Ballistic Recovery System (Parachute)
Posted: Fri Feb 27, 2015 11:02 am
Has anyone installed one? What do you think of the practicality of one?
Re: Ballistic Recovery System (Parachute)
Posted: Fri Feb 27, 2015 12:16 pm
John -
A BRS is a lot of weight and takes up a fair amount of space. It features pyrotechnics (explosives that you carry around with you in the plane), and big straps that have to connect to structural members that can carry the load of the airplane during the descent PLUS all the shock loads of the 'chute opening. Its a somewhat-complicated and expensive solution that requires engineering and testing. And, as we’ve seen from some Cirrus incidents, firing the chute does not guarantee safety. If the plane is on fire or the wind pushes you into power-lines or a mountainside you can be just as hosed as if you didn’t pull the 'chute (perhaps more-so).
The Sonex is designed to be small, lightweight, and simple (i.e. not complex). It wasn’t engineered with a BRS in-mind. Adding one would detract from your useful load and possibly cause CG problems.
A simpler aircraft is a more-reliable aircraft - the less you have, the less can go wrong and the easier it is to keep up with maintenance. My sailplane, for example, features no motor and no fuel to catch on fire. Annuals cost me less than $500 and “maintenance” involves charging batteries, greasing a few parts, inflating the tires, and washing the aircraft. Yet I can use it like most any VFR pilot uses their airplane: On nice weekends I can go out and fly 100 to 300 miles and have some fun. No complications, no IFR certification or testing of gear, etc.
You could save a whole lot of money and hassle by skipping the BRS and instead spending a small portion of that money on glider lessons (which will teach you how to fly “dead stick” with confidence and precision). Jeremy and John have also mentioned this in seminars and some of the Sonex videos online.
Invest the balance of your time and money into good maintenance on the Sonex and - most importantly - regular flying to keep your skills sharp! Regular flying also helps keep engine corrosion at bay and keeps grease/oil spread around on control hinges and other critical parts; so its a win-win for the aircraft and for the pilot!
–Noel
PPL SEL, CPL Glider
Sonex #1339 - Wings & Empennage done, about to start Fuselage
TD, Center-Stick, Acro Ailerons, Aerovee Turbo
Posted: Fri Feb 27, 2015 12:50 pm
Forget the BRS. Put in an ejection seat.
http://rt.com/news/226095-russia-unique-ejector-seat/
#554
Posted: Fri Feb 27, 2015 2:08 pm
by marsolgp
I believe the new SubSonex has one installed…
Posted: Fri Feb 27, 2015 4:56 pm
Not to be pedantic; but I need to point out that the SubSonex is a completely different design! Different structure, different engineering, different operating envelope, different powerplant (obviously), etc. Its an apples-to-oranges comparison.
–Noel
Posted: Fri Feb 27, 2015 5:50 pm
I’d echo what Noel said. A BRS is not a good fit for a Sonex.
Recent incidents also show us piloting skills are a more effective safety net than a BRS. Many incidents begin at altitudes and airspeeds where it is my personal opinion the BRS would not modify the outcome.
Posted: Fri Feb 27, 2015 6:00 pm
by rizzz
I remember someone on the old yahoo groups having either looked at installing one or had actually done so.
Anyway, his findings were that the only way he could make it work was with the chute coming out of the bottom of the aircraft, thus landing it upside down (still better than dying right?). The problem with trying to get it to come out of the top was that the chute needs to be attached to the main spars and engine mount and he could find no way to arrange the ropes so they wouldn’t risk cutting off his head or other body parts when deployed.
Posted: Fri Feb 27, 2015 6:55 pm
by Waiex 49
I think a parachute for the pilot would be an easier solution than a BRS for the plane.
The Sonex and Waiex were not designed with the BRS in mind, I don’t see how it could be made to work.
When my AeroVee packed it in I found the Waiex to be a pretty good glider.
Focus on flying the plane and you will be ok.
