Al,
I would never go right to final size. Better to drill up in steps. AN3 bolts are 3/16. I would typically go up by cleco size - #40, #30, #21, 3/16”. Your hole will be more round.
Hi Al and welcome to the forum!
You’re going to get all kinds of answers to this one. John Monett used to tell us you’re not building a Swiss watch, yet you will find people who updrill then ream to final size….
Me? I used drill bits but did not go in such small increments. Your mileage may vary…but I sure get your FOFU….I did that a lot (FU) and just learned it is part of the process…
It would be best to step up in stages.
#30 you probably have clecos for so that would be a good choice. #13 is slightly smaller diameter (.1850") than 3/16 (.1875")so that would be a good size to finish with, I think the 3/16 clecos should work for that.
#12 is slightly larger diameter (.1890") than 3/16" so if the # 13 is too tight (it most likely will be an interference fit which is ok), maybe use 3/16 instead of #12.
That’s what I was thinking; I will just need to buy #21 and do it this way.
Thanks again, Bryan.
yep
12 = .1890”; 3/16” .1850 inches & 13= .1850 inches. Thanks, Murray. How’s your Waiex doing?
Hi Robbie,
Yup - most of the advice I’ve gotten is quite helpful. And I’m frequently trying to get over the overthinkin’ it hump telling myself ‘You’re not building a space ship!!’ Don’t let the perfect be the enemy of the good!
No, but good practices, asking good questions, and following the plans goes a long way!
Enjoy the build and we look forward to seeing your progress!
Thanks for asking Al.
I finally got all the parts and will start the process of getting it back to better than before condition. Probably be a couple of months to do it all and also will need the annual inspection done too.
I made the stupid mistake of removing the gear/engine mount and now have no great way to support it while doing all the work. Hoping to put the new mount on over the next few weeks.
