Aerovee one EGT high
Posted: Sat Mar 23, 2024 4:54 pm
Hey all,
Looking for some thoughts from the Aerovee brain trust. I have one cylinder (#1, back left) going insanely high, like over 1500F. This is during a full power climb. If I enrichen it to get it below 1400, the engine runs poorly as the other cylinders are too rich. The others average about 1200 in climb. In cruise it will run below 1400, but the others are 1000-1200. I have swapped the EGT probe from the #1 and #2 cylinders and the high temperature stays with the #1 cylinder. I’ve also swapped inputs on the MFD and again the high temperature stays with #1. So I believe it’s too hot and I’m not seeing an instrumentation error.
This happens on just the mags, or on both ignitions. I did not try on the secondary ignition only.
I did reseal the left intake manifold, but no change. It seems an induction leak would be a potential cause of a high EGT.
In reading other forums a bad exhaust valve is listed as a possibility, or head gasket, or cylinder issue.
My recent compression test was 116/119/126/125. Last year was 119/121/125/119.
I’m thinking of pressuring the intake with a shop vac to look for a leak with soapy water. Otherwise I’m thinking of pulling the head to have a look.
Any thoughts welcome.
Edit: I also checked the #1 valve last on the exhaust.
Re: Aerovee one EGT high
Posted: Sat Mar 23, 2024 6:39 pm
Don’t know if this would cause it, but is the exhaust gasket on that cylinder good? I’ve had to replace them more often than I expected.
Posted: Sat Mar 23, 2024 7:03 pm
Screw the electronics…What story do the spark plugs tell?
Posted: Sat Mar 23, 2024 7:43 pm
I’ll check the exhaust gasket. They are the originals.
Plugs are coming out, stand by…
Posted: Sat Mar 23, 2024 11:50 pm
by n502pd
Another thing to look at is the intake manifold gasket security. if one bolt isnt as tight as the other, there may well be just one cylinder sucking air. I have saftied those bolts and have not had any of then come loose any bit. The other thing to consider is the probe may be at fault, if nothing else is found. The plug will also tell you , comparing to one of the other cylinders plug, if cylinder is actually very lean. Pleas e let us know what you find!
Posted: Sun Mar 24, 2024 8:44 am
n502pd wrote:Another thing to look at is the intake manifold gasket security. if one bolt isnt as tight as the other, there may well be just one cylinder sucking air. I have saftied those bolts and have not had any of then come loose any bit. The other thing to consider is the probe may be at fault, if nothing else is found. The plug will also tell you , comparing to one of the other cylinders plug, if cylinder is actually very lean. Pleas e let us know what you find!
Joe,
I redid the intake sealing on that side, so it was secure. Maybe there is a warp or crack, I’m not sure.
I did swap probes, and the high EGT stayed with cylinder #1.
Posted: Sun Mar 24, 2024 10:11 am
secondary plugs.png (260.03 KiB) Viewed 3342 times
Posted: Sun Mar 24, 2024 11:22 am
What are the corresponding CHT’s while #1 is displaying the unusual high temp?
Posted: Sun Mar 24, 2024 11:49 am
Lou,
My #1 CHT failed. It reads around 100F after the engine warms up. Pretty much everything else was under 200F. It was cool out. Oil temp was 161.
Edit: I assume it has failed. I’m going to do a differential compression test today.
Posted: Sun Mar 24, 2024 12:37 pm
Bryan, you didn’t mention so I won’t assume. You did verify both the top and bottom plugs are firing ok - right? Only one plug firing will give a hot egt as fuel burns slower and gets out the exhaust before it’s ready.
Posted: Sun Mar 24, 2024 12:48 pm
BRS wrote:Bryan, you didn’t mention so I won’t assume. You did verify both the top and bottom plugs are firing ok - right? Only one plug firing will give a hot egt as fuel burns slower and gets out the exhaust before it’s ready.
Brock,
Mag check has been good. Generally I switch to the primary ignition only by 1000’ AGL or so.
Posted: Sun Mar 24, 2024 2:37 pm
How are the CHTs. Is the side with the higher EGT also showing increased CHTs? If not then It could be as simple as the placement of the EGY probe in the exhaust. Just a slightly different angle or distance than the others could certainly cause a 100f difference. CHTs are what you really need to monitor and worry about. When they get too high you start damaging the head and can loosen up the valve seats. EGTs are less about the absolute number displayed and more about the relative changes when leaning. If your CHTs are good I would keep on flying and just periodically pull a plug to make sure it looks good and maybe borescope the valves at each oil change.
Posted: Sun Mar 24, 2024 3:29 pm
The #1 CHT has been reading 100F. It seems faulty, 200-300 is more normal for me.
The troubling thing is the big change from normal after 200+ hours.
Posted: Sun Mar 24, 2024 3:50 pm
by BobDz
Bryan
If I remember correctly, didn’t you change the needle in the AeroInjector? Richer? Or leaner? Did the high EGT start after that?
