Aerovee Primary Ignition
Posted: Thu Jun 27, 2024 8:21 pm
by Holmesryan
Yikes, i have been having primary ignition issues. I bought a plane that the builder threw in the towel and it has 77 hours on it. A little aerovee purrs like a kitten on the secondary but misses and backfires on the primary. I pulled the engine today, the witness hole looked correct. The magnet was correct. I put on new mags and tested to make sure the p-lead was grounding. I ordered new plugs and will ohm them before i install, what else should i be looking at. I am at a loss. Thank you all
Ryan
Re: Aerovee Primary Ignition
Posted: Thu Jun 27, 2024 10:56 pm
by Raluttio
Check the clearance between the magnets on the flywheel and the mags. It should be .010” and is addressed on page 33 of the assembly manual.
Nothing else comes to mind - there’s not much that could be wrong with the system.
Posted: Thu Jun 27, 2024 11:30 pm
Have you tried running it with the p-leads disconnected? That is worth a shot.
Posted: Fri Jun 28, 2024 6:50 am
Wires going to the correct cylinders?
Posted: Fri Jun 28, 2024 10:11 am
by Holmesryan
I’m going to try running p-leads disconnected.
Then I’m going to change the top plugs.
Top mag runs to front top of engine
Bottom to the back top engine
The magnet I did not change but the orientation was correct with the s pole facing out attracting the north on an aviation compass.
Posted: Sat Jun 29, 2024 9:07 am
I had a problem with the primary. Kerry sent me a new magnet. It was identical to original magnet. The only way I could get the primaries to fire reliably was to close the air gap to .005"
Posted: Sat Jun 29, 2024 7:43 pm
Area 51% wrote:Wires going to the correct cylinders?
I think Area 51 is on to something here, plug wires going to the wrong plugs would cause the symptoms you mentioned. Easy to check
Posted: Sun Jun 30, 2024 2:49 pm
by Holmesryan
Area 51 and others-
Top mag goes to front top cylinders should top wire go to x and the bottom wire go to x.
Bottom mag goes to the top rear cylinders, same equation as above?
Just as a follow up plugs all new, I checked and there is spark and I regapped the mags.
Re-grounded everything
Ran both mags p leads off, each time engine ran the same.
Posted: Sun Jun 30, 2024 4:11 pm
Holmesryan wrote:Area 51 and others-
It sounds like you have the correct wires going to the correct plugs. It is sort of engineer-proof. The top magnetron will reach either set of plugs, but the bottom magentron will only reach the aft set.
Are you able to monitor all 4 EGTs? Or CHTs? Would be telling if either the front or back were good, and the other were bad.
I am still thinking it is either a flyweel index issue or a magnetron magnet issue.
Posted: Mon Jul 01, 2024 10:40 am
Holmesryan wrote:Top mag goes to front top cylinders should top wire go to x and the bottom wire go to x.
Just to be different (and the wires were so short they would touch the exhaust pipe) I ran the bottom mag wires to the bottom of the rear cylinders. It ended up working famously.
Posted: Mon Jul 01, 2024 11:41 am
Area 51% wrote:Just to be different (and the wires were so short they would touch the exhaust pipe) I ran the bottom mag wires to the bottom of the rear cylinders. It ended up working famously.
That’s really clever. I melted one of those wires early in phase 1 and had to come up with adel clamps mounted to the intake tube.
Posted: Mon Jul 01, 2024 11:05 pm
by Holmesryan
Well the magnet was reversed. Which if anybody in the future reads this the awrovee book is confusing. Especially with the different compasses. If the magnet holder is at 12 o’clock or facing up, the top of the magnet when placed in the holder on the flywheel is north or out to the world where the South Pole should be facing toward the center of the engine. I utilized a polarity tester that cost 19 on Amazon but saved me struggling with the different compasses.
Thank you all for your help.
Ryan
I thought i saw here a source and alternate part # for the mag ignition module, does anyone recall? I seem to have lost the bottom ignition module for 1 & 3. During run up this morning with mags only rpm decreased quite a bit and 1 and 3 EGTs dropped significantly.
I’ve used an Oregon 33-345 before, as recommended by Graeme. I did not get a ton of life out of them though. The ones I bought from Sonex last time had a p/n of 440-441 on them, and I bought a couple from ebay but have not installed them yet.
https://www.ebay.com/itm/147280758211
Sonex is an option again!
Sonex is def the preferred option, not sure what speed they are up to. Its good to have alternatives in the notebook…
Thank you
I emailed Sonex several days ago… no response. I suppose it will take time for them to get up to speed.
The mags from Sonex were backordered so I found the same ones on eBay. Stens model 440-441. Used the shim from Sonex to set the gap and it’s been perfect for 15 hours now. https://ebay.io/m/73sCEh
EDIT: I realize now that this is the same mag Bryan recommended.
