Bent Longeron At Tail
Posted: Mon Sep 20, 2021 4:44 pm
by OtterlyFoolish
Ok, here is the one big problem with the Waiex B quick build kit that I just purchased. The original owner told me that it had fallen from a sawhorse and this longeron got slightly bent just at the last 5-6 inches. There appear to be no kinks or fractures visible to the eye but I know that aluminum does not like to be bent and then re-bent. I know that the safest way to handle this is to replace the entire longeron but I am concerned that I may not be able to get each hole in the new longeron aligned perfectly with all the other holes that are already drilled to size. Would that create a bigger structural issue than bending the longeron back? Would it be best to replace each rivet with a larger rivet so that I could final drill all of the holes slightly oversize to accommodate larger rivets?
I have been told that these planes are overengineered and that leaves a part of me that wants to just flex the longeron back to straight and proceed with the build. I certainly do not want to get myself or anyone else hurt so I need some real advice from seasoned builders. Hopefully with some science to back up those opinions.
I am fine with putting in the work but any advice as to how to approach this properly would be very helpful.
Re: Bent Longeron At Tail
Posted: Mon Sep 20, 2021 4:57 pm
by n307tw
I would try and bend it back a little but not excessive. The aluminum supports in the rear will absolutely force that longeron in place. I wouldn’t personally replace it. Wait and see what others say also.
Posted: Mon Sep 20, 2021 5:54 pm
I’m not going to comment about the advisability of bending it back…
But you will always know… Can you live with that? :slight_smile:
Posted: Mon Sep 20, 2021 6:56 pm
I’d bend it back. Does not look like a huge yield happened. Can you cleco all the other parts to it and spring it to shape without bending it back?
Beyond the opinions of me and the rest of the peanut gallery, email/call Sonex tech support and ask them.
Posted: Tue Sep 21, 2021 9:52 am
The best thing to do is bite the bullet, drill out the existing rivets, and replace the longeron by simply match drilling through the existing holes in the skins. I use one of these:
https://www.aircraftspruce.com/catalog/ … m=12-00817
The second option, if you choose, is to rivet the longeron back to the existing skin and bolt it all together. The tail components will likely, I repeat “likely”, hold everything in alignment.
Replacing it isn’t really that much cost or work. Match drilling is an easy skill to acquire and one you definitely need to have. You will use the tool above often and it will keep you from oversizing any rivet holes you need to drill out.
Posted: Tue Sep 21, 2021 10:45 am
pappas wrote:Replacing it isn’t really that much cost or work. Match drilling is an easy skill to acquire and one you definitely need to have. You will use the tool above often and it will keep you from oversizing any rivet holes you need to drill out.
Lou is right - It’s not hard or that much of an expense. Those would be easy rivets to drill out as they are backed up by the relatively solid longeron. The only tools I use are a nice sharp cobalt drill bit and vise grips. I don’t think you will need the vise grips with the rivet through the 1/8" thick longeron. The hole in the middle of the rivet keeps the bit centered well enough, especially if you pop out the mandrel first.
Posted: Tue Sep 21, 2021 11:43 am
by OtterlyFoolish
Thanks for the feedback guys. I asked Kerry when I was at Oshkosh this summer and he said he would replace it but that was without even seeing the pictures. That is obviously the safest thing to do but I feel that he is probably required to say that due to the liability involved. That is why I am asking real world builders here and on the SonexBuilders forum. I am still considering a new longeron but the match drilling will be a chore seeing how you can not just lay the old longeron on top of the old one for accuracy. If there was an actual bend point or any visible fatigue I would not hesitate to replace it but it appears to be minor in my eyes. That is why I want the opinions of those with experience.
Posted: Tue Sep 21, 2021 1:37 pm
If I was going to match drill it, I’d clamp the new longeron to the skin and just transfer the holes. If you really wanted to be crazy about it, transfer the holes from the bent longeron to some cheap home depot 1/8" flat stock, and then transfer those holes to the new longeron.