Don Bowen
N49YX
Posted: Fri Feb 27, 2015 9:16 pm
by SonexN76ET
If Sonex were to offer a BRS air frame parachute someday, I would buy it. The potential events I could envision using it would include: mid air collisions, air frame failures, control system jams or failures, partial or complete pilot incapacitation, engine failure over inhospitable terrain, a stall or spin that was unreoverable, inadvertent encounter with icing, or if an engine mount were to break. Most of these things have never happened to Sonex aircraft, but they have happened to other aircraft. In fact, one of the Cirrus production prototypes had an aileron jam in flight. It did not have the BRS installed yet and the Air Guard F16 pilot who was their test pilot perished after multiple landing attempts. Finally, more than for myself, I would buy a BRS as an additional safety net for my passengers.
I respect each of your opinions on this issue. I am just saying if it was offered, I would buy a BRS for my Sonex.
Jake
Posted: Fri Feb 27, 2015 9:50 pm
I wish the Sonex airframe could support a BRS but don’t think it can. So, when I stress my aircraft where a potential inflight failure is more likely, I wear a parachute and do those maneuvers high enough for me to get out. All other times, I have faith my airframe will not fail. That leaves engine failures and mid-air collisions. I have ADS-B to help on the collisions, and in the event of an engine failure, I will fly the airframe as slow and as far into the crash as I can.
Posted: Fri Feb 27, 2015 10:00 pm
by falvarez
I’m curious…how many G’s are you guys pulling in your maneuvers. I would think at most it’s just 2.5 or 3…I can’t imagine you are anywhere near 4.5 which is only half the design load.
Posted: Fri Feb 27, 2015 10:28 pm
I just put a G meter in and haven’t done my typical routines with it yet. But coming out of a loop, I feel like its about 3 Gs. Video I’ve taken from the tail showed the wing skins flexing during rolls and spins so the wing is moving a bit. Another thing I’ve noticed is the paint on the bottom of the spar is popping loose indicating some stretching there.
Posted: Sat Feb 28, 2015 9:26 am
Noel,
Great response! Couldn’t have said it better.
– Michael
XENOS #42; flying 3 years
OneX #169; ~ 2 months from first flight
Posted: Sat Feb 28, 2015 10:09 am
During steep turns, rolls, and wingovers you’ll pull about 2 G’s. Loops are best done by pulling until you reach 3 G’s and then holding to complete the loop. Cubans are usually under 3, Reverse Cubans slightly less. The only time I see 4 G’s is during some hard 90 degree bank turns, and then you feel that pretty good. Most everything else is done slower which helps keep the G load down. If I was worried about pulling more than 3 G’s because the airframe wasn’t up to the task, I’d choose another airframe because it’s surprising easy to rack up the G’s. Knowing the Sonex will go to 6 G without a problem takes all the worry out of breaking the airplane!
Posted: Sat Feb 28, 2015 12:25 pm
It seems an aircraft needs to be designed around a BRS from the get go. Retrofitting one to a plane not designed for it is full of compromise and non-optimal features. Not to mention, could be downright deadly to the occupants if during the deployment, a cable crosses the cabin.
Posted: Sat Feb 28, 2015 4:58 pm
SonexN76ET wrote:The potential events I could envision using it would include: mid air collisions, air frame failures, control system jams or failures, partial or complete pilot incapacitation, engine failure over inhospitable terrain, a stall or spin that was unreoverable, inadvertent encounter with icing, or if an engine mount were to break
I understand the sentiment of this poster; and my next few comments are not intended to be aimed at him specifically; but I want to address this notion that a BRS is a “get out of jail free” card and provides for a safe landing… It absolutely does not.
It takes some completely-unsurvivable situations and makes them somewhat-less-unsurvivable. And for some cases it absolutely can save lives. But in many cases you need to think long and hard about whether it provides enough of an improvement to be worth the tradeoffs.
When you fire a BRS your aircraft will still descend at a fair rate - you’re not falling at a feather’s pace. The airframe and seats are expected to still absorb some impact-forces when the thing hits the ground.
And then once its on the ground, wind can drag the airframe. See the recent Cirrus ditching for reference. Note how the wake forms around the aircraft as its dragged along the water and eventually flips.