Posted: Sun Mar 24, 2024 4:35 pm
Bob,
Here is the sequence. First I did the annual and all that entails:
- torque heads
- adjust valves
- change plugs
- compression test
Then, some extra credit:
5) re-shim engine
6) redo main seal/polish flywheel surface
7) Fresh air induction
So I noticed the EGT being higher after fresh air induction. Makes sense, more air and the same fuel means leaner. So I adjusted my #2 needle a few times, then swapped to #2.5
It’s entirely possible the high EGT on #1 was caused by something else and I attributed it to the fresh air induction. Maybe I have a bad or leaking spark plug on the #1 cylinder.
I’m halfway through my differential compression test. So far I have:
#1 80/72
#2 80/67
These are cold and I hear air in the crankcase, so it’s getting past the rings. The numbers don’t seem that bad.
Posted: Sun Mar 24, 2024 5:08 pm
by Mike53
Mike Busch has some thoughts on this.https://www.savvyaviation.com/unbelievable-compression/
Posted: Sun Mar 24, 2024 6:10 pm
Thanks Mike!
Final results:
#1 80/72
#2 80/67
#3 80/64
#4 80/74
The adapter was not threading happily into #3 and I suspect that lowered the reading a little.
Boroscope next.
Posted: Sun Mar 24, 2024 6:52 pm
The valves look good. I’m going to swap the spark plugs on the #1 cylinder. They are new at annual and maybe one is faulty, or leaking even.
Posted: Mon Mar 25, 2024 6:29 am
by RodgerC
It may be worth checking that you don’t have interference between valve adjusters and the rocker cover, due to an excessively compressed cork gasket.
Posted: Mon Mar 25, 2024 9:18 am
RodgerC wrote:It may be worth checking that you don’t have interference between valve adjusters and the rocker cover, due to an excessively compressed cork gasket.
Thanks Rodger. I’ve got rubber gaskets and there are definitely no witness marks on the inside of my valve covers.
Posted: Mon Mar 25, 2024 9:42 am
The 80 psi leak down test will pinpoint a leaking valve.
Posted: Mon Mar 25, 2024 9:44 am
Onex107 wrote:The 80 psi leak down test will pinpoint a leaking valve.
When I did the 80 psi leakdown test yesterday I had no air leaking through the valves, just the rings.
Posted: Mon Mar 25, 2024 11:30 am
by BobDz
So…
High EGT can be caused by an excessively rich mixture. Fuel is still being burned when the exhaust valve is open. This scenario might also show lower CHT. But I am at a loss to explain why it would only be happening in one cylinder, and why it would just start randomly. Is the exhaust valve staying open longer than it should be? Maybe stuck slightly open?
Posted: Mon Mar 25, 2024 12:15 pm
BobDz wrote:So…
Bob,
When I enrichen the mixture the high EGT comes down, but the engine starts running poorly. So it seems the one cylinder is lean.
Posted: Mon Mar 25, 2024 12:29 pm
by BobDz
Bryan Cotton wrote:
BobDz wrote:So…
High EGT can be caused by an excessively rich mixture. Fuel is still being burned when the exhaust valve is open. This scenario might also show lower CHT. But I am at a loss to explain why it would only be happening in one cylinder, and why it would just start randomly. Is the exhaust valve staying open longer than it should be? Maybe stuck slightly open?Bob,
And your compression tests don’t show a stuck / open valve.
Posted: Mon Mar 25, 2024 12:48 pm
BobDz wrote:And your compression tests don’t show a stuck / open valve.
Correct
Posted: Thu Mar 28, 2024 11:14 am
Just to link this to another relevant thread, check this out:
viewtopic.php?f=7&t=3725&p=58226#p58226
I may have caused the imbalance with my asymmetric introduction of fresh air.
Posted: Thu Mar 28, 2024 11:55 am
When I did the cold air intake on the R2300 using a Rotec MKII carb, Rotec cautioned about elbos near the carb. There were none but but I did go ahead and make a flow straightener to dampen any intake air swirl. Perhaps something like this might be helpful.
Posted: Thu Mar 28, 2024 1:03 pm
I had considered that Brock but not sure how I would implement it given I don’t have a flange mount. For now I’m going to remove my fresh air induction and verify the issue goes away. Then I’m going to add a second input to make it symmetrical. I’ll fabricate a T or Y pipe to split the flow.
Posted: Fri Mar 29, 2024 10:41 am
So I flew this morning with my cold air induction removed and I am able to climb to 4500’ and keep it below 1400F. The other cylinders are around 1200F. I’ve lost some RPM in the climb with the loss of fresh air.
So this brings up an interesting thought - it seems I can steer the mixture left/right by messing with how the air goes into the filter, much like Michael (rizzz) observed in the other thread. What I need to do is to steer it the other way, and I can get my left and right aft cylinders in balance. That should allow a little more leaning overall and better performance. I am going to put another input into the air filter shroud, symmetrically, on the other side. I’ll do some flight tests to figure out how to balance airflow between the two sides and achieve nirvana.
I also have a set of Great Plains intake manifolds that I bought from Graeme Smith, and I may try those to see if it balances fore/aft better than the stock manifolds. I did a quick check last week and it appears I will be able to bolt them on and get them to line up with the intake tube. These are the manifolds I have: https://www.greatplainsas.com/0251-/-bu … ystem.aspx
For now I’m leaving it as is until after the eclipse.
