Boroscope suggestions
Does anyone have a suggestion for a decent quality borescope? I have a older USB one that I don’t mind using with a laptop but would like something the produces a higher quality/resolution image.
Were using the TESLONG TD500. Had to get a small head for use in a Rotax 912iS engine.
https://www.amazon.com/dp/B0CLG4LHWP?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3
Decent control of the camera and saves images to an SD card. You can also connect to a computer or tablet via USB. Have gone through two annuals taking all the SAVVY Valve and Cylinder pictures.
