipe about 80% through and then bend it to sit flush on the head. Then I’ll weld the cut closed. I’d like to hear some other more experienced ideas if you have one. Thanks
Re: Exhaust Manifold Flange Gap
Posted: Wed Mar 27, 2024 2:28 pm
Sounds like a good plan. Congrats on your new airplane!
One question, have you had the pipe off yet? Besides the alignment it can fit too tight, too loose, anywhere in between. Mine are slightly tight, I have to fight to get the gasket in.
Posted: Wed Mar 27, 2024 2:59 pm
by DDUSCG
@Bryan Cotton I have removed it. Mine is a pretty tight fit too. I could probably fly it with the bolts off. ![]()
Posted: Wed Mar 27, 2024 3:27 pm
I’d probably cut it, bolt it up, tack weld it, then pull it off for the final weld. You are going to need new exhaust wrap!
Posted: Wed Mar 27, 2024 11:35 pm
by DDUSCG
Bryan Cotton wrote:I’d probably cut it, bolt it up, tack weld it, then pull it off for the final weld. You are going to need new exhaust wrap!
I don’t have power at the hanger to weld. I’m planning to bolt it up after I cut it and then use a feeler gauge to measure the gap and then remove it and reset the gap on my bench and weld it up. Thanks for the help. Can I just get the wrap at a local auto parts store?
Posted: Thu Mar 28, 2024 12:08 am
I’m sure you could. I got mine here:
https://www.amazon.com/gp/product/B002R4U72I
DO NOT buy spark plugs on Amazon though. Too much counterfeit crap out there!
Posted: Thu Mar 28, 2024 12:24 am
DDUSCG wrote:Can I just get the wrap at a local auto parts store?
Bryan Cotton wrote:I’m sure you could. I got mine here:
https://www.amazon.com/gp/product/B002R4U72IDO NOT buy spark plugs on Amazon though. Too much counterfeit crap out there!
And here is a video:
https://www.youtube.com/watch?v=Hp1uaJQZg4Q
I couldn’t make friends with the SS zip ties and used hose clamps.
Posted: Thu Mar 28, 2024 6:59 am
An old junk VW head makes a wonderful fixture.
They are everywhere.
Posted: Thu Mar 28, 2024 8:14 am
I also use hose clamps.
Posted: Thu Mar 28, 2024 9:15 am
by jeff0196
My exhaust wasn’t even close to fitting (more than an inch off on some flanges) and on the turbo that is all four cylinders in one piece. A local eaa chapter member that was very experienced with building many planes chuckled at my issue and said he could help. He came over with two small propane torches and we very carefully heated the affected areas to a lower red hot using one torch on each side and being very careful not to put too much heat into any one spot. When it was glowing I could bend it in place with small pliers from the flanges. Let it air cool and have never had an issue since.
Posted: Thu Mar 28, 2024 1:05 pm
by DDUSCG
Area 51% wrote:An old junk VW head makes a wonderful fixture.
What specs would I need (year, bore, etc) to get an old head with the right dimensions? That’s a great idea.
Posted: Thu Mar 28, 2024 1:35 pm
The dimensions are the same on all the Type 1 dual ported heads. Anything 1972 or later will fit the bill. The bore doesn’t matter.
If you can’t find anything cheap locally, I have an ex-Aerovee head that suffered unscheduled valve seat removal you can have for the cost of shipping. UPS thinks very highly of their services lately.
