Error in Logbook
Posted: Fri Aug 21, 2020 12:54 pm
by pilotyoung
I bought a Sonex aircraft and there are three obvious errors in an initial airframe logbook entry. The weight, Vx, and Vy entries are obvious typos. The entry was made on a computer or typewriter on label material and put in the logbook. The same entries in the POH are correct where they were handwritten.
I am wondering the correct way to correct those entries in the logbook? Or should I just ignore them, fly the aircraft with the correct weight and speeds, and forget that I noticed there are wrong in the logbooks?
I am tempted to put a handwritten note next to the initial entry stating that it is an error and listing the correct values.
I will appreciate your thoughts on this issue.
Re: Error in Logbook
Posted: Fri Aug 21, 2020 12:58 pm
You should make a new logbook entry that lists the corrections. A note next to the original that it is superseded by entry on date XXXX is a good idea. Don’t try to remove or make corrections directly to the original entry.
Posted: Fri Aug 21, 2020 3:59 pm
by pilotyoung
Thanks for the answer.
Posted: Mon Aug 24, 2020 9:49 am
by Sonerai13
Yep, I concur with Gordon. Make an entry correcting the info, but leave the original entry in place. The most current entry always takes precedence over anything prior.