Now think about those two points and reference the earlier post about firing the BRS through the floor and landing upside down. Now imagine that happening on a rocky hillside, or a heavy forest. How long would the Sonex turtledeck and canopy protect the occupants? (Or any aircraft, really…)
Many of the failure-modes listed at the top of this message can be mitigated by:
- Flying Regularly [keeps corrosion down and helps keep lubrication spread across moving parts, as well as keeping the pilot from becoming rusty]
- Performing Good Pre-Flight Inspections [catch existing or impending problems before they happen in the air]
- Good Maintenance Practices [find small cracks before they become big ones; not every engine-mount tube is going to fail at the same time, for example]
- Being Mindful of your Weight & Balance [ensures that you don’t get into unrecoverable stalls or spins]
- Don’t Fly VFR into IMC or take stupid chances flying when the weather is crappy [avoids icing]
All of the above steps are cheaper and easier than engineering a BRS installation, paying for the BRS, and maintaining it over time. The steps above also don’t require dead-weight to be carried in the airplane, reducing its useful load and increasing its stall-speed. They don’t require extra pyrotechnics in close proximity to the airplane’s occupants, either.
I’m not saying a BRS has no value; but often it is viewed as a panacea, or as a crutch that enables poor pilot proficiency or irresponsible/inattentive behavior.
We should think hard about items before we put them in our airplane, and understand the true value (and risk and cost) associated with them.
–Noel
Posted: Mon Mar 02, 2015 11:38 am
by gcm52
I installed a BRS when I built my Zenith 701. I never did get my money’s worth out of it as I never had any problems with the 701, however there are scenarios where the BRS would be a good last option (midair, airframe failure, etc) The BRS install in a Sonex would be more challenging. However, I am thinking about a seatpack type parachute instead of upholstery for the Onex I plan to build. I have not researched this much in terms of how comfortable this would be, (the cost is high, $2500 or so) but don’t you need a parachute for aerobatics anyway? Part of the reason I put in the BRS and am looking at a seatpack parachute for the Onex is that I have personally known two very competent pilots who perished in situations where a parachute would have saved them. One had a midair in an RV during formation flight, the other had an improperly welded wing fitting fail in a Citabria during aerobatic instruction.
Posted: Mon Mar 02, 2015 2:40 pm
gcm52 wrote:I have not researched this much in terms of how comfortable this would be, (the cost is high, $2500 or so) but don’t you need a parachute for aerobatics anyway?
FWIW, glider/sailplane pilots often wear parachutes when we fly long cross-country flights (4-6 hours). Its an insurance policy that is simple to add and use, and costs almost nothing to maintain (keep it dry, and repack it twice a year for about $50 a pop). With a little lumbar support (i.e. a thin pad or towel between my lower back and the 'chute), I’ve never had any comfort issues; even on all-day flights.
The big difference in sailplanes is that we’re usually sitting in a reclined/“lounge-chair” position - so we wear long/thin parachutes (like the Long Softie). However, there are many different models to choose from. Folks with really sensitive backs/backsides report that a sheepskin back-pad (an optional extra on most 'chutes) is a good investment for them.
Brand new parachutes do cost around $2500. But they last 15-20 years. You can often find previously-owned parachutes for around $1500 (these 'chutes not new and have fewer useful years remaining, but are not actually “used”/deployed).
Fly safe,
–Noel
Posted: Mon Mar 02, 2015 10:30 pm
I bought a National Flat Pack 2 years ago for about $1800 from ACS. Costs me $35 every 6 months to repack if I want to stay legal. I loan it to anyone who wants it for whatever they might be doing.
I remove the upholstery when I wear the pack. I only wear it when doing aerobatics, solo. I don’t do aerobatics with a passenger. I’m not required to wear it, but it gives me comfort knowing I can bail out. My wife supports it.
Posted: Tue Mar 03, 2015 1:42 am
by rbarber
To answer Frank’s question; I second the 3 Gs as normal. I frequently see 3.5, but have recorded 4.5 on a few occasions. I did see 6.5 recorded once, but it was due to clear air turbulence. Took the fun right out of the flight. An inspection of the airframe on landing revealed nothing (short of a brown stain in my underwear). Under normal circumstances loops and such I never see any movement of the wings. I did a lot of loops looking at the wing while trying to catch a “just so” picture. Finally got it (close anyway):
Rob,
N157SX
