Canopy latch Drill guide
I have a Peter Anson canopy latch. I went to install it and have lost the drill guide. It is 15.8mm OD x 4.8mm ID x 20mm long. Anyone have one I can borrow? I’ll pay postage both ways. Thanks
I’m 95% I’m sure I’ve got one at my hangar but wouldn’t be back there for 1-2 weeks. You could borrow mine if you’ve got some time. I’m pretty sure when I did mine because the plastic drill bit I had wasn’t the right diameter, I carefully traced the bore in the latch body using a sharpie, drilled the hole centered in that circle stepping up with plastic drill bits, then used a step drill up to the correct diameter.
Thanks. I’ll use your method since it worked for you.
