B and C voltage regulator
Posted: Sun May 03, 2020 9:04 pm
by T41pilot
Has anyone tried the new B and C voltage regulator yet? I’m in the process of doing a few Firewall things and am curious whether their new voltage regulator provided a higher output at low rpm and maybe provide a charge or at least break even battery voltage instead of a discharge during taxi. It’s costly, but with the built in crowbar it simplifies things and may be less prone to failure. Before I spend the money, I wouldn’t mind some feedback.
Re: B and C voltage regulator
Posted: Sun May 03, 2020 10:31 pm
hi gregg, all,
ive been watching these too. are you looking at the LRC-14? $180. plus they have an install kit for $45.
interesting to note is they reccomend to install on the cockpit side of the firewall. away from vibration and heat and moisture. built in low voltage warning , and over voltage crowbar.
jeff schultz mentioned these a few months ago. any thoughts jeff?
greg let us know if you get one and if you like it.
Posted: Mon May 04, 2020 11:36 am
by T41pilot
Hi Michael
Yes, that’s the one I’m looking at. My guess on the cockpit side of the install is that the additional electronics in the Regulator can not stand the added heat from the engine compartment. Our standard regulators apparently generate a lot of heat and aren’t too happy with the additional engine compartment heat as it is. That may be why they are failing. I think we are loading them at capacity on a regular basis. I’ll probably get a B and C anyway even if I don’t get any feedback but it looks like end of summer before My engine is running. I still have a ton to do yet so I won’t be able to generate a report any time soon.
Posted: Mon May 04, 2020 12:31 pm
Hi gregg,
yes i’d go w the b& c new unit. it s should last forever. i think your right about the heat. i have blast tubes to my coils, jab 3300. on my to do list is a blast tube to the regulator.
keep at it and happy building!
Posted: Mon May 04, 2020 1:23 pm
The new B&C voltage regulator designed for permanent magnet alternators is the “AVC1”, and B&C lists it for something like $260. According to their marketing department it was due to hit the website but the coronavirus situation interrupted that effort.
B&C says it will be available on the web shortly (time???), and that initial user feedback has been extremely good on the unit. I think this is an ideal option for all Jabiru, AeroVee, Revmaster or Rotax users that are looking for a replacement VR.
Posted: Mon May 04, 2020 1:40 pm
Gregg,
From your posts, it seems you have an Aerovee? Double-check, but my interpretation is the LRC-14 regulator is not intended for permanent magnet alternators like the Aerovee has. Even if it works, there’s no field windings for it to control to increase the voltage at low RPM, so you’ll be missing out on a primary benefit.
I’m not sure how common regulator failures are on the Aerovee. I have one installed in the recommended location without dedicated cooling and haven’t had any issues with it.
Edit: I see Jeff’s post now, the AVC1 sounds more like what Gregg was probably originally referring to. https://bandc.com/wp-content/uploads/20 … -11-20.pdf
Posted: Mon May 04, 2020 3:52 pm
hi jeff, chris, all,
thanks for the info and update. i thought the LRC-14 was the new one. i will wait for the AVC-1 to hit the webpage.
i plan on getting one. gregg did you see jeff’s and chris posts?
thanks jeff!
Posted: Mon May 04, 2020 4:55 pm
I confirmed with B&C that the AVC1 is available and ready to purchase. Until the website is updated, you’ll need to contact sales directly (Nathan Bainbridge, nathan@bandc.com). I’ve attached the product info flyer as well.
Posted: Mon May 04, 2020 5:57 pm
I’m not clear on how this regulator enhances low rpm charging output from out little 20 amp stators. Whats the scoop?
Posted: Mon May 04, 2020 6:10 pm
by T41pilot
WaiexN143NM wrote:hi jeff, chris, all,
thanks jeff!WaiexN143NM
Yup Michael. I thought the LRC was the new one too. Glad Jeff set the record straight on that one. I’ll be purchasing it and hope that it’s reliable to justify the price.
Posted: Mon Jun 01, 2020 1:06 am
hi all,
the new voltage regulator avc1 is on the webpage from b&c. you also pick the field install kit, and the capacitor.
Posted: Mon Jun 01, 2020 9:01 pm
gammaxy wrote:I’m not sure how common regulator failures are on the Aerovee. I have one installed in the recommended location without dedicated cooling and haven’t had any issues with it.
I also have had the same regulator for 6 years, on the engine-side of the firewall, no cooling, and have not had any issues. I do carry an extra one in my tool kit just in case.