There is nothing wrong with being crazy about it, but it is probably not a requirement.
Posted: Tue Sep 21, 2021 2:13 pm
by OtterlyFoolish
Bryan Cotton wrote:If I was going to match drill it, I’d clamp the new longeron to the skin and just transfer the holes. If you really wanted to be crazy about it, transfer the holes from the bent longeron to some cheap home depot 1/8" flat stock, and then transfer those holes to the new longeron.
That is a simple and practical solution to the match drilling. Kinda mad that I did not think of it myself.
Marc
Posted: Tue Sep 21, 2021 5:15 pm
by Blank
I just finished replacing both upper rear longerons in my legacy kit due to the previous builder completely botching the horizontal stab install…among other things. Kerry was key in pushing my to do it. It was labor-intensive but I’m very satisfied with the end result. I purchased the 1" angle of 6061-T6 locally and saved a ton on shipping cost. Feel free to get in touch with me as I have many photos of the removal and re-install process.
Craig
Posted: Tue Sep 21, 2021 7:00 pm
You simply drill out all the rivets that hold the bent longeron to the fuselage skin. Clamp the new longeron in the bent one’s place at several points to be sure it is aligned, then drill through the existing holes in the skin into the new longeron. Cleco as you go. Very simple, don’t fear it.
Posted: Tue Sep 21, 2021 7:49 pm
by OtterlyFoolish
Blank wrote:I just finished replacing both upper rear longerons in my legacy kit due to the previous builder completely botching the horizontal stab install…among other things. Kerry was key in pushing my to do it. It was labor-intensive but I’m very satisfied with the end result. I purchased the 1" angle of 6061-T6 locally and saved a ton on shipping cost. Feel free to get in touch with me as I have many photos of the removal and re-install process.
I would love to see your pictures and I may pick your brain if I go that route. At this point I am comfortable moving forward with the build after hearing back from Kerry today. I am going to update this thread once I am done with this message.
Posted: Tue Sep 21, 2021 7:52 pm
by OtterlyFoolish
pappas wrote:You simply drill out all the rivets that hold the bent longeron to the fuselage skin. Clamp the new longeron in the bent one’s place at several points to be sure it is aligned, then drill through the existing holes in the skin into the new longeron. Cleco as you go. Very simple, don’t fear it.
After looking closer it is not as intimidating as I thought and I could make a simple guide/punch on the lathe that would allow me to accurately locate the new holes. That may not be needed because I heard back From Kerry today and he sees no problem with me moving forward.
by OtterlyFoolish
UPDATE: I heard back from Kerry at Sonex today and he said that he sees nothing that concerns him and that I should be fine. In addition he told me
“I NEVER recommend parts replaced or repaired because I’m worried about liability. My concern is the safety of each airplane, not whether we may get sued or not.”
So I am comfortable with flexing this back and then inspecting it closely once again before making my final decision.
Posted: Tue Sep 21, 2021 8:27 pm
Good talk!
Posted: Wed Sep 22, 2021 8:49 am
Not only cost, but shipping long parts can be problematic. Even ACS is not immune to having parts damaged in shipment, and that wastes your time even through ACS is very good about replacement (been there, done that.) 6061-T6 is the most commonly found grade of structural aluminum angle material and there is very likely a source not too far from you unless living in the extreme boonies.
Posted: Wed Sep 22, 2021 9:18 am
You typically get the best deal if you buy a full length, i.e. 25’. It is nice to have a little extra stock in the shop.
Posted: Wed Sep 22, 2021 6:43 pm
by OtterlyFoolish
Clamped a large steel block spanning the bend (supported with non marring material) and a 3rd C clamp in the center to gently pull it back. 4 separate tries to get it within about .020” but I did not want to try again and over bend it. This will be perfectly fine once all the other components are riveted in place.
