EAA KIT Weight & Balance Form
Posted: Wed Oct 05, 2022 5:12 am
The W&B form that came with the EAA registration kit says that min fuel is calculate using (HP/12) x 6. Is this value, approx 50#, suppose to be used in both the most aft and most fwd table? It would seem to me, I’d want to use zero for the most aft case.
peter
Re: EAA KIT Weight & Balance Form
Posted: Wed Oct 05, 2022 3:51 pm
I used zero gallons/pounds for fuel for the most aft case. That reflects reality, so I think it’s more appropriate to use on the W&B.
Posted: Wed Oct 05, 2022 8:50 pm
My understanding was to do the W&B for most aft case using two standard FAA 170 lb pilots. On my airplane you can’t get to zero fuel and be in the envelope. You need 4 gallons.
I think you may find you can do zero fuel when solo, but not two up.
I’ve enclosed the W&B I submitted for my airworthiness cert. That’s all it is - in the real world if you want to make sure you are good at zero fuel you need to run the particular numbers.
Posted: Thu Oct 06, 2022 8:35 am
Bryan Cotton wrote:My understanding was to do the W&B for most aft case using two standard FAA 170 lb pilots. On my airplane you can’t get to zero fuel and be in the envelope. You need 4 gallons.
The turbo and cooler adds alot of weight upfront, the result being with a 170# pilot & 170# passenger mine is still within the aft limit with 0 gallons on board. I will not be flight testing that scenario tho…
Your W&B doc is helpful…
peter
Posted: Thu Oct 06, 2022 8:37 am
XenosN42 wrote:I used zero gallons/pounds for fuel for the most aft case. That reflects reality, so I think it’s more appropriate to use on the W&B.
ok great…
thank you,
peter
Posted: Thu Oct 06, 2022 9:41 am
If you want my .xls document, let me know.
Posted: Thu Oct 06, 2022 1:27 pm
Bryan Cotton wrote:If you want my .xls document, let me know.
sure…
appreciate it…
I’m getting close
peter
Posted: Thu Oct 06, 2022 10:18 pm
Here you go! I’ve also got some calculations for ballast and so on - tweak with your own numbers of course.
Posted: Fri Oct 07, 2022 9:09 am
Bryan Cotton wrote:Here you go! I’ve also got some calculations for ballast and so on - tweak with your own numbers of course.
great…
thank you,
peter
