Dial-a-trim setting for first flight
Posted: Sat Jul 23, 2022 2:33 pm
Any recommendations? Stick centered in the range maybe?
Re: Dial-a-trim setting for first flight
Posted: Sat Jul 23, 2022 3:49 pm
by N111YX
Mine works best when set to “float the stick” about 1/3 towards full down (33.33% of stick travel with zero reference at full down).
Does this make sense?
Posted: Sat Jul 23, 2022 4:04 pm
Thanks Kip! I’ll go with it.
Posted: Sat Jul 23, 2022 6:23 pm
I started with full down…then dialed in 1 turn up for every 100lbs under gross I was. Your mileage (spring settings) may vary.
